Figured Maple and Walnut Coffee Table #4: Weekend #4 Finishing touches on the top and shelf
Blog entry by bohnsai posted 10-25-2010 04:21 AM 10968 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 3: Second Weekend part two Part 4 of Figured Maple and Walnut Coffee Table series no next part
Don’t have a lot of time to write tonight but a picture is worth a thousand word right? So here are some progress pics of this week. Construction for the top is similar to the shelf: biscuits and maple splines.
Here is the bottom shelf wetted with mineral spirits.
i
and detail of spline
Here I’ve used tape for the top so I don’t have to mark the actual wood for biscuit locations
Here is a close up of some repair I had to do to one of the walnut top boards. There was a not so minor check on one end so I used a 1/8 kerf and cut it out, cut a sliver of walnut and glued it in. I also had an area of pitch showing so I hollowed it out and filled it with superglue and sawdust. It’s a little difficult to see in this pic but in it in the bottom right corner. I’ll take a close up when it is all done. Right now everything is just dry fitted.
Here is the top all glued up. Since the pipe clamps put a ton on pressure on the boards, they tend to bend a little, to counteract this, I used some spare board to stiffen the top. Once dry, it will be flat as opposed to curved.
And here are some pics of the finished top.
Something I did skip mentioning here is that while trimming the walnut edges of the top. I ran into some issues with the router. The walnut is heavily figured which can be disastrous if not dangerous to use a router on. I always check the edges of figured (or any wood for that matter) for checks or splits, etc. However, that doesn’t always mean there is a hidden split under the surface.
And I ran into that exact issue on one of the long edges. While using a flush trim bit, a huge chunk got snagged and got ripped right out of the edge. So I ended up having to trim about 1/2 off the edge. So instead of a 4 inch border I was left with 3.5. Disaster recovered and if I didn’t mention it, no one would know and that is all that matter right?
-- You're not a real wood worker until you've been to the Emergency Room...Twice...in one year...wait a minute, this isn't right.
2 comments so far
View dub560's profile
dub560
615 posts in 2816 days
#1 posted 10-25-2010 04:54 PM
damn ..that looks great man
thank’s for posting cause i’m always learning from you guys you know
-- Life is enjoyable especially when you borrow from people
View lanwater's profile
lanwater
3111 posts in 2837 days
#2 posted 10-25-2010 11:35 PM
It looks great.
How did the superglue and swadust work for you.
The last time I tried that with oak it turned the white oak to brown. I guess with walnut it won’t be visible.
-- Abbas, Castro Valley, CA
