Planing a cutting board
Blog entry by bluchz posted 12-24-2009 12:03 AM 2424 reads 0 times favorited 13 comments Add to Favorites Watch
OK everybody get a good laugh out of the way right here at the start. I decided to make my first cutting board this holiday season, we had too much time off work. I started with some nice white oak that i have lying around. planed it and cut it into 1-1/2” slices, glued it together, and (ok here is the silly part) sent it thru the planer. Anyone who has tried to do this is now laughing and saying i remember trying this, everyone else is laughing at my stupidity! Talk about chatter, and this is the first time i have experienced kickback in the planer( glad i was standing to the side!) it broke the glue joint and sent a piece flying across the room! So i tried a few more times thinking i had something wrong with the planer, i’m a slow learner. So i thought i would throw this out there in case my conclusion is wrong, Never plane end grain! or i still have it wrong and am too slow to figure it out. Hopefully i have blogged my own stupidity before someone else does!
-- flash=250,100]http://www.brickshelf.com/gallery/sprxtrerme/BANNERS/thornax.swf[/flash]
13 comments so far
View Herbiej's profile
Herbiej
66 posts in 3438 days
#1 posted 12-24-2009 01:48 AM
Hey, everybody has to try this at least once. I have several short cutting boards. I have found that a hand power plane works fairly well if the board is real uneven. After the power plane, I finish it off with 36 grit then 100 grit in my belt sander. finally, 120 and 220 in my ROS.
-- Acts: 2:38
View mtkate's profile
mtkate
2049 posts in 3410 days
#2 posted 12-24-2009 01:53 AM
Actually, it worked once for me but only because the board was not totally end grain. Some say you can “kiss” the board with the planer but I had the same thing happen two weeks ago. And I proceeded exactly like you said. I tried again. Doh! I learned my lesson. I haven’t posted the board yet but let’s say it started out to be a nice long end grain board for bread… now I would say it’s perfect for cutting garlic.
View papadan's profile
papadan
3584 posts in 3453 days
#3 posted 12-24-2009 01:54 AM
So many great cutting boards are being built this tim of year. Oh, and by the way Bluchz, DON’T DO THAT! LOL
View Rustic's profile
Rustic
3253 posts in 3681 days
#4 posted 12-24-2009 02:19 AM
Any tips on how to avoid that?
View noimagination's profile
noimagination
6 posts in 3160 days
#5 posted 12-24-2009 02:28 AM
I’m fairly new to this so I’m just wondering why this is not supposed to work.
I have built two different end grain cutting boards and sent them both through the planer (Not having a clue that it wasn’t supposed to work). Other than minimal tear out at the ends, which I expected and cleaned up easily with the table saw, there was no issue.
I was using my dad’s Dewalt bench planer and both boards were totally end grain, made of maple, about 13 inches wide (maximum for the planer) and about 1 inch or a little more thick.
Anyway, this is the first I’ve heard about this not working, guess I just got lucky? Anyone have any ideas?
-- Mike
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
475 posts in 3713 days
#6 posted 12-24-2009 04:21 AM
Drum Sander!!!!
-- The more skilled you are at something, the worse you are at it when someone is watching.
View sras's profile
sras
4844 posts in 3214 days
#7 posted 12-24-2009 05:03 AM
I followed what dewoodworker posted in his blog. I think what really helps is rounding over the edges before running through the planer. I also take VERY light passes – about 0.008” (1/128) per pass. On top of that, I start with the blades making no contact, just enough to move the board.
On the other hand – if you have a drum sander, I don’t know why you would use a planer.
View TurnTurnTurn's profile
TurnTurnTurn
614 posts in 3194 days
#8 posted 12-24-2009 05:27 AM
I was about to make a cutting board, thanks for the advice. Better to learn from the mistakes of others, glad you were not injured!!!
-- TurnTurnTurn
mtkate
#9 posted 12-24-2009 08:44 PM
If you don’t have a drum sander, use the belt sander. Mike, you were lucky. Even with very light passes, there is always a chance of explosion (as I found out the hard way!). At least when I was doing it, I was conscious that I was possibly doing something silly and stood far enough away – had a canvas apron (extra protection) – and kept my hand close to the off switch…
View bluchz's profile
bluchz
187 posts in 3458 days
#10 posted 12-28-2009 01:01 AM
Ok here is the end result of my labors. it’s smaller than i had planned, but it looks nice
Dogfish cutting board
It’s White oak end grain and the fish is purpleheart.
mtkate
#11 posted 12-30-2009 01:13 AM
That’s beautiful! Can’t tell the difference.
View TopamaxSurvivor's profile (online now)
TopamaxSurvivor
18337 posts in 3760 days
#12 posted 12-30-2009 01:25 AM
Well, I’m pretty proud of myself. I’ve never done that:-) Read this before I got a planer!!
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3430 days
#13 posted 01-07-2010 09:46 PM
Noimagination – end grain is tough. If you are lucky enough to get an endgrain cutting board through your planer congrats. It will dull your blades much faster than face grain because the blades have to chop through the fibers rather than shear them from the face. To see how tough end grain is, in your spare time try a cube in a cube project (as in mine and many other’s gallery). A large forstner bit will cut the required hole in the face grain in a matter of seconds. Drilling into the endgrain is an absolute bear ! It takes minutes, not seconds.
Another good example of cutting across end grain would be cutting logs. You can drive a splitting wedge into the end of a log and split it instantly between the grains. Chopping the log in half is a different scenario. This is also why you see crosscutting saw blades have more teeth and shallower gullets. The work for the saw is to sever the fibers, as opposed to a rip blade that has deeper gullets to remove the saw dust better from an “easier” cut.
