A Stepback Cupboard build #7: Door is done....
Blog entry by bandit571 posted 01-11-2018 02:03 AM 486 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 6: Drawer fitted, door started Part 7 of A Stepback Cupboard build series Part 8: Updates: getting the lower unit about finished »
Well, I did get a panel glued up this week..
And let it sit a day…..today, it came out of the clamps. Marked for final width, and a rip cut made on the bandsaw.
Then face planed to remove some high spots..
Along with jointing the sawn edge. Width was now set, length was about as close as I could get it. Marked a line along one end, to do a bevel across the grain…..
Panel raising. This panel is a bit on the thick side. (more on that in a bit) Paul Sellers uses hand planes to raise a panel, by going at a “skew” to the grain. I do the cross grain first, the clean up by going with the grain along the other two edges..
Until I have a corner like this. I used the jack plane, to hog the waste off, then a #4 smooth plane to smooth things up…
With the panel so thick, I decided to add a rebate on the inside of the panel….to better fit in the grooves. For going across the grain, a Ward’s ( Stanley) #78 was set up…
I also used a dado plane, to clean things up..
And used a rail to test the fit.
Problem with the 78…the spur does not play nice with following the grain, along the edges,,,I set up the Stanley #45
To make the same cut…
Ok, once the panel was done, I set it aside. Then set up to do a few mortises…
Legs were cramping, anyway. Felt nice to sit a while. Finally was able to do a dry fit..
Then a couple more..
Then finally all four corners were fitted.
I used the end vise as a helping hand, while I spread some glue, and added some clamps..
Then found some hinges, and some pilot hole bits, cleaned the hinges up…
And called it a day. Waiting on glue to cure ( tomorrow?) then maybe a door installed?
Need to sand the sides of the case smooth. Then set up to make the Upper Cabinet.
Stay tuned…
3 comments so far
View Combo Prof's profile
Combo Prof
3656 posts in 1398 days
#1 posted 01-11-2018 03:52 AM
I tink you turn the spur on the 78 so no spur protrudes when using the 78 with the grain.
-- Don K, (Holland, Michigan)
View bandit571's profile
bandit571
21074 posts in 2803 days
#2 posted 01-11-2018 04:04 AM
You can…didn’t feel like messing with it, today. And, with the 45 handy….each could do the jobs.
Have also found a few spring-loaded door catches…..won’t have to buy any, now. Trying to decide what door(s) and shelves for the Upper Cabinet…..will be more of a bookcase….my son has a BUNCH that need a place to sit..
Trying to decide what flavour the finish will be…..
bandit571
#3 posted 01-12-2018 04:18 PM
Just a PIP..once I went and bought some screws for the hinges..
Ned to start on the upper unit, next..
Trying to figure out how tall to make it.
