Dungeon Shop Rehab Center: Stanley Plane
Blog entry by bandit571 posted 05-12-2014 08:19 PM 1599 reads 0 times favorited 5 comments Add to Favorites Watch
A very Rusty & Crusty plane showed up today. Under all that gunk is a Stanley T19, #5-1/2 jack plane.
Yeah, right. A few more looks before the trip downstairs
Iron and lever cap need a bit of clean up
The handles are solid, no cracks. Paint might need a touch up, maybe. Hauled all the parts down to the shop. Took the plane apart. I managed to get every bolt out, but one. That little one holding the clip on the back of the frog. Frozen tight. Oh, well, it can just stay put. Wire wheels into the drill press. knocking off as much rust as I can. Bolts were cleaned up, and a light coat of oil added. Put all the small stuff into a tub
This is so they don’t wander off somewhere. There assembly for the tote bolts was getting a good cleaning, when, ZING! It takes a trip to the far wall. Grrrr,#$#@#$! Found the part, clamped it into a pair of vise grips. Part is now bright and shiny.
Next, that nasty looking base. Beltsander’s belt was a bit too worn out for this thing. Palm sander, and some 120 grit paper made a dent in the nasty stuff. After two sheets, a strip of fine emory cloth was used under the sander.
Ok, looks a bit better. Sole was flat to begin with, just rusted a bit. No pitting, though. The sides got the same treatment. Not planning on this as a shooting plane, so not too worried about being square to the sole
Frog’s face will be next, after a small wire brush wheely thing worked on the inside of the base ran the frog along the belt sander a bit. Worn belt wasn’t going to get too rough with it. Face all cleaned up. Wasn’t the best casting job by Stanley. Lever cap all shined up, chipbreaker cleaned up. Iron was cleaned, back checked for flat ( it was almost dead flat) and the edge renewed. Put the parts back together, for now
Well day one is done. Have a yard to mow, and stuff like that. The handles can wait until tomorrow. They will get a sanding first. IF I see something good under that black paint, I might strip the paint off. Otherwise, back in black…
Stay tuned…
5 comments so far
View racerglen's profile
racerglen
3112 posts in 2683 days
#1 posted 05-12-2014 09:16 PM
Nice score Bandit, looks like a pretty “easy”job ;-)
-- Glen, B.C. Canada
View Handtooler's profile
Handtooler
1497 posts in 2035 days
#2 posted 05-12-2014 09:16 PM
Great start to what will certainly be a user. Gonna camber the iron?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
bandit571
19158 posts in 2586 days
#3 posted 05-12-2014 10:09 PM
Iron had just the corner cambered, left it that way. As for the handles, just didn’t like that black painted wood, tain’t right. So
We’ll try some “Naked” handles on for size
Waiting on a bolt to arrive from a FRIEND INDEED
Yeah, THAT bolt. Iron has been gone over, might finish it up later. One more look
Install the missing bolt, final sharpening of the iron, and then maybe some shavings?
View DIYaholic's profile
DIYaholic
19535 posts in 2578 days
#4 posted 05-12-2014 11:46 PM
Nice clean up….
So, whatchya gonna do with this one??? ;^)
View ejvc's profile
ejvc
107 posts in 1863 days
#5 posted 08-06-2014 12:02 PM
Nice looking rehab for sure!
-- Building stuff with my daughter (6). Pretty new to woodworking, I mostly sew...
