Vermont Lap desk, part three
Blog entry by bandit571 posted 04-17-2013 07:05 PM 1258 reads 0 times favorited 3 comments Add to Favorites Watch
Ok front dovetails are done, just need to be planed true. Next is the back corners. Don’t intend to waste a dovetail back there, so.
Laid out for a rabbet/dado joint on the back corner of the sides. Sawn to the lines
and then a chisel to remove the waste
By driving the chisel in the end grain. Pare smooth, and do the other end
Next, I use the actual rabbet to mark out a dado in each side. Try as i like, neither rabbet match exactly to the other, joy of hand work, I guess. Anyway, laid out the location of a dado
( the way I am around sharp objects lately, a pencil works here) Clamped the piece to the “bench” so it wouldn’t move during the next steps
Used that back saw to try and just split the pencil lines, i sawed down to the bottom of the dado. I start the saw at the back of the cut, and slowly lower it until it is level in the cut. Checking to make sure i am still in the lines. Next step:
A 1/4” chisel , and a mallet. Knock out the waste between the lines. Then pare to get a fit.
First one was a bit loose. Sharpened pencil, and did the second dado. Time for a test fit of the four sides?
Just a little more progress made? next up? Maybe a bottom? Attach the top pieces? Decide what looks good on Ash? Oh, almost forgot, need a pencil groove…
3 comments so far
View bandit571's profile
bandit571
18890 posts in 2553 days
#1 posted 04-19-2013 01:59 AM
The way the “plan” looks right now:
Glue the four sides up
Plane them all coplaner, and smooth the corners
Use a router to make a rabbet around the bottom edges, and square the corners
Add a piece of 1/4” Oak plywood in the rabbet, with brads and glue
Add the fixed part or the top, with screws, and plugs to cover them. This will be after a bevel is planed to match the lid’s angle. Mortise for two Brass hinges.
Use a hand plane to cut a pencil groove.
Round-over most of the edges.
BLO/Poly finish.
Sound like a plan???
View DIYaholic's profile (online now)
DIYaholic
19483 posts in 2545 days
#2 posted 04-19-2013 02:15 AM
Sure sounds like one to me!
Time will tell if it is a good one!!!
I’ve no doubt that it is indeed a fine plan!!!
bandit571
#3 posted 04-19-2013 02:38 AM
Spent some actual money on this project tonight. Supplies cost almost $18 at Home Depot.
have all day tomorrow to work on it, IF I want to. have to wait around on a Gas Co. guy to restart the gas lines.
