15K views 39 replies 6 participants last post by  bandit571
#1 ·
Starting up
Ok..just can't seem to sit around all day…gets boring. Daughter asked about building a smallish, 3 drawer Chest of Drawers for GrandBRAT #5…...so…Mean Old Grandpa gets to do the build. Trying to keep things rugged, but simple….9 yr olds are a bit rough on things.
Wood Wood stain Hardwood Gas Lumber
After being told that Menard's was too far of a drive, and to go to Lowes…the Boss got sticker shocked….1×2 x 6' that cost 3 times what a 1×2 x 8' did …..was going to glue up the side panels and top….but not at what they wanted for 1×10s and 1×8s….found these glued up panels….appeared to have been cut-offs from longer panels….price was right…..saves me a little time with glue ups. Bench was a mess…
Wood Motor vehicle Tool Engineering Gas
That I needed to clear off, before things could get started..
Motor vehicle Vehicle Wood Naval architecture Automotive exterior
Had to drag a mitersaw out, and get it ready for work….
Table Wood Tradesman Artisan Workbench
I use this smaller Stanley #2246 box, to cut lumber for length….I had bought 4@ 1×2 x6' and one @ 1×3 x6' thinking I could use those for the webframes..and a start on a face frame….got to looking at the two panels for the sides….3/4×12 x 36".....might tend to be a bit tippy?
Wood Saw Tool Gas Workbench
Saw was ready…1×3 was cut in half….then glued to the edge of each tippy panel
Wood Lumber Hardwood Gas Plank
I set both aside. Then the 1×2s were cut down…
Wood Composite material Engineering Gas Tradesman
Needed eight parts, 25" long…..which didn't leave much left over to make the 12-1/2" long ends of the four webframes…
Wood Lumber Hardwood Plank Engineering
What with chopping out them knots…..dug through the scrap piles, looking for enough pieces that were long enough, wide enough, and at least thick enough to go with the four I got from the leftovers..
Wood Urban design Composite material Hardwood Roof
Some needed resawn down, some needed planed down for width and thickness….even had a couple Ash parts
Wood Plank Hardwood Lumber Wood stain
Laid out for 1/2" long tenons…set up the larger mitre box depth stops to make the shoulder cuts..
Wood Composite material Hardwood Plank Flooring
The one with the tenon done is the "prototype"...helped lay out the rest. Bandsaw to do the cheek cuts..
Table Furniture Wood Desk Wood stain
So..I ended the day with the tenons done..
Wood Machine tool Composite material Hardwood Gas
So..next time on this "Bat Channel" I will chop a few mortises….at least I can set down, doing that..
Wheel Automotive tire Motor vehicle Wood Stool
Hmmm, need to clean it off, first.
Stay tuned, part 2 is on the way. I need to get this project done before the 18th of July..then I go on the "D.L." for a while. I even have to work on Mondays!
#2 ·
Starting up
Watching this one.
#3 ·
Mortise work
Ok, time for some sit-down work..
Wood Wood stain Hardwood Gas Rectangle
Cut-resistant gloves…to keep me from getting cut, by these things
Wood Gas Tool Hardwood Flooring
Set things up to chop a few mortises..
Wood Gas Engineering Machine tool Machine
Why the backsaw? These mortises, being right on the ends, I use a little different way to chop them out..
Wood Gas Composite material Hardwood Brick
I use the tenon that will go here, to lay things out…
Wood Metalworking hand tool Gas Machine tool Machine
Backsaw to make an angled cut….I also "pull" the toe of the saw back a few times from the back corners..
Wood Trigger Air gun Metalworking hand tool Gas
Then a chisel to dig a hole at the far end….turn the chisel around..
Wood Metalworking hand tool Tool Gas Bumper
And pop the waste out. Pare the bottom of the mortise until a dry fit…fits..
Wood Machine tool Gas Milling Machine
Then mark to keep track of which part when where..
Wood Metalworking hand tool Stonemason's hammer Tool Saw
Why two marks?
Wood Gas Engineering Machine Toolroom
Because it was the second one done for this frame….goet all four corners done, then some glue and clamps
Wood Gas Machine Engineering Metal
And a pair of nails..
Wood Plank Hardwood Wood stain Composite material
Piece of scrap iron, so IF the points of those 3/4" long nails should happen to come out the other side…they will get re-directed" back up into the wood. Got two frames done, and was starting on #3..
Wood Flooring Floor Plank Wood stain
Noticed things were a bit…"off" Once #3 frame was done…I c clamped the first two together,,,trying to flatten out the "warp" going on…...SNAP!! One tenon had snapped off….NOT in the mood to make a new part….got out a few other toys….
Motor vehicle Wood Hand tool Metalworking hand tool Tool
Pilot hole drill, countersink drill, and a small screwdriver…hammer was a "In case of.."
Backsaw Wood Saw Metalworking hand tool Hand tool
3" long #6 screws…..one into each corner..needed candle wax on the threads.
Wood Gas Engineering Machine Auto part
I was going to go ahead and add screws to Frame #3…..was getting close to throwing things…so, I just hung the frame out of the way…..swept the floor, and closed the shop for the rest of Sunday…
Was out of the 3" screws, anyway…or so I thought…
Monday, I can go out and buy some more screws? ( Found the old box AFTER I did…) and maybe get the other frame done?
Stay tuned…about to get very messy in the shop….
#4 ·
Mortise work
Why two marks?
Coming along!
#5 ·
Frames are done, 1/2 the dovetails, too
Mondays…got to love them….two Doctor visits, about 35 miles apart….the the Boss had a lunch date, then a trip to Wall E World….I had a new set of pills to get, and a box of screws…too hot to sit out in the BLACK van, anyway.
Got home, took the new box of screws to the shop…looked around, found the almost full old box sitting in plain sight…gotta be Gremlins down here. Maybe it is them huge spiders?
Wood Engineering Hardwood Tool Lumber
I worked for a while, before I remembered the camera..that "Mondays" thing….Got #4 frame assembled, #3 and #4 got screws as well. Clamped all 4 frames together..beltsander and the planes were used to get all edges to almost match each other….the ends were the ones I wanted to match the best….for the next stepss
Wood Gas Toolroom Engineering Machine
Clamped to the side of the bench. Shelf sticks out a bit, just enough to rest this mess on…that corded object?
Automotive tire Wheel Motor vehicle Bicycle tire Tire
I wanted to add a dovetail bit and the fence to the router, set up to cut dovetails on the ends..
Wood Tool Gas Machine Engineering
First cut only needed 1/2 of the bit..
Automotive tire Wood Bicycle part Motor vehicle Saw
Then make a trip down each side..
Wood Workbench Tool Machine tool Toolroom
When I installed those nails and the screws, I had to keep them back from the edge, so the bit would miss..
Reset the fence…
Wood Machine tool Tool Engineering Workbench
For a second cut…final cut was right down the middle…
Wood Gas Motor vehicle Engineering Machine
Was a tad thin on one of them…..Later today, I can flip this mess over, and do the other ends. Then I need to lay out where these frames will go in the sides, and layout the sockets for the dovetails to slide into. I also need to flatten the panels…as the add-ons were thicker than the panels were….Old #8 will thin that down…
Need to go and buy a couple more 1×2s ans a 1×4….kickers and a face frame. Three 1×8 x 8' to make three drawers, and some 1/4" Luann Plywood..for drawer bottoms and a case back.
Will see how today goes….stay tuned..
#6 ·
Reset the fence…
Cool way to make those sliding dovetails.
#8 ·
Dovetail milling
Ok…went to the shop for a while….got a few things done, before I called it a day. Turned the stack of frames end for end..and plane the end smooth..
Wood Engineering Machine Tool Workbench
Used a #3 sized plane for that. Set the router up to better find the center of the stack…
Automotive tire Wood Gas Engineering Auto part
And ran that cut first, this time around..
Wood Machine tool Gas Engineering Tool
Then reset for two more passes..
Wood Machine tool Engineering Machine Tool
One more reset to get the outside cuts..
Wood Hand tool Tool Gas Metalworking hand tool
Then set the stack aside for a while. Got both panels out of the clamps..
Table Wood Hardwood Composite material Lumber
Set one aside, for now..have work to do on the other. Seems the add-ons I glued to the panels were a tad thicker than the panels..
Wood Floor Hardwood Flooring Plank
We have ways…..clamped the panel to the bench, and started with the No.8 Stanley
Wood Gas Hardwood Plane Machine
Worked decently enough. Arms were getting a bit tired, though. Flipped the panel over, decided to lighten the load on my arms a bit..
Wood Tool Gas Hardwood Workbench
  1. 7c and a #4…a cambered jack was also used, to get the real high spots down. #4 was more to clean up.
    Had a bit of knot caused tear-out on one end….promptly called that the bottom of the panel..
    Wood Flooring Floor Hardwood Wood stain
Which made this end the "Top". Decided it was also the "Inside" of the case. The two scraps are "stand ins" to lay out where the frames and kickers will be. Needed a little bit of room at the top, to allow corner blocks. Going with 1Ă—8s for drawers, so a 7" spacing was used. Used the large square to lay out lines for each frame and kicker..
Table Wood Rectangle Wood stain Plank
Worked my way down towards the "foot" area…wanted 5" between the bottom of the drawer, and the bottom of the foot. Which left a little bit extra on the end….including that tear-out.
Wood Automotive tire Table Wood stain Flooring
Came in from the edges about 2-1/2" or so..then used the old varnish can to draw some curves. Panel is too big to cut this on the bandsaw…will use the Vintage saws..
Wood Motor vehicle Tool Engineering Composite material
Both B&D one an all metal silver, the other a "newer" plastic green. Metal one for the straight cuts..
Wood Road surface Flooring Floor Hardwood
And the green machine for the curves..
Furniture Table Wood Flooring Floor
Discovered that can had a dent…will fine-tune that, before I trace this onto the other panel…wasn't quite done for the day, though. Got the "speed square" out..
Wood Rectangle Flooring Office ruler Plank
This has been many things in it's long life. Started out as a replacement rip fence for a DeWalt JobSite 10" saw, it has also been a bandsaw fence, and a circular saw guide. Today, it will be a router guide….
Electrician Tool Power tool Metalworking hand tool Electrical wiring
Need to set how far from the edge of the base to the center of the dovetail bit. Needed to mark the center of the socket the bit will cut. Used the combo square to set to guide…
Wood Flooring Floor Wood stain Hardwood
Then checked for square..
Wood Table Wood stain Floor Hardwood
Two clamps to hold the guide and the panel in place on the bench…
Wood Gas Composite material Flooring Engineering
Some nothing moves, final check with the square, start the router up..push through the cut, then pull back through to clean it out. I also pushed the router against the guide the entire time,, don't want it wandering off..
Wood Wood stain Flooring Floor Hardwood
This is where those dovetail pins on the frames will slide in. Reset the guide for the next cut..
Wood Floor Hardwood Flooring Wood stain
Then spin the panel around, and do the other two cuts…..well I at least spun things around….
Was getting worn out, even with the shop fan on "HIGH" was a bit stuffy. Swept the mess up..
Food Staple food Floor Gas Wood
And called it a day. Maybe tomorrow, I can get a few more cuts done?
Stay tuned…
#9 ·
Dovetail milling
Stay tuned…
Like that hi-tech french curve!
#11 ·
Sides are done
Meandered back to the shop, yesterday….had a few things to mill up…
Wood Wood stain Hardwood Outdoor furniture Lumber
Side #1 still had two of these sockets to do…
Table Wood Gas Engineering Machine
While that light comes in handy to see lines..camera hates it…Set this side over in the leg vise..
Wood Machine tool Gas Toolroom Engineering
I knew there was a reason that shelf stuck out a bit…set up the Wards #78…
Automotive tire Motor vehicle Vehicle Wood Wheel
Scratch awl is to pick stuck shavings out….also had a scrap of 1/4" plywood handy..to check the depth of cut..
Wood Saw Auto part Automotive wheel system Lumber
Thumb was getting a bit sore. Once the rebate was done…I could set this side over on the dryer, for now
Wheel Automotive tire Tire Wood Road surface
All of this mess was from flattening side #2….cambered jack, a couple long jointer planes and a #4 smooth plane..
Wood Naval architecture Vehicle Building Motor vehicle
Just like the other panel…even had some tearout on one end…laid side #1 on top..
Wood Table Plant Plank Lumber
The goal here was to mark side 2, to match side 1….and get rid of the worst spots….
Wood Electrical wiring Table Gas Wood stain
This became the "foot end" then I also marked the locations of the sockets..
Wood Table Gas Motor vehicle Automotive exterior
Which left the "top" to be trimmed down….The foot end was easy to do…
Wood Gas Power tool Electrical wiring Cable
But the other end needed something else….speed square also works as a circular saw..
Wood Table Hardwood Automotive wheel system Machine
I use the saw's foot plate to set the fence…motor side on the waste side ( fence too tall..) and clamp the fence as square as I can…and make the cut, holding the saw against the fence as I go..
Wood Loom Wood stain Hardwood Outdoor furniture
Then lay out and cut four sockets…and then the rebate…
Wood Motor vehicle Table Gas Automotive exterior
Then clamped both sides together, to double check how things lined up….then just left them there, while I cleaned the floor, yet again..
Wood Hardwood Machine Plank Machine tool
Legs were cramping up….fan set on "HIGH" wasn't helping a bit…was time to go upstairs, have a bowl of Ice Cream while sitting in front of the A/C unit….
Maybe later today, IF things cool off a bit…I can cut the top's panel for length? Might have enough left over, to resaw into 5 kickers? maybe a little assembly work? We'll see….
Stay tuned…
#12 ·
Sides are done
Stay tuned…
You get more work done in an afternoon than I do in an entire weekend, and in the heat and humidity. Maybe I need to ditch the A/C so I don't dawdle about when I'm in the shop?
Do you have any issues with board movement on big pieces like this when they get moved inside?
#15 ·
Dry fits, top done, and other follies
Dry fit….meh….One frame needed a hammer to get into place…two frames needed the router ran, as the pins were lopsided….
Wood Building Engineering Toolroom Industry
Added a few clamps, to pull thing together a bit better..
Wood Building material Beam Gas Hardwood
Sides were trying to cup a bit…Let this set a day….while I did some figuring….
OK, today…hauled any and all clamps that were upstairs to the shop ( yardsale finds) and a few other goodies…
Got the panel for the top of the case, cut to size….once all the clamps were stowed out of the way..
Wood Gas Garden tool Metal Composite material
Some here..
Motor vehicle Wood Gas Toolroom Machine
Some there. The big red c clamp was busy….I had to trim the panel to size..
Wood Machine tool Engineering Machine Toolroom
No fancy guides, this time…just split the line free-handed with the circular saw. Which left a small panel as a leftover..
Wood Wood stain Plank Flooring Hardwood
Which I marked a few lines on. These will become the kickers. Kickers keep a drawer from tipping down when you slide the drawer almost all the way out… They don't need to be too perfect, either. Babied the bandsaw to make a few rip cuts..
Wood Hardwood Natural material Plank Wood stain
Needed 5..but it always nice to have an extra one…Stanley #2246 mitre saw to cut these to length
Wood Wood stain Natural material Plank Composite material
Chose the 5 best…left the sixth for some other day..kickers get installed ( once I can get to the frames, again) via a dab of glue, and a screw at each end. Screws need counter sunk, to keep from hitting the drawer….point of the screw doesn't need to show, either…got out the usual suspects..
Wood Gas Engineering Metalworking hand tool Composite material
One drill for the pilot hole, another for the countersink….would take too long to keep changing bits, right?
Wood Stonemason's hammer Tool Metalworking hand tool Gas
1" screw….just enough to latch on to the frame…
Tool Wood Hand tool Metalworking hand tool Gas
And countersunk out of the way. Was starting to get a might too warm in the shop…..hmmm..
Wood Tool Workbench Machine tool Saw
Set this saw up to cut 45s….to make the corner blocks….something is missing in the background?
Wood Wood stain Hardwood Plank Lumber
Corner block…will use these (4 of them) to attach the top…..where is the fan?
Didn't like the squared corners on the top..got the sabresaw out…after a high tech radius tool was used..
Wood Automotive tire Wood stain Gas Hardwood
Doesn't get any simpler than this…Sabresaw had "issues with the cut..
Table Wood Gas Desk Hardwood
Beltsander can clean that right up…laid the top onto the case..for now..
Table Wood Outdoor table Outdoor furniture Wood stain
Was getting way too warm to work any more in the shop….tomorrow's first job is to bring that fan back into the shop….I swept the dust up, and closed the shop for the day. Had enough fun. The real FUN will be next time…trying to glue and clamp this mess together….and keep it squared up…a dozen or so clamps..vs..2 hands?
The cussing will be epic. Stay tuned…
#16 ·
Some here..
Looking good, you may have to check out the thread on sweeping compound?
#17 ·
A little assembly...
Well…the cussing wasn't quite at Drill Instructor level…..more like Squid level…..I made sure that fan was hauled to the shop, this time…
Laundry room Clothes dryer Washing machine Wood Automotive tire
And set on "HIGH"...goal was to get the case up onto the empty bench. Slide the loose side off the frames. Figures, had to turn the case around, had one frame that wanted to stick….with the frames still sitting there, I could attach the kickers…with a spot of glue and a screw at each end. I then slid each frame out, added the glue into the grooves… and slid the frames back in. Applied glue to the pins on the other end of the frames…then slid the "loose" side back in place….had a hammer handy, just in case…
Grabbed a couple pipe clamps, and clamped the bottom of the case….just enough that I could lid (barely) the mess off the bench and set it down…on about the flattest section of the shop's floor…and add more clamps..
Wood Flooring Gas Hardwood Composite material
Now, the kickers do not have to be perfectly centered and square….all they do is keep a drawer from tipping down, when you pull it out. Bottom two kickers are more to support the bottom rail of the face frame..
Wood Building Flooring Lumber Landscape
Needed a couple extra clamps…sides wanted to cup a bit in the middle..
Wood Rectangle Natural material Hardwood Lumber
Got this far, case did not rock…joints looked tight…got out some toys….and used the bandsaw. Had 4 corner blocks to make and install….45 degree cuts on the ends. drill a pilot hole, then countersink..
Wheel Wood Tire Tool Automotive tire
Used the first one as a pattern, made the other three…more screws and glue..
Wood Natural material Hardwood Wood stain Plank
Later, after this mess has set a day or two…I'll drill a slotted hole into each corner block….so I can attach the top.
Some of those pipe clamps were a bit long…too long to leave sticking out into the shop. Things weighs a ton, too..
Somehow managed to turn the mess around, and stash it out of the way..
Wood Hardwood Flooring Lumber Luggage and bags
Hard to believe..but…I even have a few extra pipe clamps on hand….been buying a bunch at yard sales this year..
Hopefully, I can get some more lumber, do a back for the case, and a face frame….then work on three drawers..need to buy a few knobs for the drawers…and maybe install the top? May run the router around the top's edge, again.
Stay tuned…
#18 ·
Stay tuned…
Just getting interesting and I have to go camping for a couple of weeks, probably have it all dun and in use by then.
#20 ·
Clamps are off, top is on...
And the supply of lumber is gone….for now.
Took the forest of clamps off, and stashed them out of the way, for now..
Wood Stairs House Gas Hardwood
Pipe clamps…..may almost have enough, for now..
Hand tool Boats and boating--Equipment and supplies Tool Gas Wood
About half of the other clamps….the "F" style are all hanging up. Cleared the top of the bench. Had to look over both faces of the top panel….trying to decide on which would look better….then set the "good side" down onto the bench.
Needed to add the corner blocks…
Wood Natural material Hardwood Wood stain Lumber
And add a slot. To do that, I drilled straight down..
Wood Wheel Automotive tire Hardwood Gas
Then rock the drill front to back a few times..
Wood Hardwood Engineering Lumber Wood stain
To turn the hole into a slot. Then flip the case over, and onto the top..
Wood Workbench Gas Hardwood Toolroom
Centered to be in the middle, and flush with the back of the case..
My 2" long screws were a tad too long….Visegrips to hold the screw, grinder to shorten the screw by an 1/8" and form a new point…..cup of water the dunk the hot part in.. then drive one screw in to each slot..
Wood Plank Hardwood Wood stain Window
I do not have the plywood for a back. I do have a leftover bit, about the right size for a drawer bottom…
Wood Flooring Floor Hardwood Table
I did use it to check the case for square, though..
Need to go shopping…1×2s and a 1×4 for the face frame….three 1×8 x 8's for the drawers, and a 1/4" x 4' x 4' plywood panel for a back, and two drawer bottoms. Maybe get a bit of stain as well?
Stay tuned,....almost done..
#21 ·
Gonna be a nice little chest of drawers!
#22 ·
Face frame, and a back
Trying to get caught up….from a "Lost Weekend" and a VERY BAD Monday…..somehow managed to get a back installed…
Furniture Wood Table Rectangle Wood stain
The way the case was…26" wide..vs..24" wide panel…..laid the panel sideways ( 48" wide?) and cut one panel to fit.
Will get the other section in a moment….you will notice I have the face frame installed. Just 6 sticks of pine..
Wood Natural material Hardwood Wood stain Rectangle
Glued and screwed in place. I used counter-bored holes, and will fill them with matching Pine plugs. Have a Veritas Tapered Plug Cutter that cuts 3/8" tapered plugs…..from face grain board. Of course, went to dig out the 3/8" forstner bit to drill the counter-bores…NADA….had to go out and BUY a new bit…..going to be one of those weekends..later, I installed the rest of the back panel…..had to fine tune the cut with a plane…
A look inside. Glue, nails, and a few screws, to secure the pack panels. Then worked on drawer guides..
Ruler Office ruler Wood Wood stain Nail
Just scrap 1×2s….didn't need to go the full depth….3/4s of the way was fine. The webframe for the top drawer was a tad too skinny….added a bit more width for the drawer to slide on. those two needed to go the entire way..
Wood Floor Wood stain Flooring Hardwood
Here is a view. As far as I can tell, the other frames will be wide enough….barely….I can add runners if need be.
Wood Gas Lumber Hardwood Machine
Even had to hoist the case back onto the bench, to better install the bottom guides…even did some rough sanding (180 grit) around the front…couldn't reach the top..
Wood Wood stain Floor Flooring Beam
And was getting ready to do the plugs…..glue bottle came up..empty. Figures. Left the case sit….then lost a weekend. Was a good thing the case was on the bench….had a heavy rain storm come through today…..and there was a couple shallow creeks going across the shop floor. I did manage to get a new bottle of glue, and 6 knobs today. The way this Monday was going….I think that will do….no sawdust was disturbed on Monday.
Maybe Tuesday…I can get back to work…for two whole days…..van is in the shop..radiator troubles…just one of those Mondays.
Maybe try to build a few drawers….only need three? Stay tuned…
#23 ·
I've learned quite a bit watching these builds of yours. One day I may have time to try one. Your doing a great job with it and it is looking great.
#25 ·
Plugging along
Was a very busy day, yesterday…..so I'll post this in a couple episodes today. First off, needed to get the case off the bench. To do that, I needed to make a bunch of plugs, install them…and then trim them all flush….
Veritas 3/8" Tapered Plug Cutter..
Automotive tire Vehicle brake Motor vehicle Tread Bicycle part
It does have a bad habit of biting off a plug, now and then.
Wood Gas Tool Machine Fastener
I try to avoid any knots, as well….a pin knot got "plugged", anyway…Cutter ate 2, chewed up a third, and that pin knot got a fourth….still was able to get just enough done, to fill 29 holes. I try to cut an extra one or two, just in case…
Wood Bottle Hardwood Wood stain Gas
"Tools" for this job…at least the install. Screwdriver is to pop each plug loose..
Wood Floor Building Flooring House
Once a plug is loose, I coat the narrow end with glue, and then hammer each plug into place…
Table Wood Wood stain Hardwood Plywood
I pay attention to the grain, and try to match the plug's to the surrounding area…takes a while..
Wood Wood stain Hardwood Plank Composite material
and I had just enough plugs, for a change..
Automotive tire Motor vehicle Vehicle Vehicle registration plate Automotive exterior
Even one left over!.....While the glue set up, I went upstairs, and hauled a 1Ă—8 x 8' plank down to the shop, as it will be the next item on the "To-Do List". Then grabbed a sharp chisel, and that hammer
And working from the 1st plug installed through to the last one, trimmed each plug flush..
Table Wood Ruler Tool Office ruler
Between the chisel and some 180 grit sandpaper, the plugs seemed to vanish….there is a plug sitting right in front of the chisel's edge….
Then I could set the case back down on the floor, since there are a few dry spots, now.
A 6' Skil circular saw to break down that plank…..cutting out the worst sections.
Wood Rectangle Hardwood Varnish Table
Here is 3 out of the 4. All are headed for the burn pile, later. Saw was a little wobbly ( may have been the Operator?) so I needed to square the ends a bit better..
Saw Hand tool Wood Tool Metalworking hand tool
Then try to fit a Front and two sides into the case….Once they were cut for length….all three needed a strip ripped for width..
Wood Wood stain Hardwood Flooring Plank
Bandsaw WAS still able to run, was able to rip most of the excess off..then the jack planes to smooth the rip cuts.
There was also a part for the drawer's back. cut to length, and then for width…
Motor vehicle Automotive tire Bumper Wood Automotive exterior
Junior Jack for the Front, until it fit the opening..
Table Wood Wood stain Hardwood Flooring
Then a regular jack plane for the ganged up sides
Table Wood Floor Wood stain Flooring
Until they fit. The back was also jointed, but will wait til later to be fitted
Wood Machine tool Tool Gas Machine
Then set up the Stanley #45…have a groove to do..
Wood Gas Hardwood Machine Auto part
Has a #12 straight cutter onboard…..1/4" in from the edge of the board…needed to cut the drawer bottom groove, so I could better lay out dovetail pins…
Wood Composite material Gas Machine Engineering
Dovetails? All of that will be in the next episode
Stay tuned…
#26 ·
Plugging along
Stay tuned…
Whew!
#27 ·
Dovetails?
Ah yes, the old debate….Tails first..vs..Pins first…...Dungeon Shop goes Pins first. So..
Wood Rectangle Machine tool Art Tool
My bevel square. There is a small combo square laying there as well. bevel is set to the angle I use for dovetails(need to write it down, sometime..)
Wood Machine tool Gas Hardwood Composite material
Where the groove comes through, one side of the pin is straight. Covers the groove. Then I work from each edge towards the center, laying out a few pins. had two backsaws to use, one was the "Veteran" and the other was a "Rookie".....thought I'd give the new guy a try..
Wood Gas Tool Machine tool Machine
It cut straight and fast..
Plane Wood Wood stain Plank Hardwood
But the handle is a bit too boxy for my hand…..went with the Old timer for the next set of these…
Once the cuts were done, I clamped the board to the bench, and chopped 1/2 way in and down
Wood Gas Wood stain Hardwood Plank
Leaves a bit of support..flip the board over, and finish the chopping. Transfer the layout marks to the other end, and repeat…
Wood Hardwood Lumber Machine Composite material
Front is now done. So how do I mark the tails? One of two ways….either stand the pin board up..
Wood Wall Gas Building Machine
And trace around each pin with a pencil…or
Wood Handheld power drill Saw Tool Workbench
Use a couple corner clamps to hold things still. Pencil? does not even have to be sharp. I cut to the waste side of each line, trying to leave the lines…
Hand tool Wood Tool Metalworking hand tool Gas
A few extra cuts help with the chopping. Bandsaw did these cuts…..then the bandsaw broke down..out for repairs
Had to resort to a handsaw for the other set of tails..
Wood Bumper Automotive exterior Building material Tool
Waste is all chopped out..one dry fit to check the fit
Wood Wood stain Hardwood Flooring Door
Then the second side was done, and it was also dry fitted..
Wood Gas Machine Composite material Metal
Sides were marked as to which side went where ( fits better, that way) then the jig for the 45 was set up
Table Wood Machine tool Automotive tire Hardwood
As the sides also needed a groove for the bottom….they also need a dado made, to house the back..
Wood Tool Saw Machine tool Gas
Mitre box to cut the dado walls….I WAS just going to chisel the waste out…decided a plane would be better
Wood Tool Engineering Saw Hand tool
A Stanley #39 3/8" Dado plane. Stanley did make a 3/4" wide one, all I have is the 3/8" one. No biggie, I cut from both walls, and meet in the middle. Stood the back in for a test fit..
Wood Gas Machine Toolroom Engineering
Works for me. The "Twins" showed up…
Wood Composite material Gas Auto part Machine
Needed a few counter sunk holes to attach the back to the sides. The miter cut? When you go to install that full drawer, and can't find the opening it goes in, these relieved corners help get the drawer started.
Old paint brush to smear some glue around….clamps and screw to assemble most of the drawer…..bottom?
Had to drag out the sabre saw, and cut a plywood bottom to fit…was still too wide? Vise to hold it, cambered jack plane to trim the edges…second try fit..
Motor vehicle Wood Gas Machine Auto part
Diagonal clamp to pull things into Square…..once it was square, THEN I added the screws to the bottom panel at the back…
Motor vehicle Wood Automotive exterior Gas Metal
Close enough. Will head to the shop after a bit, carrying the next plank, I'll remove these clamps, and clean the drawer up, and get it fitted…..and fit a pair of knobs to it…..one drawer done…only two more to do..
wasn't too bad of a day….spent half of it on this…
Wood Floor Flooring Hardwood Wood stain
Nice when you can sit down on the job…
Stay tuned….
#28 ·
Dovetails?
Stay tuned….
Yep, Dovetails!
#31 ·
one drawer fitted, another begun
Got the first drawer out of the clamps yesterday…..planes and the beltsander to clean things up. Had to keep working on the sides…drawer was binding a bit….finally got it to almost close….wax on the moving parts helped with that last inch….added a pair of knobs, so I could at least pull the drawer back out…
Hauled both 1×8 planks to the shop. Circular saw to cut out the very bad spots….
A regular Knot Farm.
Somehow managed to get enough "good" parts for most of the 2 drawers needing built….may have to buy a small, CLEAR short board…..some knots won't quite work…
Have to use things like these, as the bandsaw is out for repairs..
This doesn't look too good.
Last night, after the shop cooled down, went to work on Drawer #2….ends needed squared up on the drawer's front..
Well, this way didn't work out….went the the mitre box…
Takes a bit, cutting the 1×8 on the flat, but at least it will be square. Needed to remove a bit off one edge, until the blank fit in the opening….jack plane was used, this time around..
Won't be any see-through shavings, here…takes too long.
The other half of the shavings are on the floor. Once the blank fit into the opening, I jigged up for the Stanley 45, again. Drawer bottom groove..then I can lay out pins..
Will have to clean out that Pitch Pocket….
Hmmm, seemed to have an extra pin? Spacings do look a bit better, though…Backsaw, Disston No. 4
Used nice, long strokes, cuts fast. Imagine how many strokes a short, "Dovetail saw" would take….
Clamped to the bench, chop 1/2 way, flip over, and finish up on this side….repeat the steps, until both ends are done…..
Chopping Crew…
Went to use one of the sides…same routine with the non-square ends. Then marked how much to remove for the side to slide into it's spot in the case…..I am not using a plane for 1/4" removal….clamped the side to the bench, right over the opened vise. Circular saw to just leave the line. A pass or two to smooth the marks.
Stood one end of the front blank on top of the better end of the side blank..and traced the pins..
Backsaw to cut, leaving the lines. Cut are on the waste side of the lines. An extra cut in the middle of each, helps with the chopping. Again, chop from both faces. Then try a dry fit….
Couple hits with the mallet to start it…..almost 10pm? Time to close up for the day.
Maybe after Lunch, today…I can get a little more done? We'll see…
Stay tuned
#32 ·
A second drawer is done
Just one more to do.
Got busy yesterday….rest of the dovetails for the (NOW) top drawer were done. Had an issue with a knot right where the dado was going through…
Wood Lumber Gas Machine Hardwood
Was a bit rough on the Stanley #39. Mitre saw wasn't cutting the walls level..was hard to see the far side.
Got out a panel saw, to level the cuts..
Wood Hardwood Flooring Workbench Machine tool
The knot didn't bother this saw a bit. First drawer seemed to like the middle opening better..
Cabinetry Table Drawer Wood Flooring
So the second drawer made is now the Top Drawer. Managed to get everything glued up…
Motor vehicle Wood Engineering Gas Machine
This time, I installed one screw through the bottom panel…THEN pulled the diagonals into square..
Motor vehicle Wood Automotive exterior Gas Machine
And set out the knobs fro later. In the quest for something to do while the glue cured..
Brown Stairs Wood Wood stain Flooring
Stairway to the shop got a much needed sweeping…..and even the floor!
Wood Flooring Floor Stool Hardwood
Was after Supper last night, before the clamps came back off….and the drawer was cleaned up
Wood Saw Gas Hardwood Flooring
Sanders and a handplane were used to level these joints
Black Wood Road surface Flooring Foot
A mark was made to show where a knob would go….5" in from each end, centered on that center dovetail
Wood Wood stain Hardwood Plank Varnish
Hole was drilled, and the knob installed, with it's own bolt..and a spot of glue. That huge knot also got some sawdust and glue filler..
Brown Wood Trunk Wood stain Natural material
Then a test fit…
Furniture Cabinetry Table Wood Dresser
Something looked a bit…"off"...
Table Wood Natural material Rectangle Wood stain
Hmmm…well, I had a strip of Pine scrap about that thick….decided to cut a piece for each side of the opening, and glue and nail them to the inside edges of the face frame….NOT the drawer.
Cabinetry Table Drawer Wood Chest of drawers
Second time looked a bit better. Looked through the pieces I had set out for the last drawer..
Wood Natural material Wood stain Hardwood Lumber
Needed four good pieces…only had three….and one WAS for the back of the drawer….Hmmm.
Got the front piece fitted to it's new home..
Cabinetry Furniture Table Drawer Wood
Without the gaps. Which left these two boards..
Wood Flooring Rectangle Wood stain Hardwood
I figure I can buy a 2' Project board at Lowes, cheap…and use that as a back…I can then use these two as the drawer sides….at least they look better than some of the other scraps I had…
One of the sides has an extra feature..
Rectangle Wood Table Floor Flooring
That be a Bullet sitting there….someone had shot that Pine tree before it was cut into lumber.
Still no van…don't feel like walking in the rain. I can get the front and the two sides done, and ready for the back…whenever it gets here. Can also run this router bit around the edges of the top of the case..
Wood Rectangle Wood stain Flooring Hardwood
And get the top sanded smooth.
Bandsaw will have to wait, until the Chest of drawers is done , and out of the shop…then it can be torn down, and rebuilt..
Stay tuned…..almost done…
#33 ·
Then a test fit…
Lookin' Good!
#34 ·
Last of the dovetails are done
Still need to buy a board for the back of the drawer. Needed to clear off the bench, first..
Motor vehicle Wood Engineering Toolroom Gas
The shavings are from sizing the front of the drawer. Still needed a couple more "swipes" for the final fit..later
Even cleaned the floor, BEFORE I got started….still had to clean it a few more times. Got moving around just after 2pm in the shop. First, the drawer front needed a groove milled. Benchdog at one end..
Wood Office ruler Hardwood Wood stain Plank
A jig to keep the board from sliding around..
Wood Tool Metalworking hand tool Hand tool Auto part
Then a screw to tighten things into the dog…
Wood Gas Engineering Fastener Auto part
Screw is at an angle, and is inline with the dog. Had to open the leg vise a bit, fence on the Stanley 45 was hitting it at the start..
Wood Motor vehicle Gas Machine Auto part
Groove is a hair under 3/8" deep. 1/4" wide….and a 1/4" from the edge of the bottom of the board….Then, lay out for the dovetail pins…as I do pins first..
Automotive tire Wood Floor Flooring Wood stain
And seemed to pick up another "extra" pin? Tails and pins are getting close to the same size. Lowered the board in the vise, and waxed up the saw..
Wood Naval architecture Engineering Composite material Machine
Just an old candle. Saw the lines, chop the waste from both sides…..transfer the lines to the other end. I used a combo square…set it for each spot, transfer that to the other end….keep doing each mark until all are done…
(Later, when marking the tails, I mixed up, and used both ends, the wrong one first, then the correct end…wasn't any real change)
Repeat for the other end's pins. Stand the "Pin board" up, and mark out the locations….marking which spots will be waste…..and saw on the waste side of the lines…..Before I chisel…I use a square and a Utility Knife..
Wood Saw Hand tool Crosscut saw Tool
Whether with the pins or the tails, I use a Knife Wall….gives the chisel a line to stop at. About three good passes does the trick. Before I could transfer to mark out the tails..I needed to size the two drawer sides, including cutting the ends for square on the Mitre box saw…
Wood Machine tool Gas Engineering Toolroom
As they were a tad wavy on the ends…also made sure they were the same length. The LONG blank had a big knot on each end….HAD. Then both were sized for width, so they don't bind in the opening..
Wood Cat Tool Gas Machine tool
Jack plane was just about the right size to pare this down…..got both sides close for width…then ganged them up..
Motor vehicle Wood Gas Machine tool Automotive wheel system
And a couple passes until they matched each other. Then lay out for the tails, saw and chop, again..
Wheel Tire Automotive tire Wood Fender
The saw and my elbow were getting a work out. Have learned to sit slightly to one side, when chopping things out…some pieces tend to fly straight back out. Had one chisel give up…and ran away….right onto the floor, edge first…we have more. Time for the dry fits? Had one or two pins crumble during the chopping..
Wood Composite material Hardwood Gas Lumber
A spot of glue, and a few shavings to fill that in…other end turned out a little bit better..
Wood Gas Hardwood Wood stain Plywood
Went to slide this assemble into it's new home…..front was a hair too wide, yet….back to the bench, a few more passes with the jack plane…then try again..
Furniture Cabinetry Drawer Wood Chair
Sides still need a groove milled. Still needs a back made, and the dados to house it. And saw a drawer bottom to size…...THEN I can glue the last drawer up. Then come back, clean and fill…and install two knobs.
Stay tuned….
#35 ·
Stay tuned….
Have the board to make the back of that drawer..now. Might be able to get that drawer glued up later today?
have also picked up a pulley for the "new" motor for the bandsaw…...might get started rebuilding that old bandsaw later…..anyone want a blog about that?
This little blog was also about how I set up to do some of the tasks in building one of these dressers…other people may build a bit differently…..
#37 ·
Last drawer done, and a PIP
Board was brought to the shop, yesterday…
Wood Rectangle Wood stain Hardwood Gas
Two cuts were needed to be done, to get this done to size…
Wood Rectangle Floor Flooring Hardwood
Once those were done, and the back set aside for a bit….I knocked the other three parts back apart, had grooves to mill for the drawer's bottom to go into…
Wood Tool Motor vehicle Engineering Machine
Since these were the last of the grooves I needed milled, I could do something different for the dados
Wood Gas Engineering Electronic engineering Audio equipment
Made a new jig…..set up the Stanley 45 as a dado plane..
Wood Engineering Composite material Machine Hardwood
Turns out that a #18 cutter was a match for the width of the back.
Wood Rectangle Wood stain Plank Hardwood
To start the plane, I drag it backwards a few (3) times, to get the pair of nickers to bite….have had issues with "blowouts" where the plane enters and exits the cut, so..
Wood Plank Hardwood Wood stain Flooring
Backsaw makes a few cuts, down to the depth of the dado, only at the start and the exit.
Wood Engineering Tool Metal Machine
Then run the plane until the depth stop hits…..
Wood Natural material Composite material Gas Hardwood
And check the fit. I also bevel the back corners on my drawers….easy to insert them into the case.
Wood Hardwood Wood stain Tool Crosscut saw
While each side was in the jig..a pilot hole from the dado side,flip over, then do the countersinks.
Naval architecture Motor vehicle Wood Vehicle Watercraft
Once I had the plywood bottom cut to size…glue, clamps, a square..and a few screws were used
Let this sit a few hours, til the glue set up enough….
Wood Automotive tire Cabinetry Motor vehicle Tread
Hang the drawer from the vise…work on getting these..
Table Wood Flooring Floor Tool
To look like these..
Hood Wood Audio equipment Bumper Automotive exterior
And install the two knobs….Got the router set up.
Wood Automotive tire Gas Hardwood Machine
Ran it along the ends and front of the top..
Wood Workbench Gas Hardwood Wood stain
Around the fancy cutout at the feet..
Wood Natural material Hardwood Wood stain Plywood
Across the bottom edge of the front..
Table Tire Wood Outdoor furniture Rectangle
Then up the outside corners….until the router base hits the underside of the top..
Furniture Chair Wood Natural material Table
Then sand this all down to 180 grit ( for now, depending on what finish will be used) and stand it up..
Furniture Cabinetry Table Drawer Wood
For a PIP or two..
Cabinetry Wood Table Drawer Flooring
Daughter and her 9 yr old son can decide what flavour to make this little dresser.
Wood working part is done….maybe some more sanding, is all?
Thanks for following along.
#38 ·
For a PIP or two..
Thanks for the guided tour!
