Shop #2: Drill Press Table and other shop upgrades
Blog entry by Big Ben posted 01-13-2011 03:54 PM 2847 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 1: Workshop: Clamps Storage Part 2 of Shop series Part 3: Workbench »
While I have not completed the drill press table, I figured I would post some of the upgrades to the shop that I have been working on.
As far as the drill press table is nothing fancy but very functional. I still need to add some T-Track to the fence other that it has work fine. I used it to mortise the legs of my bench and the only issue I had was that I had to remove the table to change the height of the table but I think that is a function of the drill press (I have a 10” Ryobi).
From Woodworking
Another project that I have completed was a sawboard, this is something that I should have done a long time ago. It has made my work much faster than setting up temporary jigs. I made it 48” in case I needed to break down plywood.
From Woodworking
I also completed tenon/dado sled, its based on the design I saw at The Apprentice and the Journeyman (http://theapprenticeandthejourneyman.com/2010/08/14/13-lets-build-a-dedicated-dado-sled-for-the-table-saw/). Creating the jig meant I needed dado insert plates which I made from MDF, I think where fine but I think I will make a larger batch of them next time and try making them from Baltic Birch ply instead.
From Woodworking
I really like the sled, was easy to use but I did have some trouble with the UHMW runners when drilled them. The UHMW expanded where I screwed in. They were counter sunk but still required some sanding and filing down.
From Woodworking
From Woodworking
Next shop project is a workbench.
5 comments so far
View dbhost's profile
dbhost
5726 posts in 3260 days
#1 posted 01-13-2011 04:47 PM
Looks good and functional to me!
View canadianchips's profile
canadianchips
2602 posts in 3026 days
#2 posted 01-13-2011 04:49 PM
Jigs are always handy to have. Takes a little time to make them, but saves a LOT of time after you have them.
Good to see these.
View Maveric777's profile
Maveric777
2693 posts in 3105 days
#3 posted 01-13-2011 08:30 PM
Looks like you done good Ben. Good stuff bud….
And good luck on the bench. I been brainstorming for the last week how I want to build my “Bad To The Bone” work bench and still not sure where to go. Just got my book in on workbenches and I haven’t had a chance to read it yet. I have flipped through it and found some sweet eye candy and ideas in it. Here is the link in case your looking for a book as well….
The Workbench: A Complete Guide to Creating Your Perfect Bench
-- Dan ~ Texarkana, Tx.
View lanwater's profile
lanwater
3111 posts in 2963 days
#4 posted 01-13-2011 11:46 PM
Looks good. You are ready for the bench.
-- Abbas, Castro Valley, CA
View nobuckle's profile
nobuckle
1120 posts in 2789 days
#5 posted 01-14-2011 03:54 AM
All great projects. You’ll be amazed at the increased efficiency those three upgrades will add.
-- Doug - Make an effort to live by the slogan "We try harder"
