So it’s been a long time since my last post, had a bit of down time where I went on vacation and did odds and ends but I’d been making slow and steady progress on the top.
I can’t believe how much trouble I had gluing a bunch of sticks together :) All my issues stemmed from the fact that I didn’t have a good way of surfacing such long pieces. My 6” jointer just wasn’t up to the task so I faffed around trying to do it other ways. I eventually used a huge 9 foot straight edge clamp thing that I use for cutting ply to run the strips through my table saw which got me one reference edge, then I glued a bunch up and used a router on a sled (the white piece of melamine in the background is the sled) to flatten the resulting slab.
Anyway, here’s the top, it’s still in two pieces here, just getting ready for the final glue up but you get the idea.
So I have to glue the two halves together, trim the ends and then complete the joinery for the base, but I now feel as though there is light at the end of the tunnel :)
I also have to trim my short stretchers a bit because the depth of the top is about 3/4” less than I’d originally planned.
17 comments so far
PurpLev
home | projects | blog
2675 posts in 527 days
posted 438 days ago
Nice looking top – what kind of lumber is the top made of?
ChicoWoodnut
894 posts in 694 days
posted 438 days ago
This rocks!. I went back through all of your posts. This thing will turn out really nice in the end. I’m glad to see that I’m not the only one with “odds and ends” that interfere with my shop time.
Keep us posted. I’ll be following.
Damian Penney
1022 posts in 870 days
posted 438 days ago
It’s maple and walnut; I’ve done a couple of pieces with maple as an accent to walnut and I really like the combo.
PurpLev
posted 438 days ago
Damian: the Maple/Walnut combo works really well…. I just made a note for my future bench materials! thanx for sharing, will keep checking your progress on this!
what are you planning to do with bench holes? round type?
Damian Penney
posted 438 days ago
Yeah, going with the round bench holes and I have the Veritas twin screw vise for the front and the big steel one that Chris Schwarz used in his version for the end.
Thanks Scott, glad you like it :)
Douglas Bordner
3415 posts in 943 days
posted 438 days ago
S-T-A-B-L-I-T-Y. This looks like the Rock of Gibraltar.
Chris
1456 posts in 870 days
posted 438 days ago
Really nice work there Damian. Where did you get the circular saw guide that you used as a straight edge? I was thinking I could use a long carpenters level for the same purpose.
-- Chris
Damian Penney
posted 438 days ago
Chris, it’s a TruGrip Pro, and I got it a while back from Amazon, not sure they still make them, love mine though.
Hey Doug, yeah it’s gonna be quite the beast :) Need to think real carefully about where to put it because moving it around will be far from trivial :)
Beginningwoodworker
3857 posts in 552 days
posted 437 days ago
Nice work Damian.
-- CJIII Future cabinetmaker
steveosshop
208 posts in 505 days
posted 437 days ago
I like the maple walnut combo on the top. Great looking top!!
-- Steve-o
teenagewoodworker
2470 posts in 647 days
posted 437 days ago
looking great! i really like the accent walnut! looks great on the top.
Mark Shymanski
1549 posts in 591 days
posted 437 days ago
Great combo of walnut and maple. When you talked of the difficulty squaring the sides I thought of the shipbuilders trick when they just placed the two boards to be joined together and sawed through the two touching sides…the sides may not have been planar or even square but they’d mate with each other so the join would be very tight. Then I noticed that you had the walnut accent board and I understood why the shipbuilder’s trick would not work for this application. Great blog!
bfd
413 posts in 686 days
posted 437 days ago
Sweet Damian! wasn’t expecting the walnut accent … love it. Keep up the fantastic work man!
-- Brian, Folsom, CA http://www.brianfullerdesigns.com
martin007
108 posts in 654 days
posted 410 days ago
Very nice top Damian! I will stay tuned
-- Martin, Gatineau, Québec
Mark Briley
7 posts in 132 days
posted 118 days ago
Great looking bench. I’m building one of these as well, but I’m having trouble getting 0 gaps in my laminations. Any tips on how to achieve this? Yours looks like it went pretty well.
-- Mark
Damian Penney
posted 118 days ago
It just takes lots and lots of clamps and perfectly flat faces, doesn’t matter if there is a bit of bow to the board because you can clamp that out of it, but make sure both faces are planed parallel to one another. Good luck :)
Also I glued it up one board at a time, I think it’s too hard to do multiples at once.
15600 posts in 456 days
posted 117 days ago
Go Damian go
