Another simple little box? #3: Lid work
Blog entry by bandit571 posted 05-04-2016 09:06 PM 904 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 2: Glue ups, just glue ups Part 3 of Another simple little box? series no next part
Well, sanded down some of the fingers that were sticking up..
After which, I ran a small combo square and a pencil around
Trying to land somewhere besides right on a pin. Plane was to saw the lid part from the box’s bottom. Handsaw would be a bit too rough on things, and get into a bind. Bandsaw? A bit hard to do, and see where I was cutting. Yard sale item might just work…
I cut one end first, to get the hang of using this heavy saw. Then cut the long sides. I kept the box in the vise, to help out. I then cut the last end….just a hair of a bind at the end…..and wound up with this.
In the last blog, I had made an insert for the lid. Time to install that in place, and nail it off..
Nails yes, glue no. Clamped the two pieces back into the vise, had some small hinges to install
Small? Well, I used a small nail to make pilot holes. Try using thing screws..BEFORE taking the BP Meds..
I also finished the sanding. A sanding filler for around all them fingers was just glue, then bandsaw sawdust
Leveled all the fingers that were a tad too long. Decided to load the box up, to see how things fit..
Well, the 78 and all it’s parts a re snug, the @39 as well. Stuck the Ohio toolworks plane into it’s new home…
Everything seems to fit. Keepers even clear the planes in the bottom.
Closed the lid..
And added a the first coat of the Brew Finish
May need to craft a label for this one. I still need to find a latch, of some sort, and a final finish. Wood working part of this project is about done….thanks for looking in..
3 comments so far
View bandit571's profile
bandit571
20472 posts in 2738 days
#1 posted 05-05-2016 05:08 PM
The gap at the corner has been fixed. Used a block plane to lower the higher corner at the other end.
Printer and I aren’t on speaking terms…..may just get some brass sheet stock, and cobble a label from that. Have a Dremel, and some engraving bits. Maybe get some small brass tacks/nails later to attach it.
Found a decent enough brush this morning, might go ahead, and add a coat of Poly Gloss. Not sure about what the bottom will get…....yet. Maybe some fancy brass corner guards?
View Gene Howe's profile
Gene Howe
10621 posts in 3483 days
#2 posted 05-05-2016 05:21 PM
That’s a great tool box, Bandit.
A place for everything and everything in it’s place.
The dungeon will be so neat, you won’t be able to find anything.
bandit571
#3 posted 05-05-2016 05:34 PM
Maybe work on a rocker< next? Or….a till for a couple dozen handsaws?
