Shaker Style End table #1: Part #2 The top
Blog entry by bandit571 posted 03-06-2015 02:27 AM 1681 reads 0 times favorited 4 comments Add to Favorites Watch
no previous part Part 1 of Shaker Style End table series Part 2: Part #3 Mortise & Tenons...and aprons, too »
Well, did a bit of saw work today. Figured up I needed 3 boards @ 3/4” x 5-1/2” x 25” Circular saw did the work, after I had clamped the 8’ long plank in place. Had enough left over to form the back apron. Dry fit in the pipe clamps, looks good, spread some yellow glue around and clamp them up.
Later, after the glue had cured, started to surface the top.
A few handplanes to do the job. Had some “marks” on one board that needed to go…
This, and a big neon green crayon mark. Sand them off? Not when I have just the plane for the job..
A Stanley #70 Label scraper plane. Notice that the black marks are now gone?
Brought the other 8’ plank done, and cut some other parts out. Found a 1×2 for a breadboard edge. Cut it into two parts.
Kept the leftover section to use as a clamping jig, later. Ok, laid out some lines along each end of the top, about…1/2” or so in.
Using a brand new Harbor Freight square, It is even accurate! Set up a special plane, since I don’t have a tablesaw to do this next task. A Wards #78
You pull the plane back towards you about four times, so the spur can cut the line, and then let’er rip, as deep as you can push the plane along, until the depth stop says you are deep enough. Flip the board over, re-clamp it down, and do it all over again. Until both ends have a “tongue ” formed
And this is where I should have stopped for tonight, but….
The bread board ends need a groove cut. About a 1/4” by 1/2” deep. Thought the old plough plane was up to the task…..nope, got so frustrated with the sloppy thing, it flew against the nearest wall. And will stay there. Dug up the Craftsman router, and FINALLY found a 1/4” bit. Made a simple jig to hold each part STILL while I routed the groove….Edge guide was hitting the jig. Jig left the room, and two drywall screws and a bench dog took over. One screw to act as a stop, the dog took the one side away from the guide. A second screw was tightened against the side of the part. three passes to get the depth right. Test fit…
And THAT was that for today’s shop time. Needed a Mountain Dew, or three. I was just tuckered out.
Plenty of time to get the rest done, later. Stay tuned, I might try to chop some mortises for the apron’s tenons. Then, maybe, if things go right, a drawer just might get made….
4 comments so far
15249 posts in 2552 days
#1 posted 03-06-2015 03:02 AM
Against the wall, and there it will stay… Well, a tool that doesn’t do the job probably deserves some time to think.
Good progress, Bandit, looking good!
View CFrye's profile
10070 posts in 1773 days
#2 posted 03-06-2015 07:31 AM
This table is shaping up fast, Bandit!
-- God bless, Candy
View DIYaholic's profile
19580 posts in 2608 days
#3 posted 03-06-2015 02:52 PM
Bummer on the plane!
You are making me tired…. just imagining the pace at which you work.
I need a Mountain Dew or a nap.
Carry on….
View Slyy's profile
2839 posts in 1589 days
#4 posted 03-07-2015 12:36 AM
Bandit, your shop is organized chaos and I absolutley love it! I’ll stayed tuned for the rest of the story on this table!
-- Jake -- "Not only do we live among the stars, the stars live within us." - Neil Degrasse Tyson
