Going wild at the chess board!!
Blog entry by degoose posted 04-26-2009 10:39 AM 3992 reads 27 times favorited 18 comments Add to Favorites Watch
Welcome.
Where do I start, at the beginning I suppose, I was born at an …..sorry not that far back!
Ok let do this. [ I will be using imperial measurements throughout this blog..mainly ‘cause all wood working should be in imperial not metric! IMHO anyway]
To start :
Select the timber you will be making this here crazy board out of. For me this was Silver Ash and Tassie Blackwood as they contrast and compliment each other. I also decide to use
some purple heart as an accent.
Now decide on the curve you will be using. I just drew freehand a slow curve on a piece of scrap plywood. Then cut it on the bandsaw and used it to draw out the design on some more plywood.
This will give you an idea of the way the finish board will look.
NB If this is to be a checkers or chess board 8 ‘squares’ by 8 ‘
You will need two blanks about 22 inches square [give or take], one light and one dark, so edge join narrow boards to achieve this. Sand or plane them flat and level. Thickness is up to You but mine Started out about ¾ inch.
Place the light blank on top of the dark blank with double sided tape between to keep them aligned. Using the template draw the first curves on the light blank. [easier to see] and cut on the band saw.
You will now have a number of worm-like pieces of timber. Keeping them in order separate the light and dark and reassemble them with alternating colour strips. You will have two boards that look something like this. [ hopefully a little better cut]
Cut the accent strips from the contrasting timber..in my case the puple heart. I cut the strips 1/16 inch thick using the Incra TSLS32 table saw fence [unashamed plug].
Lay these strips in between and using a good amount of Titebond II [ another plug] and don’t starve the joint, glue up the new blanks [I find that doing this in two parts is a little easier] and clamp until dry [use as many clamps as you can to make sure that all the surfaces have pressure]
Don’t take to much notice if the lines look a bit wonky here as my boards started a little longer than I really needed. Notice the outer pieces have not been cut so as to allow better clamping!
You will now have two almost identical [mirrored] blanks. Sand or plane flat and level and keeping the same orientation double stick tape the blanks together. i.e. all the cuts line up.
This shows the basic ‘Idea’ as I don’t have all the pics of every step
Now mark and cut the new strips , separate and alternate the ‘worms’ again [keeping them in order so that any small mistakes will be duplicated in the matching piece]. Insert the accent stripes glue and clamp.
Take care that they don’t slip as they did for me. Keep all the lines tight.
In this pic you will see some screws. I used these to secure the two blanks as I had run out of double stick tape and the hardware store was closed and I was inpatient.
Band saw all the edges clean and sand. Sand the board to 180 or so and apply a finish of you choice/. I used Tung Oil Finish.
18 comments so far
27250 posts in 3817 days
#1 posted 04-26-2009 11:58 AM
This is a well documented tutorial, Larry. You have explained the process pretty well, IMHO.
Thanks for the post.
View spanky46's profile
spanky46
995 posts in 3385 days
#2 posted 04-26-2009 01:35 PM
A class well taught by a teacher with a lot of class! IMHO
I always look forward to your next post!
Thanks Larry.
-- spanky46 -- Never enough clamps...Never enough tools...Never enough time.
View Vince's profile
Vince
1148 posts in 3424 days
#3 posted 04-26-2009 02:01 PM
Good tutorial. This looks to be a fun project.
Thanks Larry …aka degoose
-- Vince
35120 posts in 4395 days
#4 posted 04-26-2009 02:56 PM
Great tutorial and a nice job. Well done.
View mtnwild's profile
mtnwild
3474 posts in 3522 days
#5 posted 04-26-2009 04:47 PM
Thanks David, very cool.
View Napaman's profile
Napaman
5526 posts in 4072 days
#6 posted 04-26-2009 04:58 PM
I remember in the 1970’s when i was in elementary school (sorry half of you who just got older)...they were telling us that we would be moving to the metric system…i just turned 39…and we are still using the IMPERIAL Measurements…despite the damn revolution!!! At least we now have representation with our taxation…
Now to your project young man…very cool…love the details…this is going inmy favorites…
matt
-- Matt--Proud LJ since 2007
View mmh's profile
mmh
3676 posts in 3717 days
#7 posted 04-26-2009 05:06 PM
Nicely done and shared! Alice in Wonderland would love this. I would too, but I’m drug free }:)~
View croquetman's profile
croquetman
136 posts in 3316 days
#8 posted 04-26-2009 07:00 PM
How do the pieces stay put?
-- Whatever
View Betsy's profile
Betsy
3391 posts in 3891 days
#9 posted 04-26-2009 07:06 PM
Can’t wait to try this. Thanks for the instructions.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
117090 posts in 3572 days
#10 posted 04-26-2009 07:26 PM
Great tutorial and photos .fun unique project. Thanks for all the work regarding this post I really appreciate it.
super job David.
View kiwi1969's profile
kiwi1969
608 posts in 3437 days
#11 posted 04-27-2009 12:37 AM
Being born and raised on the metric system I cant add 3/16 + 5/32 without staring at a ruler until my eyes glaze over! And why do tool makers insist that 6mm is the same as 1/4 inch? PAH ! where,s my calculator!
View degoose's profile
degoose
7233 posts in 3349 days
#12 posted 04-27-2009 02:18 AM
11/32
View gwebb's profile
gwebb
13 posts in 3332 days
#13 posted 04-27-2009 02:23 AM
I guess its easier then saying 6mm is 30/127”.
View Grant Davis's profile
Grant Davis
770 posts in 3903 days
#14 posted 04-27-2009 03:05 AM
Degoose, props to you for for your tutorial. I can see many versions of this being posted here at LJ in the future. My grandma used to say….”The greatest for of flattering is to have someone copy your work!”
-- Grant...."GO BUCKEYES"
View Chris Davis's profile
Chris Davis
1560 posts in 3977 days
#15 posted 04-27-2009 12:11 PM
Thanks for sharing. This is a technique that can be used on all sorts of projects. Great job.
-- Watch live video from our shop. http://www.wwbeds.com/#!current-projects/c3c1
showing 1 through 15 of 18 comments
