That OddLots Ad #2: Starting up
Blog entry by bandit571 posted 09-07-2018 11:47 PM 375 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 1: What the boss wanted... Part 2 of That OddLots Ad series Part 3: 1st panel glued up »
Ok, these were hauled to the shop…took a couple trips..
All five needed to be cut down to around 41” long..leaves a bit to trim on the ends when done..
Marked out a cut line, trying to get the “best” of the board IN the 41”...the rest will be on stand-by for smaller parts
Worked my way down the stack…each board was set up on a pair of scrap pine boards, and the a clamp to hold them all still, while I cut the excess wood off….
As much as I like my handsaws…this wasn’t the time for them…I also snapped a couple lines, after I had found the chalk box..
Thinking that the bandsaw could at least follow the blue lines? Wrong…it followed ( or tried to) the grain….wavy cuts, like it was afraid to even get any of that blue on it’s blade…
Ganged the two parts up….and tried the #8 Jointer..It was just hopping along, hitting a high spot, now and then.
Got out a jack plane, to bring those high spots down a bit, so the jointer could plane the entire edge…
About time this fancy plane saw some real action..
Yes…it IS a jack plane. Once it was done, a few full length passes with that HEAVY #8 to get a straight edge.
So, now I have four 1×6 x 41”s for two panels….ends of the cabinet. The two narrow boards are fillers to be glued between the 1×6s
Used one of the narrow boards to mark a straight edge on each of the 1×6s….then decided to lay out one panel..
back was hurting..decided to take a break, for a while….all four 1×6s will need their edges jointed, in order to do a glue up…
Stay tuned….
2 comments so far
View lew's profile
lew
12424 posts in 3953 days
#1 posted 09-08-2018 12:39 AM
That’s a bunch of boards!
Rick Dennington
6295 posts in 3392 days
#2 posted 09-08-2018 02:32 PM
Looking like you’re making some good progress on the cabinet….I’ll be keeping up with your postings to see how this turns out…..Stellar job so far….!!
-- " At my age, happy hour is a crap and a nap".....!!
