Shaker Style End table #4: Glue ups. Just glue ups
Blog entry by bandit571 posted 03-08-2015 11:48 PM 1301 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 3: Front legs get joineried Part 4 of Shaker Style End table series Part 5: Getting things ready for a drawer.. »
And maybe a Dutchman, too. Got the top over to the cleaned off (!!!) workbench. Worked on fitting the two breadboard edges to almost no gaps. Add some glue, clamp it down
Until the gaps close up. Since this is a three board top, I used three 5/8” brads, in the center of each board. Set the top aside. Almost tripped over the Shop Cat
He is looking a little digusted with me, I am interrupting his Mousing,
Ok, top is out of the way for awhile. Took apart the base, and started to glue it up
This is the side with the OOPS in the leg. Got this end glued up, and then set out to make a Dutchman Patch. Dug up a scrap of pine that looked close to the grain, and almost the right size. A little trimming here and there until it almost fit. Coated with glue and drive it home. Then, trim the excess off until flush.
More on that in a moment.
Got the other side glued up. Sides will also get some 1” brads. Driven in from the inside, through the side’s tongue, and conter sunk with a nail punch. Then the juggling can begin. Brought both sides back to the bench, along with the rest of the parts. Glue everything that moves, clamp the whole mess and sit it on the floor.
Letting the glue cure over night. As for that Dutchman Patch?
You can barely see it, right beside the clamp. Then laid out a stretcher of sorts
Not only will this keep the drawer from tippng down, it will add a place to attach the top to. Take a good look.
As this will be the last of the handcut dovetails used in this table. The drawer will get a router and a jig to make the half-blind dovetails for the drawer’s front and sides.
Stay tuned, the building part is almost over….
5 comments so far
View DIYaholic's profile
DIYaholic
19539 posts in 2583 days
#1 posted 03-09-2015 12:49 AM
Nice progress, today.
A lot more than I’ve made….
in the last month!!!
View Slyy's profile
Slyy
2839 posts in 1563 days
#2 posted 03-09-2015 01:47 AM
Shop cats, hmmm mine knocked a chisel on the ground last week…
-- Jake -- "Not only do we live among the stars, the stars live within us." - Neil Degrasse Tyson
17567 posts in 1764 days
#3 posted 03-09-2015 01:57 AM
Lookin good bandit.
View CFrye's profile
CFrye
10042 posts in 1747 days
#4 posted 03-09-2015 02:51 AM
Must be something in the air…my work bench got cleaned off today too! Now if I could just get some work done like you!
-- God bless, Candy
View TheFridge's profile
TheFridge
8902 posts in 1394 days
#5 posted 03-09-2015 03:46 AM
I knew you didn’t just rehab planes all the time. Looks good bud.
