Dining Room Table...BY Suppertime?
Blog entry by bandit571 posted 07-07-2013 01:21 AM 1370 reads 0 times favorited 6 comments Add to Favorites Watch
Yup. had a pair of legs already tapered on two sides. Got the other two legs done by noonish. Tapered with handplanes only, mind you. Set up a “work space” such as i have.
A washer & dryer served as a staging area
And laid out a few toys, er tools.
That little piece of paper? THAT is all the “plans” I had, just the measurements for the aprons. Made tenons on one of the short aprons ( 24-1/2” long 1×4) so I would have a pattern fot the mortises in the legs. laid out the lines
And chopped down a starter hole/stop hole. Next a saw
Long ago, I gave up on that little piece of wood at the top of a leg mortise, so, I just saw down to define the waste
Use a chisel to pop the waste out, and pare the mortise square. Then a check for fit
Then rotate to do the other mortise. Then sine the leg was in the vise, did a clean up
of the leg’s sides, and got rid of the layout marks, finally put a slight champfer on the edges. Legs were about done
So, I got the rest of the tenons cut on the aprons. Tried out a shoulder plane, well I used like one anyway
Apron routine: Lay out one line 1/2” in from the end. Take a handsaw, take 7-8 level strokes, check for depth of cut. Take a wide chisel, pop off the waste. Pare tenon smooth. Flip over and repeat for the other side. Short aprons were ready for a glue up
Glue, clamp, and two finish nails per joint. Both short ends are done ( it is now 3:00!) Time to work on the long longs. Aprons get a slight round over by using just a hand plane. The long aprons get a stretcher between them. So, a Dovetail was cut
Measured acroos the assembled (dry fit) base to get the length of the stretcher itself. Cut the matching dovetail. Got everything Glued up, clamped up, stretcher installed.
Cut and fitted corner blocks. DDrilled for the screws to attach them. Everything secured? Take the clamps off ( AFTER having another Mountain Dew, of course) Carry this “thing” up the Dungeon steps, beat on the door to get it to open, waddle through the Kitchen, place the base onto the table top. Top was just sitting on a card table.
Screwed off one side. Found out the other side was out of square ( Did I do that??) so, back down them stairs, grab a long clamp, trudge back up and pull the side square, and THEN screwed that side off. Four screws in the strecher, one in each corner block. Flipped this thing over, got rid of the card table, place the “new” table in just the “right spot” ( according to the wife) Placed the two existing chairs under the table. THEN I get to go fry up some supper. Time? 6:30 pm!
6 comments so far
View Buckethead's profile
Buckethead
3194 posts in 1776 days
#1 posted 07-07-2013 01:30 AM
This is a charming project. The final shot is great. Love the puzzle on the table. It suggests a wonderful evening shared with a loved one.
-- Support woodworking hand models. Buy me a sawstop.
View gfadvm's profile
gfadvm
14940 posts in 2597 days
#2 posted 07-07-2013 01:30 AM
That is a very impressive day’s work.
And a nice table.
I like the ‘open top’ mortises and will steal that idea.
View whitebeast88's profile
whitebeast88
4128 posts in 2097 days
#3 posted 07-07-2013 01:39 AM
very nice build,i thought building a doll bed for my daughter was doing good today (except for paint) but you put me to shame.great job and i also like the open top mortise.
-- Marty.Athens,AL
View Gary's profile
Gary
9298 posts in 3340 days
#4 posted 07-07-2013 01:39 AM
I got tired just watching all of your hard work. Good job. What’s for supper?
View DIYaholic's profile
DIYaholic
19538 posts in 2582 days
#5 posted 07-07-2013 02:09 AM
Yeah, yeah, yeah….
It ain’t DONE….
‘Til it’s FINISHED!!! ;^)
Nice days work. Was the wifey happy, as we all know that is all that matters!!!
Now what did you do with MY Mountain Dew???
View bandit571's profile
bandit571
19215 posts in 2590 days
#6 posted 07-07-2013 02:56 AM
Drank them, of course. Then had two more with the fried egg and baloney sammiches.
Wife hasn’t said what finish she wants, YET. Sure it will be something or another.
Top was a Yard Sale Freebie, walnut was already in the shop. had to buy some pine for the aprons, and some screws. Basically one afternoon in the Dungeon Shop….
