Cherry Box of squares #4: Glue-ups
Blog entry by bandit571 posted 11-14-2016 10:52 PM 793 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 3: Dovetails and grooves Part 4 of Cherry Box of squares series Part 5: Lid work »
Dryfit came out decent enough….
Somehow missed that one side was a hair shorter than the opposite side. Will just have to deal with that. Got to the point I could spread some Elmer’s around…
Somewhere, in the midst of that forest of clamps is a box…...let it side for a day…..
Ok, today the clamps came off, wore me out just doing that…..Decided to clean things up a t bit..
Set the box in the vise. Any holes got a dribble of glue, and a pinch of bandsaw dust. Mooshed around a bit, then a palmsander to sand smooth. Then and old plane came along
Stanley #4, Type 13. Tried to follow the grain as best as I could, sometimes had to turn the box around..
Until I had cleaned up all four sides. Tossed the box onto the bench and clamped it in place..
As a couple corners needed trimmed down. I think I can set this aside for now. Time to work on a panel for the lid…
Yep, ugly, I trimmed it to rough length, hoping I got it square by cutting both ends. Width is fine. Got out the cambered jack plane for a bit of work,,
usually just straight across the grain. Got both faces leveled out. Then used that smoother again..
Going at a diagonal to the grain. Had a few problem spots…..100 grit beltsander took care of that.
Trying to decide which is it’s best side….to be the show side.
While running the planes around, I usually rub an old candle across the soles of the planes, makes thing a little easier to push the plane along…maybe a bit too easy. I pulled back a bit too far, and when the plane went forward again…plane missed the wood…three knuckles did not. DNA on the bench, again.
back was getting a bit stiff, left hand was sore. Knee was behaving, for now. Marked four pieces to make a frame to hold the raised panel.
And looked at all the plane work needed to make them smooth, and square…...”Breaktime!” Maybe AFTER Supper, I might wander back to the shop. Until then, stay tuned.
BTW: I raise a panel with just handplanes, ala Paul Sellers. Might be fun to watch….
0 comments so far
