Workbench build - roubo #3: End caps
Blog entry by buck_cpa posted 02-28-2014 02:12 PM 3379 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 2: The top Part 3 of Workbench build - roubo series Part 4: Stretchers »
For the end caps I decided to use some walnut I bought a while ago. I went with a standard C-channel end cap. I really wanted to do a sliding dovetail, but it seemed a little too difficult at this point in my woodworking.
First I cut a straight edge with my circular saw across the end. I flipped it over and offset my cut 1/16” and finished the cut. Then I used a pattern bit and cleaned up the 1/16” excess. I read somewhere this method was much easier that attempting to match up the circular saw cuts, and I think that is true. This is prior to cutting the shoulders for the end cap.
To cut the shoulders (not really sure what to call them), I considered using a router. It seemed like that would take forever and I always seem to wobble the router and take out a chunk and screw up the project. So I used my circular saw. I set the depth @ 15/16” and setup a cutting guide. I made several straight cuts, then I slightly turned the saw and pushed it through. The saw guide prevented me from unnecessarily cutting into the benchtop (beyond the edge of the end caps). I learned this method watching my father in law cut dadoes in 6×6’s when constructing decks.
I cleaned it up with a chisel.
Then I took my end caps to the tbsw and setup my dado stack and cut the female portion of the joint. I used several test pieces of scrap lumber to get the fit right.
After I got the fit right, I counterbored three holes in each end cap. Then I fastened the end cap to the top with three 2” lag bolts.
The finished benchtop.
2 comments so far
View BTimmons's profile
BTimmons
2303 posts in 2541 days
#1 posted 02-28-2014 03:03 PM
Looking good!
-- Brian Timmons - http://www.BigTWoodworks.com
View helluvawreck's profile
helluvawreck
31736 posts in 2922 days
#2 posted 02-28-2014 04:30 PM
When it’s finished it will be a fine addition to your shop.
helluvawreck aka Charles
