The two planks that made up the top, were a bit cupped, gluing them up into a top didn’t help out much. Although I took the top out of the clamps
I still kept them handy. I used two of the pipe clamps to hold the top steady whilest i did a little flattening
The one face wasn’t too bad, so just a wide Jack plane to level the field, and a smoother to, well, smooth things out
Flipped the top over, as I wanted both faces cleaned up. I hadn’t decided which face would be the top one. After i flipped the top over to reveal a….mess. Decided to scrub things down a bit
by going at a diagonal with a cambered #5 Jack plane. Scrubbed things down, and decided to use the larger planes as smoothers
I went end to end with these big guys. I had two #6 Fore planes, so why not try them both out?
Then a follow up with a regular smooth plane, just to hit the high spots
That’s enough for tonight, whew. Next up? Making some aprons.
4 comments so far
DIYaholic
home | projects | blog
7578 posts in 872 days
#1 posted 119 days ago
Next up aprons?
Are you working on a kitchen table or working in the kitchen???
-- Randy-- I may not be good...but I am slow!
bandit571
3844 posts in 881 days
#2 posted 119 days ago
Need aprons to keep all the shavings off of me…
TV Table will be for grandson’s bedroom. Why he needs a 42” tv in there…...
racerglen
1714 posts in 978 days
#3 posted 119 days ago
Maybe he likes chanell surfing ?
Better make sure you know which ones ;-)
Nice work Bandit.
-- Glen, Vernon B.C. Canada
bandit571
#4 posted 119 days ago
Went to the Dungeon this afternoon. No wood available yet for aprons. I did get the edges beveled, though. Both ends first, after squaring the ends with the saw. Used a #3 plane to start the bevel, and a block plane to smooth it out. Also worked on saw marks on the ends. I then took Ye Olde Numbah Six and started the bevels on the front and back. Cleaned the areas around a knot with a #3, and finished up with a block plane. Ran my hand over the top’s surface, and found a few rough spots. Time for a little smoother action
There was a “hump” running down the middle. Was. I also ran a smaller smooth plane around a few knots
I HATE knots! I also used a block plane for some other clean-up work. A few of the plane’s passes left behind little nibs
So a #18 “Nib-be-gone” plane took care of that. The bevel clean up?
When one has a couple of these little planes, one tends to use them. Stay tuned, I MIGHT have a few boards tomorrow…
