Pine Project, 4x4s #1: Resaw some 4x4s
Blog entry by bandit571 posted 01-04-2016 12:19 AM 972 reads 0 times favorited 7 comments Add to Favorites Watch
no previous part Part 1 of Pine Project, 4x4s series Part 2: Leg work to do »
After a loft bed build, I had four 4×4s left over. Boss finally told me to get them out of the Dinning Room!
OK, Laid some lines out, and tried the bandsaw
Cuts seemed to go which everyway they wanted. Tried to get them close to the lines….Figured I could at least plane them close to flat..
A Corsair #5 Scrub Jack got things almost flat, then a longer plane tried it’s luck…
Stanley No. 7c…...Got three boards planed close to flat, and had a few more to do…
There was one skinny plank in there…set it aside. Put the rest into the clamps with some glue…called it a night
Well, football games weren’t going too well. Might as well trudge back down and de-clamp that “top”
Scrubbed the heck out of both faces, not sure yet will be the “show side” Scrub planes, cambered jack planes, jointer planes…they all took a turn at it. I also mark a square line on each end, and cut the line with a saw. Got down to a smooth plane..
#4 sized plane by Millers Falls…. Set the “top” aside, had two other 4×4s to resaw. Wasn’t happy with the cut from the bandsaw, sooo, clamped one 4×4 to the benchtop, marked two lines, and a circular was run down the lines, cutting the line.
Just one side was done this way. Tried the bandsaw one more time….to seperate the three slabs….smaller kerf of the bandsaw… left a bit of “junk” on two faces. Ran the slabs through the bandsaw again, and cut off the extra stuff. Back to the bench, clamp each down, handplane them smooth..
Close to one end, a HUGE knot was sitting in the way. Hmmm the slabs will be too long anyway, soo, cut the knot off. Had a second slab, smaller knot…..gone. Marked that slab to match the other one.
Needed to make four leg blanks….circular saw again..
This time, marked aline down the center, and cut the line, rotate, and repeat. Laid them down to mark the center line again
Then gave the bandsaw another try. Still had a wavw effect, but I could at least plane that away..
Got the saw marks planed off…..back is in bad shape, called it a day. Sawdust all over me, hard to see out of my glasses. Swept up the ankle deep shavings. Did a bit of laundry for the Boss….and went upstairs to MY chair. Had to “boot” the Shop Cat off MY chair, first. Heating pad set on BROIL, Mountain Dew in hand. It will do for one day…stay tuned.
7 comments so far
View TraylorPark's profile (online now)
TraylorPark
212 posts in 1561 days
#1 posted 01-04-2016 12:39 AM
I hope this is where we get to guess what the build is? If so mine is launch pad to get up on the loft bed. And it sounds like you earned that mountain dew.
Zach
-- --Zach
View eddie's profile
eddie
8565 posts in 2577 days
#2 posted 01-04-2016 01:16 AM
a cold one is well deserved ,thats a good looking #7 , cant wait to see the end
-- Jesus Is Alright with me
View robscastle's profile
robscastle
4873 posts in 2167 days
#3 posted 01-04-2016 01:41 AM
Wow some job, I neded a little lie down and a cold one after reading all about the work!
Now firstly the bandsaw,
First up thats a huge chunk for your bandsaw to swallow so its on max cut limits for sure, and looks to me its possibly time to spring for a new blade, or some ovedue maintenance, but I dont think that would be the case after looking at the condition the planes are in.
-- Regards Robert
View CFrye's profile
CFrye
10120 posts in 1803 days
#4 posted 01-04-2016 06:03 AM
Whatcha making, Bandit?
-- God bless, Candy
View bandit571's profile
bandit571
19713 posts in 2646 days
#5 posted 01-04-2016 06:06 AM
Just a small table….details still being worked out. Have one leg turned on the lathe, might get the others Monday.
View DIYaholic's profile
DIYaholic
19596 posts in 2638 days
#6 posted 01-04-2016 01:10 PM
I think you have rested long enough….
Whatchya gittin’ done today???
View Miataguy's profile
Miataguy
142 posts in 1238 days
#7 posted 01-04-2016 03:03 PM
Can’t wait to get up there myself and see that!
