DAILY DEALS Clampmate Frame Clamp - Internet Only Special!  |  Makita Makita Recon LCT203W 10.8 Volt Lithium Ion Impact Driver 2 Pc Kit
Restoring an old 6" jointer - Delta Milwaukee 37-207 #1: Restoring an old jointer for the shop
Blog entry by Bob #2 posted 12 days ago 263 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Restoring an old 6" jointer - Delta Milwaukee 37-207 series no next part
A couple of weeks ago I rescued a an old 6” Delta/Milwaukee jointer from a Garage sale. ( Circa 1940’s)
The fellow I bought it from was mostly into old cars and had no use for this iron and it sat rusting in his way. We made a decent deal and I lugged it homeward.
The surfaces of the in and out feed table were rusted and pitted and I did think about having them re honed at a machine shop but first I felt it better to run it to see what else was wrong.
About and hour with some rust remover from Lee Valley and I had the vital parts soaking overnight in dampened paper toweling or immersed where practical.
With a bit of elbow grease and some metal finishing pads on the electric drill I was able to get an acceptable surface on the tables.
From delta 37 207 jointer
At this stage I was confident that it could be put back in service. bearings good, tables flat, belt not so good,
pulleys, out of round and too small for the 3/4 HP motor.
After some help from the guys here I figured out the ratios for the upper and lower pulleys and swapped the drive system over to “Vee” belts which are wider and tend to run smoother.
I have a 2-3/4” pulley on top and a 6-3/4” pulley on the motor which should give me around 4000 RPM . With the 3 blade cutter head I will be getting close to 12,000 cuts per minute.
To get the motor to hang properly off the belt I had to rig up a hinge plate for the motor to sit on attached to the frame and on the unhinged end I made an adjustable rubber covered motor mount that I can set to take tension off the bearings and still drive the cutter head.
From
The next thing I wanted to address was the short bed length and fortunately the out feed casting came with a hole in the end allowing me to put a tenon in the space .
It was a bit of a trial and error as the inside of the casting was neither smooth or parallel.
At any rate, I came up with this:
Today I worked on putting a removable stabilizer leg under the extension and am fitting the sweep under the carriage to attach a dust collection hose.
For what it’s worth the old iron seems to cut extremely well and will serve me for what I need.
7 comments so far
View jackass's profile
jackass
58 posts in 604 days
posted 12 days ago
A friend of mine got an old jointer similar, that was in service as a small boat anchor, he brought it back to a working machine. Congrats to both of you. It cost him the price of a danforth anchor plus labour.
Jack
-- Jack Keefe Shediac NB Canada
CanadianWoodChuck
158 posts in 804 days
posted 12 days ago
That looks like a great labour of love Bob – enjoy your jointer! I’m sure you’ll get years of service from this equipment.
20518 posts in 713 days
posted 12 days ago
I really like to see posts like this, Bob. Giving an older tool new life is pretty cool.
Now that the hard stuff is done go ahead and have some fun with it.
View king's profile
king
50 posts in 838 days
posted 12 days ago
Nice job I enjoy seeing posts of old tools being renewed and put back to work.
-- franklinalbert@sbcglobal.net
3031 posts in 912 days
posted 11 days ago
Thanks Fellas.
I think I almost enjoy this part as much as the woodworking.
Well, maybe not quite as much.
Next on my agenda is the Delta 24” jig saw(like this one) sitting waiting for me in the garage.
View blockhead's profile
blockhead
286 posts in 199 days
posted 10 days ago
Great job Bob! I know it will last you a long time and serve you well. It is very gratifying to bring an old tool new life. Well done!
-- Brad, Oregon- Wood, it's what's for dinner.
posted 10 days ago
Thanks Brad.
I got the vacuum hooked up last night and the thing purs like a kitten.
I was going to give it a paint job but I think it deserves to be original after all these years of service.
Cheers
