Pine tool box, Stanley Style #1: Start ups
Blog entry by bandit571 posted 01-18-2016 01:38 AM 890 reads 0 times favorited 4 comments Add to Favorites Watch
no previous part Part 1 of Pine tool box, Stanley Style series Part 2: Dovetails, story of two saws »
Well, while going through the local Menards Store, went over and dug through there Value Wood rack…they were selling 1×10s and 1×12s, all under 3’ long. Picked through to get the clearer stuff. Wound up with five boards, for $1.69 each..
And, since the Single Brain Cell Sketch Up was “off-line” had to actually draw something on paper..
About as close to an actual “plan” as I get. Even drew a “page 2”
Wore out the pencil, even. Dug around, found a sharpener to keep down in the shop..
The old metal tool box has seen better days…
The thing is so full of small hand tools, I can barely lift it. So, laid out some lines, and did some cross cutting
Cordless saw. Got two blanks to work with
Then laid out some bevels. Cut those on the bandsaw, then clamped them up, and planed the cut edges smooth and flush with each other..
I still needed these sitting out. Marked how far up the sides of these ends the “sides” will go, and the bevel they will need. I was able to get two sides out of a plank. Ripped on the bandsaw, but it needed planed straight along an edge
Marked the bevels needed
Then I had to carry the line down one side. To actually cut the bevel, needed that big old plane again..
Just hold it at the angle of the bevel, and plane the edge’s corner down until the line is cut, almost. Got both sides beveled….then check for length…..hmmm, a bit too long, crosscut to 20” in length
Then a test fit of sorts on the bench’s top…
That should do for now. next up? Through dovetails need to be done, to join the corners. Might look better than a butt joint with screws or nails? Stay tuned….
4 comments so far
View RustyHacksaw's profile
RustyHacksaw
142 posts in 1292 days
#1 posted 01-18-2016 03:09 AM
Looks great. Gotta love value wood. You sure are turning the scrap pile into something nice though.
View Miataguy's profile
Miataguy
142 posts in 1304 days
#2 posted 01-18-2016 12:53 PM
Looking good!
Miataguy
#3 posted 01-18-2016 12:53 PM
...and looking forward to the dovetails….
View bandit571's profile
bandit571
20266 posts in 2712 days
#4 posted 01-18-2016 07:53 PM
Found out why I don’t do tails first..
Other three corners will be Pins first. I can at least tuned this corner up
Waiting on the camera to finish charging back up. For some reason, It had a “Low Battery” alarm…maybe this evening, I can post part 2??
