Operation Holtzapffel #8: Building the top
Blog entry by Damian Penney posted 564 days ago 378 reads 0 times favorited 12 comments Add to Favorites Watch
« Part 7: Slow Going Part 8 of Operation Holtzapffel series Part 9: Base almost done »
This post is just to share some top building pics
I’m using a 9’ straight edge to joint the boards for the top. I usually use this for cutting sheet goods to size as I have a jig that locks a circular saw to it but it’s come in real handy for handling these long pieces.
Here you can see how big and unwieldly the straight edge is, as well as my super high end Taiwanese saw…
The blade is a new 12” Freud combo blade, doesn’t leave an edge like my Woodworker II that usually lives on the saw but it gets it smooth enough whereby I can finish off on the jointer.
Slowly but surely…. :)
12 comments so far
View Mike Lingenfelter's profile
Mike Lingenfelter
458 posts in 1008 days
posted 564 days ago
Looking good. The top seemed to take the most work for me. It was a lot of ripping and gluing. I felt good when it was all done :).
-- http://theinquisitivewoodworker.com/
View GaryK's profile
GaryK
9521 posts in 882 days
posted 564 days ago
I remember building the top on mine. Little by little!
View gizmodyne's profile
gizmodyne
1674 posts in 984 days
posted 564 days ago
I just worked with a neighbor and we chose a first coat of the Washcoat and Minwax Mahogany gel stain and a second coat of General Finishes Java gel stain.
Note that we also carefully sanded from 80 – 220 grit. In between coats we vacuumed or blew off the dust. Before the stain we tack clothed.
How did you prep the wood?
View Chris 's profile
Chris
1469 posts in 885 days
posted 564 days ago
12” Blade??? What kind of saw is that?
BTW, I have enjoyed watching you build this bench. I am planning on the same style and have learned a lot so far.
-- Chris
View Damian Penney's profile
Damian Penney
1030 posts in 885 days
posted 564 days ago
I got the saw when I first started woodworking from some guy on Craigslist. Had I known then what I know now I probably never would have bought it but it’s worked out pretty well all in all.
It’s some oddball import from Taiwan. The top is all cast iron, and it came with a Vega fence on it, there is another extension wing for the left hand-side that’s also cast iron that I recently removed for better access. Cost me about $300 I think, and the shop-built rolling base came with it.
It takes two hands to raise the blade or change the angle, the arbor has a bunch of run-out that I counteract with a Veritas blade straightening thing (it’s like a stabilizer plate with setscrews to push the blade a smidge) and the top isn’t exactly flat.. But apart from that it’s great! It also takes a 12” blade but has a 5/8 arbor, suffice to say it has lots of character :)
View Dorje's profile
Dorje
1767 posts in 891 days
posted 564 days ago
Here comes the top!!! Looks like a lot of work!
Is John in the right post – or is he just losing it? You didn’t dare ask him how you should stain (aaaghh!!) the bench did you? No smileys needed…or would that be smilies?
Douglas Bordner
3421 posts in 958 days
posted 564 days ago
Damian, you are a master. Sepia duotone project posts. Dude…
Todd A. Clippinger
5639 posts in 993 days
posted 563 days ago
It’s great following this journey!
Damian Penney
posted 563 days ago
Stain it? You crazy Dorje? I’m going the traditional route whereby I paint it and then followup with a few coats of poly.
Glad you like the sepia Doug, figured I’d play around with some camera settings I never get to use :)
View johnjoiner's profile
johnjoiner
153 posts in 787 days
posted 563 days ago
Thanks for the post Damian.
That top looks like tough work. How long are you making yours?
After you paint and poly that, breaking it in will be some work too. I’m guessing Dorje might be willing to drive down and help put some gouges in it for you. ;-)
-- johnjoiner
Dorje
posted 562 days ago
I can do that! (break it in!) – Paint and poly? Are you crazy Damien? You should go the more conventional route and wrap it in stainless steel…or you could tack a sheet of plywood on top to protect the good wood…
View Kipster's profile
Kipster
1072 posts in 647 days
posted 560 days ago
Great start on the top, step by step ans then it’s done.
-- Kip Northern Illinois ( If you don't know where your goin any road will take you there) George Harrison
