Pine Auger bit box #7: Lid work
Blog entry by bandit571 posted 10-28-2016 12:06 AM 1060 reads 0 times favorited 11 comments Add to Favorites Watch
« Part 6: Page #3 in the clamps....finally Part 7 of Pine Auger bit box series no next part
The blank came out of the clamps today. Marked it for the size of the box, trying to get as much of an old knot cut off as I could. One part of the blank was a bit fatter than the other..
Sanding that down would have taken too much time and sandpaper.. we have ways..
After drilling a pair of new dog holes, on a center line from the vise…I used a Stanley #5c with a cambered iron. Going across the grain, didn’t take all that long to get close to flat. Then turn the blank 90 degrees, and go with the grain, but with a smoother of a jack plane..
Had to do this to both faces of the blank..
This face had a touch of a ridge. Plunked the lid onto the stack of “pages”...
Sooo, I now need to get rid of all those gaps. Already started on the top page…before I had to go run a bunch of errands. I need to install the last of the hinges. Plan to attack the gaps? Place the box in the vise, hinge side down. Run a handsaw down where each gap is. The kerf cut will remove the excess wood that is causing the gaps.
First off, I might want to clean the bench up a tad? As I made a mess again…
Then IF I can get a day or two without Honey-dos and errands…..I might get this about ready for a finish?
11 comments so far
View CFrye's profile
CFrye
10480 posts in 2038 days
#1 posted 10-28-2016 02:34 AM
No such thing as a day without Honey Dos, Bandit, unless you don’t have a honey!
Neat ‘trick’ with the sawing away the gaps.
-- God bless, Candy
View bandit571's profile
bandit571
21735 posts in 2881 days
#2 posted 10-29-2016 07:19 AM
Well, Gap-osis is almost done away with. Got as much as I could..
So, since I have to wait on the latches to get to the shop…I might just put a finish on this block of pine…
This is a 50/50 mix of BLO/Varnish…...we’ll se how it turns out. Almost time to post as a project? As soon as I get the latches on. I think this blog is about done…
bandit571
#3 posted 10-29-2016 04:59 PM
So, maybe a PIP before we go?
After a good sanding, and a roundover on the lid..
With a block plane, of course….now IF I can get the latches to the shop…
Maybe it might qualify as a project?
CFrye
#4 posted 10-29-2016 10:24 PM
From where are you getting the latches, Bandit?
-- God bless, Candy
bandit571
#5 posted 10-30-2016 06:35 AM
Hook & eyes are from Menards…..might wind up looking like a chain down the front.
Between the cost of the parts, and shipping…..decided to wait on any orders to UM EX. Their LT-25 was just about what I was looking for….
CFrye
#6 posted 10-30-2016 01:18 PM
Not familiar with that company. Got a link?
-- God bless, Candy
bandit571
#7 posted 10-30-2016 05:53 PM
Link: http://www.umei.com
$8.50 for a bag of 10 parts…haven’t seen what the shipping would be. Hook& eyes were #1 a piece. At Menards. 2 to a package @ $1.97. I bought three packs, and a package of brass corners….
Made a “chain” out of the Hook & Eyes. 4 corner brackets to a $1.97 package. With a bunch of very tiny screws. Needed a pilot hole drill..
For both the screws, and the hook & eyes. Small screwdriver, too.
Currently have the second coat on the box. Went with the redder Witch’s Brew. Will give it a rub out later today…
bandit571
#8 posted 10-30-2016 05:54 PM
Oh, and as for that chain?
Will see how this works out.
View robscastle's profile
robscastle
5444 posts in 2402 days
#9 posted 10-30-2016 10:05 PM
Looks pretty flash,
I made a Chisel box many years ago for my chisels enjoyed it almost as much as reading all about your exploits.
Keep up the good work!... as for a project I will be disapointed if you do not post it when complete!!
-- Regards Rob
robscastle
#10 posted 10-30-2016 10:11 PM
Ha ha I found it just goes to show what I get up to when “bored!!
-- Regards Rob
bandit571
#11 posted 10-31-2016 09:19 PM
It has now been posted as a Project.
We’ll see how that turns out..
Next up? Well….there is an empty box that used to hold a few drill bits. Might try to fill it up with something else? Stay tuned….
