Thorsen Table #3: Parts
Blog entry by cheller posted 04-07-2007 06:49 AM 1045 reads 0 times favorited 10 comments Add to Favorites Watch
« Part 2: Early progress Part 3 of Thorsen Table series Part 4: Down to the Wire »
As I mentioned last night, I’ve got most of the parts roughed out for my version of the Thorsen table. I’m using cherry and walnut for the table.
The cherry parts – stretchers, breadboard ends (there’s an extra one pictured), legs and aprons (still need to be cut to length).
The walnut parts - the table top and the shelf. The shelf has been glued and is drying now.
The parts for the top - walnut field with cherry breadboards.
-- Chelle http://artsgranddaughter.blogspot.com
10 comments so far
18615 posts in 4161 days
#1 posted 04-07-2007 11:40 AM
how exciting.
this is going to be beautiful!
35121 posts in 4401 days
#2 posted 04-07-2007 04:31 PM
Great looking PARTS.
View Ethan Sincox's profile
Ethan Sincox
767 posts in 4174 days
#3 posted 04-07-2007 08:10 PM
Mmmm… it looks like you’re getting ready to put breadboard ends on the long grain of your top. Is that an accurate assumption?
If so, you might want to consider changing your layout by 90 degrees. The purpose of the breadboard ends is much more than decoration – they are used to prevent wider tops from cupping. To be effective in that purpose, they need to be laid out to cover the end grain of your top.
In fact, if you were to tenon the long grain edges and attach the bread boards to those sides, they could quite easily snap off, as you’ll have very little shearing strength in your tenons.
Just thought I’d pass along the observation.
(If you were just laying out the wood for all to see, then never mind.)
-- Ethan, http://thekiltedwoodworker.com
dennis mitchell
3994 posts in 4315 days
#4 posted 04-07-2007 08:13 PM
Cherry and walnut make a great combo!
#5 posted 04-07-2007 11:03 PM
regardless, Ethan, I appreciate the information sharing!
View cheller's profile
cheller
254 posts in 4110 days
#6 posted 04-07-2007 11:46 PM
The orientation of the breadboards was just for the picture. I wanted to show the contrast between the two woods, and didn’t really pay attention to the orientation.
#7 posted 04-07-2007 11:55 PM
Good recovery. Don’t let anyone think otherwise.
Ethan Sincox
#8 posted 04-08-2007 06:12 AM
Then never mind! Just wanted to make sure.
Can’t wait to see the future progress.
View woodchips's profile
woodchips
238 posts in 3965 days
#9 posted 07-20-2007 06:38 AM
That is going to be a very nice contrast in color. What finish did you say you were going to use?
-- "Repetition is a leading cause of carelessness, and carelessness usually leads to injury"
cheller
#10 posted 07-20-2007 06:18 PM
The table was finished in May. I used a gel stain on the walnut, then covered everything with an amber shellac.
You can see the final result here.
