Ebonizing oak with vinegar and steel wool solution.
Blog entry by bigfish_95008 posted 02-05-2012 04:10 PM 13085 reads 5 times favorited 23 comments Add to Favorites Watch
A while back I was reading about using vinegar and steel wool to ebonize wood – particularly Oaks. I took the last of the wife’s vinegar and and some steel wool threw them in an old peanut butter jar and set it on the shelf. Nothing seemed to be happening with it – don’t know what I was expecting, but even after a few days in solution there was not significant color change of the liquid. Yesterday, a fabulous day here in SOCAL by the way, I looked at the solution and noticed a bit of settling. After shaking it up to mix it the solution turned almost black. After straining it through some cheesecloth the wife dipped a couple of woods in to see what would result, interesting, very interesting. The oak that I was hoping to use it on turned a almost red after drying and was very rough. After resanding it to 220 it felt smooth again but was still and ugly color red. I decided to try some linseed oil on it to “wet” it – WOW – did that make the process worth while. The oak turned a dark black and the grain really lit up. Time for some assembly of parts to see if it contrasts with the other oak parts well. Once the clock’s is assembled I’ll post some pictures of all 12 using various woods and finishing processes
Have a great day out there.
Allen
-- bigfish "I am always doing what I cannot do yet, in order to learn how to do it." Vincent Van Gogh
23 comments so far
View Ben's profile
Ben
302 posts in 2331 days
#1 posted 02-05-2012 05:28 PM
That is a really interesting idea. I would love to see pictures of this. I’ve thought about trying to find some less chemical ways to color wood, and I do like to experiment so that is something to try for sure. I have plenty of oak to try it on. Is it a reaction with just oak or would it work on other woods too?
-- Welcome to downtown Coolsville, Population: US! --Hogarth Hughes
View Dlow's profile
Dlow
70 posts in 2688 days
#2 posted 02-05-2012 05:47 PM
Several years ago there was a show called “furniture to go” with 2 guys that would do repairs to all kinds of furniture. I remember one episode they did that they used the same technique to make a dye for a piece they were restoring. They put a bunch of steel( nails, chain and what have you) into a bucket with vinegar and the resultant product made a very interesting dye. I always wanted to give it a try but haven’t found the right project to use it on. I don’t know if you can find the episode on YouTube but they had some interesting techniques.
View Gene Howe's profile
Gene Howe
10479 posts in 3429 days
#3 posted 02-05-2012 05:53 PM
I suspect that the tannin in oak will yield the best (darkest) results. But, it would be interesting to try it on other woods.
View Ben's profile
Ben
#4 posted 02-05-2012 06:01 PM
That is what I was thinking Gene. It is also the tannin in the oak barrels that gives whiskey that nice golden color and some of the flavor ;)
View DIYaholic's profile
DIYaholic
19620 posts in 2676 days
#5 posted 02-05-2012 06:02 PM
I want a grey/silvery tone to red oak & red oak ply. Would this technique work or does it just make the oak more or less a black?
View John Ormsby's profile
John Ormsby
1285 posts in 3738 days
#6 posted 02-05-2012 06:32 PM
For a gray or silvery look try mixing some baking soda in water and applying it to the oak. Let it sit a while ( can let it sit for a day or two on the wood ) and then wipe it off with clean water to remove the excess soda. Let dry and try different clear finishes.
-- Oldworld, Fair Oaks, Ca
View shipwright's profile
shipwright
7980 posts in 2799 days
#7 posted 02-05-2012 06:35 PM
I have used it on Oak and on Walnut (which has a close enough grain appearance to pass for real ebony) with good results. If the solution is strong enough you can literally watch it go black before your eyes. ... Fun!
DIYaholic
#8 posted 02-05-2012 06:58 PM
John,
Thanks for the info. I’ll have to give it a try.
View Brit's profile
Brit
7376 posts in 2843 days
#9 posted 02-05-2012 07:08 PM
It works a bit quicker if you wet the steel wool with water and let it go rusty before putting it in the vinegar. Add some rusty nails and any other metal too.
-- https://www.clickasnap.com/Andy61 - Andy - Old Chinese proverb says: "If you think something can't be done, don't interrupt man who is doing it."
View Ben's profile
Ben
#10 posted 02-05-2012 07:11 PM
Walnut is my favorite wood, for both look and workability. I’m going to try this and I will try it on walnut too. Does walnut contain tannin like oak? maybe just not as much I suppose…
View ~Julie~'s profile
~Julie~
607 posts in 3035 days
#11 posted 02-05-2012 07:15 PM
I use it on pine often, to make it look old. You have to experiment with how much vinegar, how long to sit it, and I sometimes add water after. I’ve used it on old barn board when I cut the ends and they appear fresh, you can add some of this mixture to make the cut look darker like the rest of the board.
-- ~Julie~ followyourheartwoodworking.blogspot.ca
View Will Mego's profile
Will Mego
307 posts in 3713 days
#12 posted 02-05-2012 07:17 PM
yes, to second what Brit said, it’s often referred to as “rusty vinegar”, so throw some easy rusting metal with it. Also, most common steel wool will require being broken up and washed a bit, as it gets a thin coat of oils on it somehow during it’s early life. So if you take a pad, wash it a bit in water, break it up, and many people swear by cider vinegar instead of white. I did this a while back and it QUICKLY turned red oak into a deep beautiful dark color that made me think of old libraries.
-- "That which has in itself the greatest use, possesses the greatest beauty." - http://www.willmego.com/
View Brit's profile
Brit
#13 posted 02-05-2012 07:22 PM
Other possibilities for ebonizing wood are Indian Ink from an art supplies shop and Ebony wood dye. Indian Ink looks nicest in my opinion, but it isn’t cheap if you have a lot to do. Fine for a drawer knob or small items like that though.
View stefang's profile
stefang
15881 posts in 3335 days
#14 posted 02-05-2012 07:43 PM
I have read about this method for oak, but not for Walnut as Paul described. I would be interested in seeing a photo if possible from Julie to see what it does to pine.
View doncutlip's profile
doncutlip
2832 posts in 3557 days
#15 posted 02-05-2012 07:47 PM
Hey I use that solution all the time, but I think you have to wash the oil off the steel wool first. I use this solution on pine and it turns it grey, after it dries I put a solution of tobacco and ammonia on it and it turns it a real nice brown.
-- Don, Royersford, PA
showing 1 through 15 of 23 comments
