Prototypes #6: Is that your natural color?
Blog entry by darryl posted 49 days ago 284 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 5: To Dye For Part 6 of Prototypes series no next part
well here it is, my first attempt at a dye job.
As you can see, the dying process mostly worked, but not 100%. I’m not really sure I like the color selection anyway, but it would have been better if each piece of dyed maple had dyed completely. I wonder now if using a pressure pot is the only way to ensure that each piece gets 100% color saturation… time and testing will tell I suppose.
here’s a detail shot of the piece.
Any feedback, suggestions & insights would be greatly appreciated.
-- www.darrylmasterson.com ~ www.darrylmasterson.etsy.com
5 comments so far
View dustbunny's profile
dustbunny
315 posts in 188 days
posted 48 days ago
Almost…I think you might be onto something with the pressure pot. I’m not so sure about using alcohol under pressure….be careful.
This stopper is still cool even though I think we had all imagined the stain different.
Nice work, Keep trying…
Lisa
-- I inherited the woodworking gene and it's gone into overdrive.......
View Sawdust2's profile
Sawdust2
1183 posts in 980 days
posted 48 days ago
There were recent posts about using a vacuum system to stabilize wood.
Your might try that, also. Put the wood in a container with the dye solution and that container inside a larger jar, such as a pickkle jar.
If it will work with absorbing acrylic it should work with a dye solution.
Just a thought.
I like to turn bottle stoppers so I’ve been following your posts.
View stefang's profile
stefang
1644 posts in 227 days
posted 48 days ago
It isn’t too bad Darryl. I think what you are experimenting with is very interesting. I have a hard time getting exotics with different colors, so a good way to dye wood all the way through would be a great benefit to me. I hope you will keep us informed on this topic. Thanks very much for posting this blog. I liked the stopper by the way. Nice shape and nicely done.
-- Mike, American in Norway
View matt garcia's profile
matt garcia
716 posts in 565 days
posted 48 days ago
Cool!!
-- Matt, Houston Texas
View Napaman's profile
Napaman
3482 posts in 970 days
posted 47 days ago
good start…
