A little time off #4: Dovetails cleaned up, lid is done..
Blog entry by bandit571 posted 11-07-2017 04:31 AM 1515 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 3: Time for a glue up Part 4 of A little time off series no next part
And even a PIP!
Dovetails were planed down flush with the sides…
Once all the corners and edges looked good, I could set up the Stanley 45 as a bead cutter..
As I wanted a pair of beads run all the way around…
Started on the ends first, then the sides, reset the fence a bit, and go around again..
Beads had to be low enough for a sliding lid..saw cuts were made..
Down to the top of the bead. mitre cuts on one end, then a plunge cut the split off a “handle”
Then, I could size the lid’s panel to fit into the top grooves. Once it fit nicely, without binding, I glued on the handle
I let it sit for a day. Then out of the clamps, and a final fitting…
So the lid would shut all the way. (look for a saw cut)
A view from the side. Open the lid?
All that is left is a finish, of some sort. Nice little box, just something a little different.
Thanks for following along.
1 comment so far
bandit571
21743 posts in 2882 days
#1 posted 11-08-2017 06:13 PM
Ok, First coat of the Infamous Witch’s Brew is now applied..
Debating on a second coat…then maybe a top coat of Gloss Poly? We’ll see how it goes…
