Circle cutting #9: New cutting and sanding jigs ...
Blog entry by degoose posted 04-05-2011 11:32 AM 4147 reads 4 times favorited 17 comments Add to Favorites Watch
« Part 8: Fitting the Lazy Larry Bearing Part 9 of Circle cutting series Part 10: Arc cutting like Patron does. »
With the big clean up and purchase of new equipment, I decided that the old ratty jigs had to go… and I have now built both a cutting jig and a sanding jig…
Started with some Melamine… and then cut a dado in some Camphor for the sides… this will also help support the material…
The lower part of the sides wraps around the table on the Bandsaw… and on the Disc Sander… using t-nuts and star knobs I attached cleats under the table to hold it in place…
The material to be cut and sanded it placed on a bolt inserted into a sliding dovetail… another t-nut and star knob are use to hold the sliding centre in place [from underneath].
Turning the star knob pushes the centre up against the two side capturing pieces…
The material is then turned on the bolt… very quick, very simple…
This jig can accommodate circles up to 800 mm… or 32 inches… in diameter..
The sanding jig uses the same principle…
I noticed on the original sanding jig that the circle was sanded on one part of the sandpaper only… so I made the centre slider wider to enable me to insert to bolt at alternative positions to use all the paper…
Next on the list, a Patron Jig and a Curve Cutting Jig..
Any questions or comments… feel free…
17 comments so far
View Eagle1's profile
Eagle1
2066 posts in 3061 days
#1 posted 04-05-2011 11:55 AM
nice looking jigs degoose
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
13603 posts in 3337 days
#2 posted 04-05-2011 12:22 PM
hark and bark goose
look’s like someones been spiking your drinks
well done
my plan too
soon as my leg get’s of it’s butt
and starts to work again
View ellen35's profile
ellen35
2738 posts in 3429 days
#3 posted 04-05-2011 12:34 PM
Even your jigs have style!
6855 posts in 3976 days
#4 posted 04-05-2011 01:38 PM
Hi Larry;
Yeah, that should do it alright.
Nice.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3431 days
#5 posted 04-05-2011 03:38 PM
Good decision Larry, nice looking jigs. Look forward to seeing the whole new collection.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
View Jim Bertelson's profile
Jim Bertelson
4173 posts in 3161 days
#6 posted 04-05-2011 04:21 PM
Let’s face it, those are production jigs, and you have to make them much more robust than a jig I might make for the same purpose. Even storage would be a problem for me. That said, they tell us amateurs what it takes to make a robust jig that will stand up to abuse. I have a circle cutting jig for my bandsaw, and it does work, however I don’t think it would take much abuse. So thanks for setting the high bar, sometimes the construction of something more robust or flexible influences the plebian jigs we amateurs make.
-- Jim, Anchorage Alaska
View BertFlores58's profile
BertFlores58
1698 posts in 2918 days
#7 posted 04-05-2011 04:27 PM
Very resourceful and you made life easy. The sliding dovetail you constructed is angled at 45 degree. It is same as lathe (machining lathe) compound rest. That is a nice idea that I can copy for my incoming manual thicknesser using portable planer. Thanks for the idea.
-- Bert
117090 posts in 3573 days
#8 posted 04-05-2011 04:42 PM
Ok Larry the Jigs Up,and there both very good. great job
View Joe Lyddon's profile
Joe Lyddon
10097 posts in 4048 days
#9 posted 04-05-2011 05:52 PM
Very good!
View donjoe's profile
donjoe
1360 posts in 3027 days
#10 posted 04-05-2011 05:55 PM
Great looking jigs but more important very useful jigs. You should get a lot of work out of these bad boys.
-- Donnie-- listen to the wood.
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3032 days
#11 posted 04-05-2011 06:10 PM
Nice jigs, Larry.
View stefang's profile
stefang
15881 posts in 3330 days
#12 posted 04-05-2011 10:17 PM
I’m glad you finally got round to making these fine jigs Larry.
View BigTiny's profile
BigTiny
1676 posts in 2884 days
#13 posted 04-06-2011 12:20 AM
Hi Larry.
Here’s an idea: cut a slot for the bolt that acts as the center so it can be moved side to side, allowing the use of the entire sanding disk with less trouble changing than the idea you mentioned.
Why is it the more intelligent a wood worker is, the simpler his jigs are? :)
-- The nicer the nice, the higher the price!
View lanwater's profile
lanwater
3111 posts in 2930 days
#14 posted 04-06-2011 01:37 AM
Nice jigs Larry.
I never thaught of making a sanding jig for the disk sander.
-- Abbas, Castro Valley, CA
View moonls's profile
moonls
412 posts in 2983 days
#15 posted 04-06-2011 01:39 AM
As Emeril Lagasse would say…let’s kick it up a notch! Nice work Larry.
-- Lorna, Cape Cod
