Quick and Easy Blade Changes on the AP1300 - Update
Blog entry by Damian Penney posted 547 days ago 225 reads 0 times favorited 11 comments Add to Favorites Watch
So on the advice of FlWoodRat I contacted Ryobi support about the seized blade bolts and they were kind enough to send me a new set of blades ($74 a pair) for my troubles :)
11 comments so far
teenagewoodworker
2482 posts in 667 days
posted 547 days ago
thats good but i think for all the troubles you went through they should have sent you a whole new helix cutter head or something of the sort ;)
View Tony Z's profile
Tony Z
173 posts in 689 days
posted 547 days ago
That’s funny cause I went through the same thing changing the blades on my 12 1/2” Delta a few months ago. Every Hex screw came out fine except one. I had to do everything you did. I even heated it with a torch. A slot cut into it and a large screwdriver finally did the trick. My quick blade change turned into a 2 hour project.
-- Tony, Ohio
View SPalm's profile
SPalm
951 posts in 781 days
posted 547 days ago
All’s well that ends well. (Not really but that is what they say, whoever ‘they’ are)
Back to the bench?
View Damian Penney's profile
Damian Penney
1030 posts in 890 days
posted 547 days ago
Bench? :) Yeah, I’m slowly but surely getting the top together and have started work on the base. My latest issue is that my table saw is a piece of junk. Trying to do the tenons with a tenon jig, starts off perfect, comes out off of perpendicular by a degree or two, turns out that my top is warped so the tenon jig changes angle wrt the blade.. I just got permission to get a new saw :-)
View Dorje's profile
Dorje
1767 posts in 895 days
posted 547 days ago
Did I hear someone say “new saw?”
Well, what’s it gonna be?
Damian Penney
posted 547 days ago
That’s a good question Dorje, time to do some research, my main requirement (other than it not being useless) is that it has a riving knife, thinking the Grizzly or possibly the Powermatic, have to figure out budget though…
Dorje
posted 547 days ago
So a cabinet saw, then?
Damian Penney
posted 546 days ago
Yes definitely a cabinet saw, cry once and all that :)
3710 posts in 878 days
posted 546 days ago
Hi Damien;
New saw time huh? It’s kind of hard to believe you’ve been turning out the quality of work you do with a “junk saw”
I’ve heard that some of the larger saw stop dealers take other brands of saws in trade, which they then resell at a discount to get rid of them.
Maybe it’s worth your time to try to find such a dealer.
You could end up with a great saw at a bargain price!
Good luck in your hunt.
SPalm
posted 546 days ago
WooHoo, new saw !!!! I have permission for a new one also, but I am too chicken to pick one. Keep me posted on your choices.
I cut the tenons for my bench legs by scoring the sholders on the TS and cutting the cheeks on the BS. From the very beginning of your build I was wondering how you were going to cut these, as they are so massive. I tried a tenon jig but my legs would cause it to tilt right out of the miter slot. I don’t have T slots.
Damian Penney
posted 546 days ago
Hey Lee, the table dips by the throat, for rips it’s fine because the dip is perpendicular to the blade, and I’ve always used my SCMS for crosscuts, using that combo I’ve gotten by. Also the dip is far more pronounced on the left side of the blade where the tenon jig rides and I’m usually to the right of the blade. Not quite junk, but I was pretty frustrated when a simple operation like cutting some tenon shoulders produced less than perfect results.
I’ll post a blog entry with some pics of my troubles.
Not sure any dealer would want my current saw, it’s quite the oddball :)
Steve, my plan had been to use the bandsaw but I wanted to try and leverage the larger table on my TS, time to go back to plan A. I’m thinking the Grizzly G0651 fits the bill at the moment. Trying to keep in the $1500-$2000 range and open to getting a used one.
