If you knew Sushi.... #4: Two handles, two curves..
Blog entry by degoose posted 08-05-2011 11:34 PM 1710 reads 2 times favorited 4 comments Add to Favorites Watch
« Part 3: Two in a set. Part 4 of If you knew Sushi.... series Part 5: Out of order... sorry.... »
You will have seen on the sushi boards, that I have cut two curves on the handles.. If I were just making one board, the cuts could be made freehand on the bandsaw…but…
Since this is now part of the range… I need to be able to produce these cuts on a regular and repeatable basis… so once more a jig is needed..
To start, glue the mainboard to the handle/ends… this need not be a great bond… it is to temporarily hold the pieces together while they are cut…
Move to the bandsaw and make the first of a series of cuts..
The handle is cut… on the curve cutting jig,
The blank is then moved along the jig and the cut is repeated to remove the waste of the handle.
Using a small amount of glue the cut handle is glued onto a scrap [remembering to position the piece curve side up and the holes outward.]... for easier handling on the curve cutting jig.
You may see the holes for the brass rods have already been drilled..
A fence was set up and positioning marks made on the fence.
Now we repeat the cuts for the second curve on the handles.
You will notice that there were two sets of holes drilled in this piece… a small mistake that will be easily fixed with a little sanding…
Here be the four blanks for the set of four..
Queensland Maple with one thin stripe of Purple Heart…
More to come!
4 comments so far
View LittlePaw's profile
LittlePaw
1571 posts in 2949 days
#1 posted 08-06-2011 12:19 AM
Soooo, that’s the method to your madness, heh, Larry? Thank you for sharing how you do it with us! That’s one of the reasons I like LJ so much. I am constantly learning and having fun at the same time! Y’just can’t beat that! Don’t stop, y’hear? ! ? ! ? !
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View Joe Lyddon's profile
Joe Lyddon
9979 posts in 3923 days
#2 posted 08-06-2011 01:31 AM
COOL…
“That’s my baby…” :)
View lanwater's profile
lanwater
3111 posts in 2805 days
#3 posted 08-06-2011 06:47 AM
You have been spending a lot of time in the shop.
your jig make life easy.
Thanks Larry.
-- Abbas, Castro Valley, CA
View eddy's profile
eddy
939 posts in 3235 days
#4 posted 08-06-2011 05:17 PM
cool i like the process
-- self proclaimed copycat
