Here you will see the steps in the glue up of the weave strips…
The strips are ready for assembly..
After applying glue to the various surfaces, I assemble the 5 pieces in order and secure with blue painters tape.. this is easy to remove later…
While just using tape can be enough, I like to clamp between two cauls to ensure that the width of the piece remains constant along the entire length.. and it aids by applying even pressure on the strips being glued..
As each set is glued and taped, it is added to the clamps..
This is the slab of Huon Pine ready for ripping … for the background of the Open Weave LL..
Everything out of the clamps and the Huon Pine dressed to size…
After a quick clean up of the glue joints…. It will be time for the most awaited part... the cutting of the various pieces to form the pattern…
15 comments so far
rance
home | projects | blog
3856 posts in 1329 days
#1 posted 672 days ago
Once you posted this, it occurred to me the need to get very accurate cuts so this will all go together as it should. Keep it up and THANK YOU for sharing with all of us.
lanwater
2419 posts in 1103 days
#2 posted 672 days ago
Cool!
The step by step couldn’t be more detailed than that.
Thanks!
degoose
6590 posts in 1523 days
#3 posted 672 days ago
Yes Rance… accuracy is the key… all the weave strips must be the same width…or there will be h*ll to pay…
degoose
#4 posted 672 days ago
Ian,
While this is not a CLASS per se… I am treating it as an exercise in teaching… hope you all don’t mind…
Joe Lyddon
6393 posts in 2221 days
#5 posted 672 days ago
Heck NO! I don’t mind…
I love it!
Thank you very much for taking the time to do it!
rance
#6 posted 672 days ago
Sorry, but I’m a baaaaaad student. I looked back at your Chip & Dip Tray and am curious.
1) What glue do you use to provide the longer open time, and
2) do you roll it on both surfaces or just one?
Thanks for putting up with my questions and thanks for the reply earlier. :)
littlecope
2329 posts in 1671 days
#7 posted 672 days ago
Great lessons to be learned here…
Nice Job on the instruction Mr. Degoose… And the Board is going to be another Beauty!!
degoose
#8 posted 672 days ago
Rance, I use Titebond III and only need to spread on one face… seems to work… I use a roller to give it an even coat..
Joe, Glad you are enjoying this as much as I am…
Mr Little…private joke….thank you…
lanwater
#9 posted 672 days ago
I am pretty sure no one will mind. We all pick up something here and there.
~Julie~
524 posts in 1203 days
#10 posted 672 days ago
I still haven’t made one, but watching these photos sure does make me want to try it!
(Thanks for the non-class)
-- ~Julie~ followyourheartwoodworking.blogspot.ca
MShort
1376 posts in 1587 days
#11 posted 672 days ago
Thanks for the instructional on these. I am learning lots.
-- Mike, Missouri --- “A positive life can not happen with a negative mind.” ---
34370 posts in 2569 days
#12 posted 672 days ago
Larry: Some more meat (er timber) for us to chew upon.
rrdesigns
413 posts in 1355 days
#13 posted 672 days ago
What? I thought this was the second semester. Keep ‘em coming! Much appreciation.
-- Beth, Oklahoma, Rambling Road Designs
Jonathan
2568 posts in 1219 days
#14 posted 671 days ago
Nice amount of detail to go along with the photos. Enough detail, instructions, and explanation to comprehend, yet straightforward and to the point. Well done.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
eddy
885 posts in 1533 days
#15 posted 671 days ago
looking cool thanks for sharing
-- self proclaimed copycat
