NOT your average screen door: Raised Panel work
Blog entry by bandit571 posted 10-14-2014 06:56 PM 1388 reads 1 time favorited 4 comments Add to Favorites Watch
Ok, last episode, I was getting a center stile made. Well, after measuring three times, the dang thing still was short. Yanked it out of the door frame, used it to mark another board. THIS time, I held the new blank to it’s new home, and marked things out, and cut leaving the lines. I needed to cut a groove on both edges of the now center stile. Clamped it into the bench vise, and gave this old boy a work out
First a little hammer work to center the cutter. Might have had it a little deep, too. BIG curlie things shot out from the side of the plane. You have to start at the far end, and work your way back. When it no longer cuts, groove is done. Then flip over, and do it again. Kind of helps to go with the grain, too.
Ok new center stile FITS, need to make them raised panels. I’m sure a router bit can do this, but..I don’t have one.
After marking out the size of the panel, a circular saw was used. I am not going to hand saw THAT much off
Well, at least it IS a vintage one. Next, layout some lines for the bevels
I mark out a line 1” in from each edge. There is a stop line to show how deep to make the bevel, as well.
Clamp the board so I am pushing aginst the bench’s long axis, and using a #5-1/4 Junior Jack plane
I also go at an angle to the grain, less tearout. A low-angle block plane to clean things up, rotate, and do the other end grain end. Then set things up to do the long grain sides.
Then do the other side. Next, I need a rebate on the inside part of the panels. A #78 plane works just fine for this. Same routine, the end grain end first, then the long grain sides. Almost to a knife-edge
Then place both panels in their new homes for a test fit.
Still need to draw-bore the joints closed, and add some wedges. Top half will just get a rebate, done with a router and a rabbitting bit. Corners will get cleaned up with a corner chisel, IF I can find mine, again
To think, all of this is going to get painted…...
Next up? Maybe some assembly? Stay tuned
4 comments so far
View DIYaholic's profile
DIYaholic
19623 posts in 2704 days
#1 posted 10-14-2014 09:09 PM
You need to get yourself one of them thar board stretchers!!!
View Mean_Dean's profile
Mean_Dean
6567 posts in 3176 days
#2 posted 10-15-2014 12:34 AM
I’m definitely staying tuned in!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
View Tugboater78's profile
Tugboater78
2746 posts in 2221 days
#3 posted 10-15-2014 12:57 AM
Git r dun bandit!
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View CFrye's profile
CFrye
10247 posts in 1869 days
#4 posted 10-15-2014 05:24 PM
”You have to start at the far end, and work your way back. When it no longer cuts, groove is done.”
(slaps forehead) Now THAT makes sense! Thank you Bandit for explaining that bit of plane use!
-- God bless, Candy
