Trying to build a cheap table
Blog entry by bandit571 posted 01-30-2013 02:27 AM 1726 reads 0 times favorited 9 comments Add to Favorites Watch
I have some reclaimed boards, including some rclaimed waterbed frames. Daughter wanted a small “Dinette” Table built.
Got one plank up onto the “bench” I now have. i needed to flatten it down, and then rip some leg stock out of it.
a cambered iron jackplane took care of all the weather stuff, then a few other planes to smooth the plank out. Laid out for the first blank
That is the plank. i had a “new” saw to do the rip cuts with
I figured i could get all four legs out of that plank. The last cut, well, i had a pair of screws going through the waste part, because the was about 1/2” of wood left after all the cuts.
Front two legs were to get two sides tapered. From about 7” from the top, the taper goes from 1-3/8” down to 1” at the bottom. No tablesaw, bandsaw won’t work. Guess it is time for some plane work, again.
My “Straightedge”. After getting rid of any saw marks, and other dippity dos, I laid out the taper. Next, starting at the foot of the leg, and working my way back up the leg, a taper soon appeared.
One final pass, and the taper is smooth as can be, no sanding needed.
Ok, after all the tapering was done, and the other two (back legs) were cleaned up, time for the aprons. I had some old Oak/ash sort of boards. Matched the legs, anyway. Started by cutting them to length
Laid out some curves
And cut them out with a Sabresaw
That “benchtop” is actually the table’s top. I had those Watrebed frames, and used one of the long sides. Cut into two 36” slabs, glued up, and then handplaned smooth. It will serve as a bench until I get things done.
Next, needed some tenons cut on them aprons. Again, no tablesaw to make them nice and quick. So, Old School Time. Lay out some tools
Laid out the tenon
Sawed the tenon
Used a chisel to”pop” off the waste
Repeat as needed until all the aprons are done
Next up Some mortises need chopped out. Base needs to be glued up. corner braces need cut, and installed, and THEN maybe get the top on? Total out of pocket, so far? $0.00 Love it.
9 comments so far
View gfadvm's profile
gfadvm
14940 posts in 2598 days
#1 posted 01-30-2013 02:38 AM
You hand tool wizards just amaze me!
Smitty_Cabinetshop
15133 posts in 2526 days
#2 posted 01-30-2013 02:47 AM
Very cool, Bandit!
bandit571
19225 posts in 2591 days
#3 posted 01-30-2013 02:55 AM
Amazing what happens when there is no big machines to do the work, ain’t it?
Wizard is it now? Nah, just keeping my hands busy. Therapy so I can get back to my “Day Job”.
Give me a few more days, i might have this done….
116906 posts in 3485 days
#4 posted 01-30-2013 03:02 AM
Good progress.
View Kreegan's profile
Kreegan
1452 posts in 2054 days
#5 posted 01-30-2013 01:33 PM
Looking good, Bandit!
View Dallas's profile
Dallas
3599 posts in 2395 days
#6 posted 01-30-2013 02:33 PM
Two questions:
How much noise does picture number one make and where is the cord?
View DIYaholic's profile
DIYaholic
19539 posts in 2583 days
#7 posted 01-30-2013 03:11 PM
CHEAP, is NO way to describe your table!!! That is a quality hand crafted piece. Great start! Looking forward to the project posting!!!
Inexpensive, free & “value made” are exceptable terms!
Now then, if we are talking about you…....
View helluvawreck's profile
helluvawreck
30164 posts in 2774 days
#8 posted 01-30-2013 03:12 PM
Nice going, bandit. Hand tools in the right hands can always work wonders.
helluvawreck aka Charles
bandit571
#9 posted 01-30-2013 05:04 PM
Dallas: Q#1 Kind of makes “schweeesh” noise.
Q#2 Cord? I KNEW I was missing something! Must be one of them new-fangled “cordless” models. ;-))
Thanks for looking in on my little project.
