Hi guys ,, I had a request to make a tutorial with regards the endgrain Tumbling Block Design.
First off,.., You need to decide the size of the blocks…. for this example I used 1” stock… Or something similar.. actually just over .. once dressed.
Set the blade of the table saw to 60 degrees.. a bevel box makes this simple
I use the INCRA fence system so it is easy to rip bevels off side of the blade.
Once the bevels are ripped measure the length of the bevel and move the fence that distance plus the kerf and 1mm [ 1/25 “] for the variation of the kerf due to the angle. For my diamonds, the fence was moved 1 9/16 ” to cut 1 13/16” Bevel rip again. Do this for all three timbers.. I did it twice for all three…
I glue all three different timber diamonds together and clamp.[ ensure the grains of all three are perpendicular to each other..].
then cut to the required depth/ length and then glue up.
.With different size stock.
Any questions PM me.
28 comments so far
hooky
home | projects | blog
133 posts in 211 days
posted 102 days ago
Hi Larry this was very informative
all I need now to do this is
The wood
A Saw that tilts
A bevel Box
an incra fence system
yeah i think that just about covers it
Hey maybe you just want to ship me yours
Thanks
Hooky
-- Happiness is a way of travel , not a destination (Roy Goodman)
degoose
1981 posts in 247 days
posted 102 days ago
So you do have the clamps and the glue.!!
hooky
posted 102 days ago
sure do all good workshops have those
Russel
2057 posts in 832 days
posted 102 days ago
Thanks for the instruction. It’s people like you who get me started using jigs and seeing things in a particular way and the next thing I’m on the road to making pretty stuff.
poochie
3 posts in 131 days
posted 102 days ago
thanks i always wanted to make something like this. thanks very much for the article will give it a try
ellen35
531 posts in 325 days
posted 102 days ago
You are so clever!!!!
I have been hoping you’d post this!
It is on my “to do in the next month” list already!
Thank you Larry.
Ellen
-- Ellen on Cape Cod
moshel
471 posts in 576 days
posted 102 days ago
I know this sounds strange, but I just made one today! (well, I saw your prototype in one of the earlier posts).
I don’t have neither the bevel box nor the incra, so i’ll give my 2c:
to set the blade to 30/60 degrees (depends if you look at the half full or half empty), i cut a block on my mitre saw 30 degrees. as the mitre saw is pretty accurate and you can cut a 2×4, you get pretty good reference.
I did the math beforehand. first, the first cut to remove the end of the board (my blade also tilt toward the fence, so this is a tricky cut). now, measure the length of the beveled cut. the fence should be 1.5 times this length from the base of the blade. it pays to mill an additional piece of pine scrap to test that your piece is good (all sides should be equal).
-- The woods are lovely, dark and deep, but I have promises to keep...
7299 posts in 1139 days
posted 102 days ago
You glue a to tab b then b then glue what at 90 degree centegrade, whats a milimeter. Hey I’m lost, will you repeat that. Ah, nevermind.
-- Mike. mwurm13@yahoo.com
sIKE
1094 posts in 647 days
posted 102 days ago
Thanks Larry! That is what I as looking for, nice to get up and see something like this…
blackcherry
730 posts in 716 days
posted 102 days ago
I wish you would of posted this last week toucans. Your way is a whole lot easier thank for sharing with the crew. Blkcherry
eddy
281 posts in 257 days
posted 102 days ago
that beats gluing 1 piece at a time. thats how i was doing it
will make some more this way looks a lot easer
thanks a lot
degoose
posted 102 days ago
Nice to see you have crossed over to the dark side, lol
HokieMojo
1140 posts in 621 days
posted 102 days ago
that looks too easy. are you messing with us? Just kidding. I know getting a good tight fit is tougher than it looks. nice work!
majeagle1
426 posts in 389 days
posted 102 days ago
Thanks alot Larry, this was a big help…............ now I may actually get down to business and make one!!!
-- Gene, Majestic Eagle Woodworks, http://majesticeagleww.etsy.com/, http://www.flickr.com/photos/majesticeagle/
Don Newton
528 posts in 511 days
posted 102 days ago
Awesome, it don’t get no better than that. Seems like a great project for a diversion.
-- Don, Pittsburgh
DAN
6438 posts in 875 days
posted 102 days ago
not bad for a lumberbud ! thanks for posting … looks like fun
moshel
posted 101 days ago
Three more tips :
1. make sure you can cut the “hexagonal sausage” using your mitre saw or crosscut sled in one pass. its very hard to get accurate results when cutting in two passes. believe me…
2. it pays to pass the “hexagonal sausage” through thicknesser. just light pass to level everything. you need to repeat the pass on 3 sides (its best to number them, its very confusing), lower just a bit and repeat on the other 3 sides.
3. leave enough milled “diamond” lumber unglued, so you can complete the pattern nicely
woodsmithshop
288 posts in 438 days
posted 100 days ago
Larry, now that you have everyone on here making boards, the next thing will be to rename this site to “Board Jocks” or ” Lazy Larry Jocks” lol
-- Smitty!!!
SteveM
76 posts in 1060 days
posted 98 days ago
Larry, Thanks for once again sharing your remarkable skills with instructions that we of much lesser skills can understand. I continue to be amazed.
16611 posts in 470 days
posted 98 days ago
Hey Larry
You always amaze me with you ingenious and innovative work. Thanks for sharing all of your great work.
stefang
1644 posts in 227 days
posted 88 days ago
Great tutorial Larry. Thanks for sharing this. I plan to give it a go sometime. I have been doing something similar for many years called stick work (small scale stuff). The only real difference is that the diamonds are cross-cuts, so that the long glue joints are end grain. These are made into geo patterns and then sliced off to be used as inlays with the long at the end showing. They can be turned on a lathe for disk shaped inlays or just left with pointy ends. A bad photo example of it can be seen on ‘A Gimmicky turning’ on my projects page.
-- Mike, American in Norway
ken90712
334 posts in 81 days
posted 81 days ago
Very well done! I have been wondering on how the 3D effect was pulled off! New to the site and I must say it is a pleasure to read about the tips and see the projects of so many fine woodworkers!
coloradoclimber
448 posts in 960 days
posted 81 days ago
That is really cool !! thanks for taking the time to post. Having the walk through really helps and makes it look pretty straight forward.
Sitting here in front of the computer doing a mental walk through I’m still not clear on the following:
“Once the bevels are ripped measure the length of the bevel and move the fence that distance plus the kerf and 1mm [ 1/25] for the variation of the kerf due to the angle. For my diamonds, the fence was moved 1 9/16 to cut 1 13/16. Bevel rip again.”
A 60 degree blade angle is 30 degrees off of 90. 1 inch thick stock cut at 30 degrees should yield a bevel length of around 1 5/32 inch. I didn’t actually cut a piece of wood, just sitting here at the computer I drew a triangle, 1 inch tall on the vertical side, an angle 30 degrees off of vertical, and I get the angled side (the bevel) around 1 5/32. Not even close to 1 9/16 bevel. I’ll have to cut a piece and see what I get.
But let’s say I did have a bevel of 1 9/16. If the bevel is 1 9/16 I want the horizontal side, the side down on the table saw to also be 1 9/16. So I move the fence out 1 9/16 + the kerf width (1/8 or 2/16) + 1 mm. 1 mm is mostly 1/25 of an inch, lets say close to 1/32 for now. That ought to add up to 1 9/16 + 1/8 + 1/32 or 1 23/32. Still short of 1 13/16.
And I’m wondering if your numbers are transposed, did you mean to say you would move the fence 1 13/16 to get a cut of 1 9/16 ?
I’m sure if I cut some myself the numbers would fall into place. Just trying to do a mental walk through and I’m not able to get your numbers.
Thanks again for the post.
degoose
posted 81 days ago
Just a transposition of the numbers..And the stock was around the 1” mark.. not exact.
mmh
1381 posts in 615 days
posted 80 days ago
Gee, it looks easy when YOU do it! Nice job.
sIKE
posted 60 days ago
Larry,
How long do you make your blanks? Just trying to get an idea of how much wood to buy.
notottoman
449 posts in 123 days
posted 59 days ago
Thank you for the tuition.
So much to learn….....
-- "Even small steps makes a distance." (Shawn Phillips, musician)
scrabby
8 posts in 79 days
posted 59 days ago
Awesome Mate – just joined the site as a relatively new hobbyist woodworker who wanted to make a few cutting boards as xmas gifts, and you’ve inspired and amazed me with your work.
Thanks.
-- Jim, North Vancouver, BC
