NOT your average screen door#2
Blog entry by bandit571 posted 10-09-2014 06:30 PM 1830 reads 0 times favorited 4 comments Add to Favorites Watch
Well, after much cussing and fighting, got all the rails fitted to their mortises.
This being the last on this side of the door. Wound up making it an open ended affair. The lock rail took the longest, and I think I traced it’s ancestry back about ten generations…
Ok, when I go to assemble the door for the final time, I will install a few wedges into each tenon, then pin the joint with a couple of dowel pins.
Managed to measure for the center stile, and get the measurements for two raised panels. Decided to just do the two panels today. Cut a few boards to about 29-1/2” long, needed a little extra to trim to square. Didn’t have exactly the right width, of course, so a glue up of two boards each to make the panel blanks. Happen to have two LONG pipe clamps, long enough to span between the two benches. Not going to do seperate panels, when I have clamps long enough to do both at once.
I leave the lights out for now, and let the panels cook overnight. Next time down in the Dungeon Shop:
I have a center stile to cut upon. Two grooves and two tenons, with the 45 details, too. Need a groove cut into the bottom rail. Rip and size two panel blanks and get them ready to raise a panel out of them, with a hand plane, of course.
Maybe this weekend, I can get the other stile chopped and fitted? Worn out from all the cussing. About like a D.I. after the first day of Recruit Training…..Whew.
Stay tuned.
4 comments so far
View gfadvm's profile
gfadvm
14940 posts in 2565 days
#1 posted 10-09-2014 08:15 PM
Looks like some “industrial strength” joinery!
View DIYaholic's profile
DIYaholic
19487 posts in 2550 days
#2 posted 10-09-2014 09:24 PM
With all the cussin’....
While you were cuttin’....
It’s no wonder why you are making such strong joinery.
Once this door is complete, it won’t be coming apart….
Hence there will be no more fussin’!!!
View Mean_Dean's profile
Mean_Dean
5832 posts in 3022 days
#3 posted 10-10-2014 12:06 AM
This thing will probably outlive the house….........!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
View stefang's profile
stefang
15726 posts in 3209 days
#4 posted 10-11-2014 11:35 AM
Sounds like belts and suspenders type joinery. No harm in that. It should last at least another 10 generations!
