Refurbbing Rusties
Blog entry by bandit571 posted 02-12-2013 08:11 PM 2793 reads 0 times favorited 9 comments Add to Favorites Watch
I had three planes, mainly from two rust hunts. A Dunlap, with red handles
That i decided to strip the red off of.
Two others were in need of the “Works” handles stripped, one tote repaired, irons sharpened back up. All manner of rust removed. Ok, “Velcommen to Mein Dungeon”
This little machine does a lot of removal work, weather it is rust on a plane’s side
Rust on an iron
Stripping a finish off a knob
Note that ugly brush laying there? That takes off the finish on the rear handles, aka Totes. Set up the sharping station
I had a second use for the belt sander. I went from this
To a bit cleaner look, like this
This is the base for the Worth #4. I already had sanded the bottom of the Hibbards True Value #3. The sander had another duty to do.
I set the angle for each iron, and sanded away. Remove the sander from the vise, install the first of two oil stones. Flip to use the finer grits and on to the next stone’s two sides. Starting to look better. Made a sanding block to fit in the vise. It was to hold some 1000 grit wet&dry paper. A spritz of 3in1 oil, and do the irons. Time to assemble the three planes.
I know why people hate these pressed steel frogs, er, Toads. The two bolts are a ROYAL PITA to put back in place. lost one bolt into the sawdust on the floor. I had a “spare” though, and the toad was tightened down. Set up a test track
Some nasty looking Oak/Ash. Tried the face side first
Then I tried the edge grain with the Hibbards True Value #3
Note the repaired tote. Wheel to adjust the depth is solid steel, not brass. Handles have one coat of BLO.
This is the Dunlap #3, sans red paint on the handles. Haven’t decided to re-paint them, or just add a coat of BLO?
A Millers Falls #8. With the thick varnish removed from the handles. Almost ready for the BLO on them. The Worth #4 and the Hibbards True Value planes were a “package deal” for $25. The Dunlap#3 was about $8 + tax. The M-F #8 was about $22.00 + S&H. Other than adding a finish to a few handles, I think I am done.
They don’t look too hatefull???
9 comments so far
View Kreegan's profile
Kreegan
1452 posts in 2201 days
#1 posted 02-12-2013 09:38 PM
Those look pretty good, Bandit. Nice work!
View poopiekat's profile
poopiekat
4364 posts in 3789 days
#2 posted 02-13-2013 12:38 AM
Great work, bandit! I like the look, the stained iron old locomotive look on a vintage handplane. I prefer to just disassemble the pieces and clean them up a little, removing only the red rust which might stain a raw wood surface. If and when the day comes that I want to prepare some planes to sell, then I will go for that ‘over-restored’ look to bring in maximum dollars. I could never bring myself to use a shiny new restoration. Those would have to go into the ‘trailer queen’ category. A ‘Worth ‘plane is high on my wish list, I don’t own one of those, or an Armstrong, either! Nice work!
View shampeon's profile
shampeon
1775 posts in 2238 days
#3 posted 02-13-2013 01:10 AM
The goncalo on the MF looks so much better without the red varnish, eh? Looking good.
I say BLO the Dunlap knobs and totes.
View DouginVa's profile
DouginVa
490 posts in 2327 days
#4 posted 02-13-2013 01:11 PM
Have you tried electrolysis? While the goop that floats to the top is disgusting I think overall it’s a much more effective process and the end result is better.
-- Just a man with his chisel.........
View bandit571's profile
bandit571
20470 posts in 2737 days
#5 posted 02-14-2013 02:46 AM
handles now have a coat of that “Smelly Stuff in a Blue Can” (BLO) applied nad cured.
A Dunlap #3. Last seen wearing bright RED painted handles. Now handles have just a coat of oil..
Hibbards True Value #3. I have since traded out the rear handle, for a better looking one. I will keep the old one as a spare. Next
This big and long fellow is a Worth #4. @ 10-1/4” long, it is a biggie, for a #4. Handles have one coat of oil. I also re-finished a Millers Falls #8. The handles had a thick red varnish on them, covering up the Gancolo wood used as handles.
As for chemical stripping/cleanng? I tend to try to do with out any chemicals in the shop. Grand kids like to run around in there. Shocking the parts would be nice, IF one had the “shocker” to begin with. I don’t. Need the $$ for other items…
View gawthrrw's profile
gawthrrw
207 posts in 2501 days
#6 posted 02-14-2013 02:50 AM
Looks Great! Good job!
-- Rob, Dallas TX
View DIYaholic's profile
DIYaholic
19624 posts in 2729 days
#7 posted 02-14-2013 03:12 AM
Igor has done a very nice job on them monsters!!!
If you want out of the dungeon, you come play, err work in my shop, I’ll only carge a modest fee….
I have 4 planes that need some TLC!!!
poopiekat
#8 posted 02-16-2013 07:22 PM
bandit: I’m wondering whether anyone has tried “The Works” bathroom cleaner for removing rust. It was written up in a review here a couple of weeks ago. I can’t find it on the shelves here in Canada… http://lumberjocks.com/reviews/3237
bandit571
#9 posted 02-16-2013 10:13 PM
Seems i need to post a photo of the Hibbards True Value #3 with it’s “Brand spanking new” tote
Shavings in old Oak, no less. Two of the planes, from one store
Got them as a two-fer. Instead of $35 for each, cost went down $10 when sold as a pair. Looks good to me
Keepers???
