Another pile of pine #3: Part 4: maybe a glue up?
Blog entry by bandit571 posted 04-04-2015 05:17 AM 1701 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 2: Part 3: mortise and tenons and dovetails, oh my! Part 3 of Another pile of pine series Part 4: Part 5: Top and a shelf »
Well, mosey back down the steps to the shop, GrandBRATS had showed up, and were acting acting…LOUDLY. Time for me to disappear…
Got the rest of the mortises chopped out. Went fairly fast, too. I then set about adding the rebate for the plywood shelf. Nothing too hard about it, at least for the short stretchers
Just set the Wards #78 to about 1/2” width, and a 1/4” deep. Checked the depth with a combo square on the plywood itself, too. As for the two long ones, they needed a jig or two to keep them still long enough for the plane to work
Had a block still screwed down to the bench, added a clamp to hold the far end of the board tight. And just plow away.
Ok, got all four pieces done. Rounded up every clamp in the shop. Time for a glue up
All that trouble to label which part went where? Right out the window….parts were close enough that little fitting was really needed. Had a split in the one leg, so some glue and a c clamp to the rescue. Couple places needed a little extra “motivation” to close up. Getting closer
Could have used a couple more clamps, IF I had any. sat it upright on the bench, grabbed the top, and placed it on the base…..and watched it rock and roollll. Hmmm, well happen to have a couple shorter clamps left over, clamp the top down to the base at the tops worse points
By golly we might be getting somewhere? Still have two drawers to build, the runners for them to slide on, and some way to attach the top. Oh , and figure the cuts to make to get a bottom shelf made, and get it to fit.
Not every day I get the entire day to play in the Dungeon Shop. Might have logged 6-7 hours in there today.
Stay tuned, more to come.
3 comments so far
Smitty_Cabinetshop
15369 posts in 2646 days
#1 posted 04-04-2015 05:25 AM
Doncha love long stints in the shop! Good for the soul, I think.
Table looking good, bandit!
View DIYaholic's profile
DIYaholic
19623 posts in 2703 days
#2 posted 04-04-2015 12:51 PM
Good thing I waited until after a good night’s sleep….
to view your progress. Now I need a nap!!!
In need of more clamps you say….
I think you may need to build some!!!
Carry on….
View robscastle's profile
robscastle
5109 posts in 2232 days
#3 posted 04-05-2015 04:19 AM
Ah pulled the Houdini act on the rels eh!
You are a cunning man! and very talented as well
Nice work on both accounts!!
-- Regards Rob
