Softball Bat #1: New Tool Skills
Blog entry by cheller posted 10-08-2007 02:19 AM 3650 reads 0 times favorited 2 comments Add to Favorites Watch
no previous part Part 1 of Softball Bat series Part 2: The Bats are Done »
Up until this summer I had never used a lathe, and that was okay. I’ve been able to do what I wanted without it. Then last spring the guys in the adult ed class I take, including the instructor, got interested in making baseball bats. I don’t know what started it but soon fully half the class was working on creating bats. At the time I was busy with other things.
I spent most of the summer session working on other projects, primarily an advent calendar for my nephew. With one more class left I realized that I had completed all the work I wanted to do in class on the advent calendar. So, I decided to join the club and make my own bat. Since I play softball, it would be a softball bat, not a baseball bat. (Primary difference between the two is the barrel diameter – softball bat barrels are narrower.
First step was to cut a couple of blanks from a slab of ash. I ended up with two blanks about 3 1/2 inches square and 36” long. The corners of the long edges were cut off at a 45 degree angle on the table saw leaving a hexagonal blank.
The center at one end was punched with an awl, and at the other end a saw was used to mark the X seen in the picture. After mounting the blank in the lathe The corners were knocked off using a gouge (I’m not so good with the precise names of the tools.) until the entire blank was a cylinder. Using an aluminum bat as a reference I measured out the transition points – the edges of the knob, the point where the handle angles into the barrel and the end of the barrel. Those were marked with a pencil then cut using a parting tool.
Then using a skew chisel, gouges and parting tool I brought the barrel down to final dimension (about 2 1/4”) and the taper into the handle was rouged out. This was the end of session #1 on bat number 1. The blank looked like this at that point.
Fast forward to last week, the first class of the fall session. I was able to finish the first bat through sanding. I was fairly please with the results although the knob is a little small. My instructor has recommended using a dog biscuit to burnish the bats, and he’s offered to provide it, but didn’t have it with him so I put the bat aside.
With the first bat finished I started in on the second bat. Class number one ended with the second blank ready for marking. On Thursday I was able to get the second bat to the same point as the first. I should be able to get them finished up next week.
Here are a couple more pictures of the almost completed bats:
The first bat is in the middle, the second on the right, the bat on the left is the aluminum bat from which the dimensions were taken.
The knob of bat number 2.
I don’t know how much more turning I’ll do anytime soon. I do know that if I decide to do much more I’m also going to acquire my own tools. The tools available in class are just not sharp enough, and have been abused – broken handles, bent shafts, and the like.
It has been fun learning this new skill.
-- Chelle http://artsgranddaughter.blogspot.com
2 comments so far
35111 posts in 4369 days
#1 posted 10-08-2007 02:25 AM
Great set of pictures. Keep us informed.
18615 posts in 4129 days
#2 posted 10-09-2007 04:47 PM
this is wonderful !!!
(I’ll be sure to show this to Rick so he can made one from our free wood we got)
