Quick and Easy Blade Changes on the AP1300... (perhaps in bizaro world)
Blog entry by Damian Penney posted 549 days ago 1774 reads 1 time favorited 24 comments Add to Favorites Watch
In this blog entry I’m going to demonstrate how easy it is to change blades on the Ryobi AP1300 Planer.
A quick read of the manual will tell you that all you need to do is remove the cover, lock the cutterhead in place by rotating it and then remove the screws with the included hex key. Sounds simple right…
Well here I shall demonstrate the actual process.
Step One, strip the included hex key on any screw you choose, grind it down with a grinder, try again, strip it again.
Curse. Throw tool in trash.
Step Two.
Find a higher quality hex key (metric 4mm).
Repeat step one.
Curse.
Step Three
Grind a slot in the top of the hex screw.
Destroy the the biggest screwdriver you own trying to unseat the hex nut.
Ponder whether or not the hex nuts have been welded by a prankster..
Curse.
Step Four
Purchase a Bosch PS40 Impact Driver
Smile
Step Five
Shatter the flat head screw bit that comes with your brand new PS40.
Curse.
Step Six
Grind the bit down and try again…
Quick and Easy Blade Changing Ryobi AP1300 Planer from damian penney on Vimeo.
Smile a little at how awesome the PS40 actually is :-)
Curse for old times sake.
Step Seven
Grind and remove the other nine screws and you can be done in as little as two days depending on your Amazon shipping choices.
I hope this little guide has been informative, I’m in talks with Ryobi to update their manual.
24 comments so far
teenagewoodworker
2479 posts in 660 days
posted 549 days ago
now that is a really quick and effective blade change! lol! thanks for the post.
View kem's profile
kem
56 posts in 610 days
posted 549 days ago
That’s crazy, Damian! BTW, awesome picture of you grinding the slot in the hex screw. How’d you do both at the same time (taking the pic and grinding).
-- Kevin
View Damian Penney's profile
Damian Penney
1030 posts in 883 days
posted 549 days ago
I know, absolutely ridiculous. I did the grinder pic with a ten second timer, and the camera propped up on a block of wood.
View GaryK's profile
GaryK
9518 posts in 880 days
posted 549 days ago
Nice little new tool you got there! Great little video.
View Dorje's profile
Dorje
1768 posts in 888 days
posted 549 days ago
Pretty funny…and painful. But, all is well that ends well.
Did you lube those buggers with anything?
Are the knives, at least “quick-set,” (i.e., did they have pins to align them?) or are you going to have to break out some of your mad knife setting skills...
What is it with you and Allen wrenches? Love/Hate, eh?
View Napaman's profile
Napaman
3482 posts in 968 days
posted 549 days ago
wow that sucks…and to think—-we go into the shop to RELAX…sometimes at least…may your next two days in the shop be spent enjoying every moment…actually two straight frustrating days should equal about 20 ugly ones…
View Sawdust2's profile
Sawdust2
1181 posts in 979 days
posted 549 days ago
In for a penny, in for a pounding.
Damian Penney
posted 549 days ago
The knives are quick set Dorje, and they were reversible, I doused it with WD40 many a time before going this route. This is a common problem with these planers.
View bbqking's profile
bbqking
332 posts in 615 days
posted 548 days ago
I finally got mine loose with a with a high dollar machinists grade allen wrench and, believe it or not, an 18” cheater bar made from 3/8 inch pipe. By the way, I had to buy the allen wrench as a set. Go figure. bbqKing
-- bbqKing, Lawrenceville
Napaman
posted 548 days ago
THANKS DAMIAN…as I read and wrote my comments yesterday about your frsutrations I was literally itching to get home and into my garage to open up three huge boxes I had just received—-my new (used) shopsmith pro planer…well today I got home early enough to tear open the boxes and start putting my big purcahse together…
Each time I ran into trouble i thought: “ok…this aint nothin’.....damian struggled with one screw for two days and persevered…I can put table legs together!!!”
Well…the stand is complete…the planer is mounted…all ready to go…then I hear the one of the worst things a wood worker can hear—-”DINNER!” (well of course there are many worse things)...this is not a bad thing to hear…but just when I was ready to get to the next set of directions and maybe turn the thing on…I had to quit for the night…
Probably a very good thing since I still havent gotten this far in the manual…
Thanks for this story…you kept me going at times while i was laying on my back trying to turn a screw sneazing dust…
View fredf's profile
fredf
319 posts in 601 days
posted 547 days ago
I wonder how hex bits would work with the PS40. I managed to remove a water pump one time WITHOUT breaking any screws by using an impact wrench, the impact seems to loosen them without over torquing them
To prevent problems next time invest in a nice big jar of antiseize. That stuff goes on EVERYTHING, and worth every cent too
talk Ryobi into using torx; much less likely to strip than an allan, though much more expensive
-- Fred, Springfield, Ma
View wouldi's profile
wouldi
22 posts in 559 days
posted 547 days ago
yeah so about torx …. when i was putting together my bench …. pics are on my site….. anyway i decided that i should use torx head screws cuz there tuf righttttt. so just about 17 bits and screws later i decided to that all things made in china that are sold at a HARDWARE store should be hard….. well im thinking just based on my experience and your own that there must be some lead slipping into our driver bits …. good luck
-- to the endeavor
View Jimboe's profile
Jimboe
81 posts in 641 days
posted 547 days ago
damian
You dont know how funny this is . I have the same planer and tried taking the blades out this past monday .I got all the screws out but one the allen screw rounded out so i plulled out the dremel and cut my slot thought i was going to strip the head again .Well i got it off and all is good . Just thought it was funny that i just went thru the same thing 3 days ago .
Damian Penney
posted 547 days ago
Hey Fred, I’m sure a hex bit in the PS40 would have worked just fine but I couldn’t find one (4mm) that didn’t come in a kit with a gazillion pieces. I’d take Torx or Square over an allen head any day of the week.
That’s funny Matt :) I should put one of those inspiration posters together :)
View FlWoodRat's profile
FlWoodRat
581 posts in 800 days
posted 545 days ago
Just wondering, did you send a copy of a link of your video to your friends at Ryobi? Their customer service department may send you a new unit, perhaps the dewal 735 for your troubles
-- I love the smell of sawdust in the morning....
Damian Penney
posted 545 days ago
That’s a great idea, I’ll do that.
View Yettiman's profile
Yettiman
153 posts in 629 days
posted 544 days ago
Thanks for a good laugh at 5:00 am in the morn. Glad it worked out ok in the end,
Take care
-- Keep your tools sharp, your mind sharper and the coffee hot
View matt garcia's profile
matt garcia
716 posts in 563 days
posted 536 days ago
You know I worked on cars for 12 years, and this is the kind of thing that I always feared. It seems things like this only happen when you have a few days to try and accomplish something, then chaos strikes!! This is the prime reason I don’t work on the car on Sundays anymore. I own a Delta 13” planer, and the blade change on mine went smoothly, much to my bad luck. I had a similar problem with my Delta hollow chisel mortiser. It seems the plunge arm is attached to the gear mechanism with a roll pin. Well the roll pin cracked in half, and I couldn’t find one at Home Depot(it is a metric roll pin). So I bought a bolt, and a nut, and put it in there, and finished mortising. The next day I called Delta to order a roll pin, and a new arbor (had to partially drill the old roll pin out. Well they were backordered for 5 months, and I just got it a few weeks ago. They brilliant guys at Delta redesigned the roll pin so that it isn’t hollow anymore, thus it won’t crush and collapse anymore, and I am now back in business. I wonder what tomorrow will bring???
-- Matt, Houston Texas
View ferstler's profile
ferstler
138 posts in 412 days
posted 412 days ago
After reading some of the nightmare comments about removing blades from the AP1300 and watching the video that showed a very desperate procedure, to say the least, I decided to remove and reinstall mine as a preliminary operation before they got so worn that I would be in serious straights in the middle of a project down the line.
Rather than use the supplied Ryobi wrench, or even a standard L-shaped allen wrench, I installed a premium 4 mm allen tip in my impact wrench and proceded to VERY easily remove each screw that way. An impact wrench basically jars the screws loose and does so before the head or tip can deform. I also pulled each blade and cleaned it and also cleaned the mounting bosses and clamps (acetone did the trick) and then reinstalled everything. The allen screws were absolutely pristine after this operation.
My only beef against the planer, which has worked very well so far, is the cost of replacement blades. The price is considerably more than replacement blades for the more expensive Ridgid TP1300 planer, which I find peculiar. Ryobi stuff is supposed to be reasonably priced. The Ridgid blades are also heftier and obviously cost more to make. However, the Ryobi blades still cost more.
Ryobi should be ashamed.
Howard Ferstler
ferstler
posted 408 days ago
I phoned Ryobi today to get a price for a pair of AP1300 blades and the quote was $41, which is even higher than it had been before. Given that I have seen blades for the more expensive Ridgid TP1300 planer on sale at HD for $29, I think that Ryobi should remain ashamed. Interestingly, I recently saw single-blade (not double-blade) packs for Delta 12.5-inch planers on sale at HD for $25 each. Can they get that much for those suckers?
Howard Ferstler
View archie18's profile
archie18
48 posts in 381 days
posted 381 days ago
Sounds like my experience. After grinding off the screw heads so I could remove the blade holder, I had to drill out most of the screws. I replaced all the screws with stainless steel hex head bolts which are much easier to remove.
-- Robert in middle TN
archie18
posted 381 days ago
Replacement blades are available cheaper at HomeDepot online
View Rxmpo's profile
Rxmpo
119 posts in 637 days
posted 290 days ago
Type in the search box on the HD website 6660664 and you will get the replacement blades. Just got my set in the mail today. $19.91 +free shipping. Good luck.
View dnco's profile
dnco
1 post in 180 days
posted 180 days ago
I thought I would have all your problems and things were really tight so I used some WD40, sprayed, prayed, and waited a few minutes. The siupplied wrench worked just fine and I was able to change the blades without stripping anything and I didn’t even have to buy new blades because the blades on the machine are double edged so I just reversed them.
Thanks…
Manuel
