Small Pine table, with a shelf
Blog entry by bandit571 posted 11-01-2013 05:28 PM 1376 reads 0 times favorited 4 comments Add to Favorites Watch
Found a few boards to use. Got the one 1×6x60” cut down into three boards. Glued up into a panel, and then flattened with a couple handplanes. I have a large, plastic tub sitting under the bench, to catch a few shavings
Between the top, and a pine shelf, it got full kind of fast. Sawed a couple found 2×4s into some leg stock. Plan (Plan, I have a plan??) was for a notch about halfway up the legs, to house a shelf. Grabbed a small saw, and knocked off a corner on the shelf, first.
I saved that cutoff, to use as a pattern. I cut the other three corners, and set the shelf aside for a bit. Used the “pattern” to layout how much of a notch to make on the leg. Same saw to cut the lines
Then a bit of work with a chisel and mallet to clean out the notch. Then a test fit
Then just kept cutting notches, and test fits until done
Drilled a pilot hole for a screw to hold each leg. Drywall screws for now, have some fancy SS ones for later. Next up, I grabbed an old sabresaw ( freebie, found in a basement clean up) for a bit of edge work
Hey, the price was right, anyway. The top gets a wavy edge treatment, so, I had an old apron to use as a pattern from a walnut reclaim project. Laid out some lines on the top, clamped it to the bench where I could saw two edges at a time.
Then I rotated the top and cut the other edges. Assembled the legs and shelf, and place it on to the top. I needed to measure for the sizes of the aprons
Once I get those new aprons cut and ready, I might either leave them square, or cut some fancy stuff on their edges, too. Might be a while on this table….
4 comments so far
View SamuelP's profile
SamuelP
793 posts in 2608 days
#1 posted 11-02-2013 09:08 PM
Nice progress..
-- -Sam - FL- "A man who carries a cat by the tail learns somthing he can in no other way" -Mark Twain
View DIYaholic's profile
DIYaholic
19596 posts in 2637 days
#2 posted 11-03-2013 10:36 PM
I have a very similar “Big White Box” (5th picture) in my shop!!!
BTW: Nice job on the table so far!!!
On the edge of my seat, awaiting an update….
View Rick's profile
Rick
9413 posts in 2995 days
#3 posted 11-04-2013 09:21 PM
”Might be a while on this tableā€¦.”
Oh. That’s okay. Take Your Time. We can Wait.
-- LIFE is what happens when you're planning on doing Other Things!
View bandit571's profile
bandit571
19707 posts in 2645 days
#4 posted 11-07-2013 07:24 PM
Everything is now in a dry-fit mode. Might just get this done this weekend….
Now, IF I can find enough AAA batteries to at least take a couple pictures of the table…..
Camera seems to eat the darn things like candy…
