Having sourced the timber it was time to cross cut to size and rip to width..
The board is going to be 650 mm by 400 mm [26 in by 16 in] so I cut the pieces to 850 mm [34 in] taking in the 3mm [1.8 in] kerf for each cross cut in the next step….. and sized them to 50 mm [2 in] thick.
This will leave a little extra to hold against the fence when crosscutting and maybe a little left over the make a small herb board to match…
Then each piece was ripped to the desired width… and arranged to give the best pattern… making sure to orientate the grain…
Each board from the right was moved over to the left to see how the patteren would look.
This pattern had to be adjusted to make sure the width of the board was exactly 400 mm.
[The width dictated that more strips were used… to make sure that there was no splitting … wood movement in larger pieces may eventually cause cracks…]
Into the clamps over night… next step tomorrow…
17 comments so far
Bob Collins
home | projects | blog
1129 posts in 1856 days
#1 posted 484 days ago
Looking good so far Larry, nice variety of wood. Look forward to the next episode.
-- Bob C, Australia. I love sharing as long as it is not my tools
ellen35
2442 posts in 1605 days
#2 posted 484 days ago
You are an adventure in wood, Larry!
Like Bob, I’m anxious to see the next installment.
Ellen
KnotCurser
1410 posts in 1241 days
#3 posted 484 days ago
Now you got me hooked to “As The Board Glues”....... Will it Crack? Will it Warp? tune in tomorrow!
-bob
-- Man is a tool-using Animal. Nowhere do you find him without tools; without tools he is nothing, with tools he is all. - Thomas Carlyle http://www.ffrf.org
HalDougherty
1820 posts in 1409 days
#4 posted 484 days ago
Larry,
You are the cutting board master. One of the first LJ projects that inspired me was one of your cutting boards. I had a lot of small pieces of lumber left over from making gunstocks, so I made a cutting board from them and used it as the top of a kitchen island. its about 24” by 24” in size. Another project I want to make someday is to build a bench from a laminated slab of blocks. I’m building another hydraulic press to glue up gunstock blanks that will handle a 12” X 55” X 4” glue up.
-- Hal, Tennessee http://www.first285.com
nonickswood
266 posts in 559 days
#5 posted 484 days ago
Looking Good, Staying Tuned!
-- Nick, Virginia, http://www.etsy.com/shop/NONICKSWOOD
Beginningwoodworker
13225 posts in 1845 days
#6 posted 484 days ago
Looks good, Larry.
-- CJIII Future cabinetmaker
rance
3856 posts in 1333 days
#7 posted 484 days ago
Looks like it is coming together Larry. Questions and a comments:
>“making sure to orientate the grain…”
For looks, or for stability?
>“wood movement in larger pieces may eventually cause cracks…”
Percentage wise, thin strips expand as much as wide strips. They can cause just as many cracks. Are you breadboarding the ends?
stefang
9510 posts in 1506 days
#8 posted 484 days ago
Fun to watch Larry and I never would have thought to see the final pattern the way you did it. Looking forward to the next installment.
-- Mike, American in Norway
sras
3248 posts in 1301 days
#9 posted 484 days ago
That’s going to be a big one! Looking forward to your next post.
Philzoel
253 posts in 516 days
#10 posted 484 days ago
Larry: What are the woods? Are they hardwood? Small pores?
26×16 is large. Could make a chopping table out of it.
-- Phil Zoeller louisville, KY
LittlePaw
1500 posts in 1250 days
#11 posted 484 days ago
Looking good, Larry. What kind of glue did you use?
-- Paul - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
87370 posts in 1749 days
#12 posted 484 days ago
Thanks for the blog on boardem assembly,you da master of the board.
SASmith
1369 posts in 1159 days
#13 posted 484 days ago
I just finished my biggest board to date and it was way more work than I expected.
Looking forward to seeing yours.
-- Scott Smith, Southern Illinois
robert triplett
1309 posts in 1277 days
#14 posted 483 days ago
If I had any questions, somebody else has asked them. Nothing like seeing a project take shape.
-- Robert, so much inspiration here, and so little time!
matt garcia
1736 posts in 1844 days
#15 posted 483 days ago
Trees fear you!!!!
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
View all comments »
