Torque Workcentre at work.. #33: What cutter?
Blog entry by degoose posted 10-15-2010 10:45 PM 5583 reads 1 time favorited 6 comments Add to Favorites Watch
« Part 32: Flattening a log.. Part 33 of Torque Workcentre at work.. series Part 34: Sign for a Bar... »
In answer to a question from LJ Sharon aka PurpLev.... I took some close up pics of the Carb-i-tool 55 mm 3 flute surfacing cutter… this bit has 3 rotatable replaceable carbide tips…. as they dull or are damaged you loosen of the holding screw with the tool supplied and rotate 90 degrees to a new face… when all 4 are used… just replace for a few dollars each.
This is a fairly powerful router bit and it is advised only to use it in some form of jig… such as the “Torque Workcentre or maybe on a router sled…
You probably see that this has been used… in fact it is the original bit I bought with the machine… just about ready to replace the tips.. after over 12 months…
It has a 1/2 shaft and due to the diameter of the cutter,ideally, should be used with a variable speed router… that said I had no problems with my Makita 3612 single speed … I have just up graded to the new variable speed Makita and if the client requires a router with the TWC I recommend and supply the new Makita Variable Speed…[made in Japan] I get a good price from my local Power Tool shop… Trademan's Toolbox in Morayfield.
Although any GOOD quality router… at least 2 HP or more if possible…..would be suitable.
These bits are available from Carb-i-tool in Melbourne, Australia and Torque supplies the cutters as an option with the TWC at a discount.
If you follow the link and watch the last video on the TWC page there is a close up at around the 1 minute mark.
6 comments so far
View SASmith               's profile
SASmith
1850 posts in 2889 days
#1 posted 10-15-2010 11:07 PM
Thanks Larry
I saw a pic of this the other day on the TWC website and thought it would be great for surfacing my cutting boards before they go to the sander. I was going to drop you a line and see where you can get these from but I guess purplev beat me to it. Now to find out if they ship to the states. Here is a link to the exact page in the cab-i-tool catalog for this bit http://www.carbitool.com.au/pdf%27s/PageR039.pdf for others who want to see the specs.
Scott
-- Scott Smith, Southern Illinois
TopamaxSurvivor
18188 posts in 3578 days
#2 posted 10-16-2010 03:01 AM
Lookin good, wish I had room for that :-)
View BigTiny's profile
BigTiny
1676 posts in 2790 days
#3 posted 10-16-2010 11:25 AM
Now for the question on everyone’s lips but that nobody is crass enough to ask, so I will…
How much? (holding my breath.)
-- The nicer the nice, the higher the price!
View degoose's profile
degoose
7227 posts in 3256 days
#4 posted 10-16-2010 12:02 PM
The Cutter retails for about AU$180.00 but when you buy the TWC… only AU$150.00 as an optional extra…
With the Aussie dollar SO strong…. it works out about the same…. in US dollars.
View PurpLev's profile
PurpLev
8534 posts in 3550 days
#5 posted 10-16-2010 10:47 PM
Thanks Mate!
This looks like a a great cutterhead to safely (welll, compared to a planer that is) surface end grain cutting boards and similar applications.
degoose
#6 posted 10-16-2010 11:29 PM
Also great for flattening table tops, benchess and slabs… the arm can be swung out the back of the machine for work that won’t fit on the bench top..
