Managed to get out to the barn today. Needed to work on a desk’s top. Started out with a scrub plane to level the glue joints. Then it was the Jack plane’s turn. After that, a smooth plane went to work.
Stanley handyman #4, with a shaving. Why all the handplane work? Sandpaper costs money. Anyway, i worked the top down to as smooth and flat as i could
next it was time to set-up for a breadboard edge. Done with the Tablesaw, This was after i handsawed the ends square, had to test out the newly sharpened saws, afterall. Anyway, needed to set up a dado cut
Roughly 5/8” wide. The height of the blade is 1/8”. THIS is how I set-up the saw. Strip of wood hides about half of a cutter. C-clamps also help hold the piece down. Seems to work ok..
I then cut the matching grooves for the edges. A test fit:
Also done out there today, both lower drawers got their dovetails routed in, a groove for the bottoms done, dado for the back of each drawer. Oh yeah, since I did remember to bring a box of screws along, center divider is now screwed, and glued in place.
Also done out there today. One saw handle run through the round-over station on my router table. Sanded smooth, and ready for hardware. A second saw needed some “bolts’ to start life as a “Toolbox’ saw. Rethreaded some 1/4” x 20×2” long hex head bolts. Installed the bolts and ground the excess off. Sanded the handle down
all it needs is some sort of finish. Blade was an Irwin ( I think)not a newer “Hard Tooth one either. Handle is by Disston.
3 comments so far
davidroberts
home | projects | blog
952 posts in 1654 days
#1 posted 400 days ago
nice breadboard ends. sp is overrated. if you soak those saw burns with mineral spirits a few minutes, they will soften right up and much easier to remove. That is a dry fit, right?
-- david roberts, spinning Tales from Topographic Oceans, no, really.
bandit571
3643 posts in 852 days
#2 posted 400 days ago
Very dry fit. just some screws from underneath, in slotted holes. I’ll spokeshave the burn marks next time out there. Trying to find out WHERE I left a pair of wooden knobs at…...
Not all them black marks are burns, some are nails, and some still have a nail in them. Added ballast so it won’t tip over.
bandit571
#3 posted 378 days ago
Desk is now in the house, and getting use to being there instead of a pole.
I couldn’t find those “store bought” knobs, so I wound up making a couple from some walnut scraps…
as for them ugly legs, the BOSS seems to like them…
well, still need a finish to match the hutch, that will be later…..
