When making end grain cutting boards, it is imperative to have flat, square and evenly thick pieces.. the initial milling for the first glue up is easy…here is a video of milling timber
Once glued up…
There may be a small movement and you need to sand the glued up board flat…
Here is the secret... I found that if I crosscut the pieces first, the sanding is simple…
Sand on the drum sander on one side and then flip and adjust the height by 1/4 turn and sand again… this is easier on the work and on the drum sander… just make sure that you number each piece…so they go back in order and orientation…
The sanding of a small piece like this is far simpler than trying to sand the whole blank..
Having all the pieces smooth and even makes the secondary glue up so much easier too.
Just a matter or squaring the ends and sanding…
Even in a two color piece like this the grain orientation is very important…to incorporate the flow…
Once the purple heart has oxidised back to purple I will apply several coats of Oil…
19 comments so far
Joe Lyddon
home | projects | blog
6395 posts in 2222 days
#1 posted 674 days ago
Cool Tips…
What do you do if you do NOT have a drum sander?
... but have a thickness planer?
moshel
838 posts in 1853 days
#2 posted 674 days ago
I tried this on thicknesser when I started.
can be done but you have to make sure to glue an extra strip at the end as the last one will chip something horrible.
-- The woods are lovely, dark and deep, but I have promises to keep...
moshel
#3 posted 674 days ago
and even with a drum sander – you have to have a really good one, like Larry has. with mine you will get a slight capping at the ends as it has only one roller. its very small but when glueing up the crosscut it shows bigtime
degoose
6594 posts in 1524 days
#4 posted 674 days ago
For those with a thicknesser, you can just go and flatten the whole blank…
I use this method because.
A. I have a drum sander…
B. I do not want to loose too much thickness of the blank using a thicknesser…
Hope this is of help to some…
lew
8985 posts in 1925 days
#5 posted 674 days ago
Cool!
Thanks, Larry!
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
moshel
#6 posted 674 days ago
Larry, where are the clamps from? I have some parallel ones but they are not as beefy as these.
lanwater
2420 posts in 1104 days
#7 posted 674 days ago
Thanks for the tip Larry,
On the few boards I made I sanded the whole glued board. I did loose some thickness.
Sam Shakouri
849 posts in 1257 days
#8 posted 674 days ago
Fantastic board and good tip for people who have fully equipt workshop.
By the way, Larry, I’d like to ask this question. Why do people prefer endgrain cutting board to flat one? Dose it have something to do with sharpening the knife, cleaning the board after using it or any other reason than the beauty of the endgrain reflection?
-- Sam Shakouri / CREATING WONDERS WITH WOOD.....Sydney,Australia....
Jim Bertelson
3337 posts in 1334 days
#9 posted 674 days ago
Thank you kind sir. Pretty neat.
-- Jim, Anchorage Alaska
Beginningwoodworker
13225 posts in 1843 days
#10 posted 674 days ago
Beautiful board, Larry.
-- CJIII Future cabinetmaker
34370 posts in 2570 days
#11 posted 674 days ago
Larry Great tips.
degoose
#12 posted 674 days ago
Sam, there are a few reasons..
they look good
they are kinder on your knives,
they don’t mark as easily…
If I may use the analogy used by Marc Spagnuolo… imagine a paint brush held horizontally [Like Long Grain] and using a knife to cut across.. you will damage the bristles [or grains]... and now have the paint brush vertical [Like End Grain] and when you cut the bristles [grains] part and allow the knife to enter the brush… [or board ] and when you remove the knife the bristles [grains] come back together… no damage…
I hope this is of help
Joe Lyddon
#13 posted 673 days ago
A very good explanation!
Sam Shakouri
#14 posted 673 days ago
I told you, you were a good teacher, didn’t I?
Thanks, Larry.
degoose
#15 posted 673 days ago
Yes Sam… You did…
View all comments »
