Not so cheap Walnut Table, part two
Blog entry by bandit571 posted 04-01-2013 10:00 PM 1472 reads 0 times favorited 2 comments Add to Favorites Watch
Ok, salvaged some parts from an old junk table that was being tossed into the trash. Got four legs, and a couple aprons to use as a pattern.
That pile of rusty hardware will be tossed out. As for patterns
Might keep them around for other table projects. Laid out the aprons on some walnut
Traced them out, and got ready to saw them out
All clamped up and ready to saw? not quite, needed a square end to start things better.
Handsaw? Well, stay tuned, it will be back in a little bit. Got out the “Green Saw” and started to cut the aprons out
Halfway there, working on two aprons at a time
Short apron is done, need to finish the long one
Long one done. You can see how much waste is left over. One 30” long plank at 6” wide, made a short and a long apron. Reset everything, using the sawn aprons to trace out the next set. Same set-ups. After all were cut out, time for a little hand plane work. Since the planks were still rough sawn, decided to smooth the aprons out. A #6 and a #5-1/2 were used to level and smooth the edges and the faces
Once each side was almost smooth, a trip with a smooth plane was then used
Next, maybe some work on tenons? marked out for 1/2 tenons and sawed down until the teeth are just below the surface
A nice sharp, wide chisel splits off the waste
pare until flat and smooth. Repeat until all three sides of the tenon are done
Stack the parts on the bench.
Take a break, and get ready to work on the legs, later.
Well that is all for now, stay tuned for the next round of table work…
2 comments so far
View DIYaholic's profile
DIYaholic
19490 posts in 2551 days
#1 posted 04-02-2013 03:20 AM
Great find on the legs & aprons.
I get tired just thinking about how quickly you knock out these projects!!!
OK, ya gotz…
legs….
apron….
What about a skirt??? ;^)
View Kreegan's profile
Kreegan
1452 posts in 2023 days
#2 posted 04-02-2013 12:35 PM
Looking good, Bandit!
