Pine Project, 4x4s #6: Assembly done, and a PIP
Blog entry by bandit571 posted 01-09-2016 02:25 AM 1196 reads 0 times favorited 6 comments Add to Favorites Watch
« Part 5: Mortises chopped, a bit of glue spread around Part 6 of Pine Project, 4x4s series no next part
Well, other than a Boss ordered shopping trip, spent a bit of time in the Dungeon Shop today..getting the rest of the base assembled.
Diagonal clamp to pull this thing close to square. Had to make the corner blocks as well. Was just going to add a corner block to help glue up one short apron…..and kept going.
Actually, I got to this point, and had to take the Boss shopping, then come back and fix supper….Finally got to work a bit more
A smooth plane? Ah, not exactly. I was trying to flatten the top a bit, since it had cupped a bit..
Figured a #6c could do that job. Attached the now flatter top to the base..
Drew some circles on the corners of the top. Old green B&D Sabresaw to cut tthe circles off. Beltsander to smooth out
Made use of the end vise on the bench, needed a way to hold the table still long enough to run the router around the edges..
Used a small bit to cove the edges abit..
Sooo, after a lot of sanding, and dusting off, time for the Witch’s Brew. Opened the can….running a bit low…added a pint of BLO to the mix. Stirred it up, to bring the stuff in the bottom up, cheap brush..and
Drum Roll, if you please..
Almost a Pumpkin Pine effect? This will also get a coat of clear Poly Gloss later, maybe one more look, before this is posted as a Project?
Not too bad? Remember, all the wood for this project came from just those four 4×4x30” scrap timbers. hated to throw them away….might as well use them.
6 comments so far
View robscastle's profile
robscastle
5631 posts in 2441 days
#1 posted 01-09-2016 04:34 AM
Hey !! thats looks a bit of allright I must say!
-- Regards Rob
View eddie's profile
eddie
8565 posts in 2851 days
#2 posted 01-09-2016 06:01 AM
it turned out great ,like the coved edge on the top, BLO got it to pop
-- Jesus Is Alright with me
View TheFridge's profile
TheFridge
10816 posts in 1723 days
#3 posted 01-09-2016 06:25 AM
Good work. It’s unfortunate that you’re making the rest of us look bad. We need you to cut back production a hair.
View Sylvain's profile
Sylvain
768 posts in 2736 days
#4 posted 01-09-2016 02:43 PM
Very nice … as usual.
Happy new year
-- Sylvain, Brussels, Belgium, Europe - The more I learn, the more there is to learn
View Reaperwoodworks's profile
Reaperwoodworks
94 posts in 1171 days
#5 posted 01-09-2016 04:11 PM
All from scrap?! So cool. Nicely done. Love the color.
-- Website: www.reaperwoodworks.com, Youtube: https://www.youtube.com/channel/UC_ognomZyK6V0VwdokBcixw
View bearkatwood's profile
bearkatwood
1675 posts in 1248 days
#6 posted 01-10-2016 01:48 AM
That is a very charming table, nice old world feel. Great job!
-- Brian Noel
