The next step, now that the timber is dressed to size…..and more fun than sanding…
The Glue Up…
Notice I have purposely left the outer pieces longer… this is to help when the cross cutting is done..
The clamps are set up to size and all pieces are rotated 90 degrees on edge [all exept the last one] and glue is applied to the edge…only one edge receives glue… this makes it quicker if you are doing a production run…I use Titebond III…
Using a rubber roller spread the glue evenly,
Roll each piece back and tighten the clamps… use only sufficient pressure to cause a small amount of squeeze out…
Note the third clamp in the centre… to ensure even pressure..
The alternative board was a little more difficult due to the angled edges… they wanted to ride up when the clamps were tightened…. even tho I used Compress-X....
2 Timber Cauls and 3 G-clamps were used to hold the boards down and flat… and prevent the riding up of the edges…
Not really that much more difficult … just a little awkward.
Next episode will be a video… so stay tuned to crosscutting and selecting the final pattern…
17 comments so far
home | projects | blog
12051 posts in 1508 days
#1 posted 710 days ago
glue boards – check
wait – check
Maveric777
2593 posts in 1243 days
#2 posted 710 days ago
Ohhhh…. I have never seen a clamp like the one in the last picture. That is very cool! Yet again I see and learn something new….
-- Dan ~ Texarkana, Tx.
34369 posts in 2567 days
#3 posted 710 days ago
very good Larry.
Will Stokes
254 posts in 1521 days
#4 posted 710 days ago
Very interesting, you refer to those as G clamps huh? I’ve always heard and called them C clamps, but now that I think about it they do look more like a G! :-) Looking good, I’ve always wanted to try bevels on the strips but haven’t had a chance thus far.
eddy
885 posts in 1531 days
#5 posted 710 days ago
i like those timber cauls need to know where to get them
-- self proclaimed copycat
Beginningwoodworker
13225 posts in 1840 days
#6 posted 710 days ago
Looks good, Larry.
-- CJIII Future cabinetmaker
#7 posted 710 days ago
eddy
thanks to rich greer
http://www.leevalley.com/US/wood/page.aspx?p=31181&cat=1,43838,47843&ap=1
http://www.shopsmith.com/ownersite/catalog/mvclamp_doublebar.htm
Rustic
2983 posts in 1763 days
#8 posted 710 days ago
Woodcraft has some for about 20
http://www.woodcraft.com/Product/2000321/1858/WoodRiver-Clamping-System.aspxbucks
Joe Lyddon
6379 posts in 2219 days
#9 posted 710 days ago
Now, we’re moving!
Thank you.
Jonathan
2568 posts in 1217 days
#10 posted 710 days ago
I like your clamps Larry. The link that David provided above to the shopsmith site appears to be the closest to the clamps in your picture.
I just used the Panel Max Glue Press from Peachtree for the first time a couple of days ago. It’s rather awkward to use, but maybe I just need more practice. It essentially does the same thing, only you’re not limited to minimum widths as you are with the ones on the shopsmith site. The glue press will supposedly glue up any widths from 0-5”. I glued-up 2+inch stock for an end grain board I’m making. This system isn’t inexpensive, but I got it for not quite half price at the woodworking show last year and would not have purchased it if it hadn’t been discounted. I’ll be curious to try it on some larger glue-ups. I used a nice thick caul on the top and the bottom to help evenly distribute the clamping pressure. I’m sure the next time I use it, it’ll work even better as I get used to using it.
Here’s a photo of it in-action, along with some other supplementary clamps just to make sure:
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
degoose
6590 posts in 1521 days
#11 posted 710 days ago
Check out the site… Compress X Clamps..
matt garcia
1736 posts in 1838 days
#12 posted 710 days ago
Sweet!!!
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
lanwater
2417 posts in 1101 days
#13 posted 710 days ago
Larry,
I just realized I have been sleeping during class… I hope the punishment is not too severe for first offence.
I actually missed two blogs… I would like to blame it on a computer glich :)
10636 posts in 2413 days
#14 posted 709 days ago
Very good Mate, love the timber and the caul clamps. Man they sure would help out in glue ups. Don’t forget that hearing protection!! LOL! I’m already half deaf, so why bother. I know morse code.
17838 posts in 2018 days
#15 posted 708 days ago
Looking good Larry. Those compress clamps are brilliant. Must get a pair.
View all comments »
