For the last few days at the end of last year ….LOL…I was very busy… I was designing a recessed base for my Lazy Larrys..I have just taken the time to post this….To start I have cut a circle of 5/8” plywood to mount the bearing.. this is roughly 300 mm or 12” in diameter as seen to the left in the first pic.
This is accomplished by using the router to drill a hole in the centre.. the same size as the pin in the table. The hole is dropped over the pin and the router moved to the correct distance from the pin and x and y axis locked… turn on router and using plunge lever and lock lower cutter into the plywood…the plywood is then turned [ increasing the depth on completion of each turn] until the cirlce is cut..
... and using the Torque work centre I am cutting a ring from the same timber as I have made the top of the Lazy Larry.. this is also shown on the video of the TWC
the router is then moved on the y axis [towards the pin] by the thickness of the cutter. This virtually changes the cutter to the other side of the line..the process is then repeated with the timber ….remove waste and then insert and glue the ply inside the round hole…..cutting the waste from the centre gives you a round piece that can move be made into a round cutting board...
but here is the kicker… I make the ring slightly thicker at just under 1” and when I sand it there is enough left proud to hide the steel bearing from side view..
Now replace the blank on the pin and move the router to the desired diameter and lock the Y axis [X axis has remained locked.. BTW it is in line with the pin.]
This one is Queensland Rosewood.. and is for this amazing top….
I kinda got carried away and made Eight of these bases.. 7 in Camphor Laurel.
After cutting the outer circle..
,Sand and chamfer the edges.
This is a shot of the bases underneath with a coat of wipe on poly…
A glimpse of the tops to 7 lazy larrys… first of a few coats of clear….also cut on the TWC
Lots of fun and a quick and accurate project… made possible due to the Wee Beastie… LOL
-- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber...
20 comments so far
matt garcia
home | projects | blog
1739 posts in 1868 days
#1 posted 1258 days ago
Man that is some pretty wood!!
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
12166 posts in 1537 days
#2 posted 1258 days ago
larry ,
looking real nice ,
bringing pro ,
to the ,
fessional !
well done .
woodworm
14105 posts in 1787 days
#3 posted 1258 days ago
What the toy can do is amazing (considering the accuracy & ease of set-up).
..and that beautiful wood, make me liking my lips…!
-- masrol, kuala lumpur, MY.
Splinterman
23056 posts in 1558 days
#4 posted 1258 days ago
Hey Larry,
Sweet job mate.
hootr
183 posts in 1543 days
#5 posted 1258 days ago
great as usual larry
-- Ron, Missouri
hooky
355 posts in 1515 days
#6 posted 1258 days ago
larry you getting the hang of that new beastie
you have done a wonderful job on these
Hooky (the new scrounger, i want free wood)
-- Happiness is a way of travel , not a destination (Roy Goodman)
Sawdust2
1467 posts in 2284 days
#7 posted 1258 days ago
We’re not seeing Larry’s real mastery.
His real mastery is selling all of these neat things he makes.
ellen35
2453 posts in 1629 days
#8 posted 1258 days ago
Very nice.
Ellen
10635 posts in 2443 days
#9 posted 1258 days ago
Wow Larry, you got it made. Here all this time I’ve pictured you up all night slaving away making these and other things, and come to find out you got a machine that does all the work for you..lol. they are Beautiful though even if they don’t have a lot of blood ,sweat and fingertips in it.. LOL
joebazooka
113 posts in 1380 days
#10 posted 1258 days ago
Larry you did it again, why didn’t I think of that when I made my blue wooded susan. I am truly astonished! way to go brother!!
-- Robert-maine
janice
1029 posts in 1621 days
#11 posted 1258 days ago
You make it look so simple. They are beautiful!
-- Janice
Charles Maxwell
828 posts in 2003 days
#12 posted 1258 days ago
Goose, Nice work! No lazy susan in that shop.
-- Max the "night janitor" at www.hardwoodclocks.com
blackcherry
2949 posts in 2019 days
#13 posted 1258 days ago
Great work Larry, your Queensland Rosewood is quit spectacular eye candy for the woodworker soul.
rseabrease
55 posts in 1287 days
#14 posted 1258 days ago
Larry,
I have recently received a complaint from the Queensland Rosewood and Laurel Wood Beaver Association (QRLWBA) about some missing wood. Your name kept popping up in the investigation – any thoughts on this subject?
Really great work on this project.
-- Richard
34396 posts in 2597 days
#15 posted 1258 days ago
Larry: A quick question Why would the bearing mounted in a recess, not be as effective as cutting a larger circle for plywood and the bearing. Is that to eliminate any cupping or bowing in the timbers?
Some beautiful wood and boards.
View all comments »
