End Table project #6: A test fit, and some assembly
Blog entry by bandit571 posted 07-29-2015 02:36 AM 991 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 5: Narrow end came out of the clamps... Part 6 of End Table project series Part 7: Final assembly, and aPIP? »
Moving right along, now. I checked the narrow panel end for square…..zero to 1/4” along one side, zero to 1/16” along the other side. Circular saw to rough the wider one back to square, not going to worry about the barely there one. Clamped the panel into the leg vise, added a clamp out in front, #5-1/2 jack plane to joint the edge. I think I can try a test fit of all the built-so-far parts..
As for that top laying under everything?, well, the #5-1/2 went to town on it, to get both faces flat(almost)
Okay, laid out a bunch of marks along the corner’s ends. 3/8” Forstner bit to drill some counter bores. Then a pilot hole. Apply a bead of glue on the non-drilled part ( held in place with a clamp or two) and then added a few screws.
Once all four corners were screwed and glued, I could stand this thing up on it’s own four feet
Added the top bar above the door opening. Then made a couple (for now) corner blocks to hold it in place
Screwdriver collection? Two screws and some more Elmers to hold things in place. I also added a cleat to hold a floor
I’ll run cleats all the way around. Need two more corner blocks made. I add a slotted hole in them, and attach the top that way.
hey, we are making a bit of progress…I think. Stay tuned…
2 comments so far
View DIYaholic's profile
DIYaholic
19623 posts in 2704 days
#1 posted 07-29-2015 10:14 PM
- bandit571
I would agree.
Staying tuned….
(even though I am tone deaf!!!)
View CFrye's profile
CFrye
10247 posts in 1869 days
#2 posted 07-30-2015 08:54 PM
Trying to catch up! Moving right along.
-- God bless, Candy
