A little time off #3: Time for a glue up
Blog entry by bandit571 posted 11-04-2017 10:25 PM 481 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 2: Back to work, a box from Poplar scraps Part 3 of A little time off series Part 4: Dovetails cleaned up, lid is done.. »
First, I needed to make a bottom panel, and some grooves to fit the panels ( 2) into…
Dry fit, to get the size of the panel…close.. need grooves, though..
Set up the Stanley 45 with the #13 groove cutter. Built a jig on the bench….so the sides would stay put..
Get one side grooved along both edges, the do the other long side….adjust things to hold the shorter ends..
Made a bunch of “noodles”
Once all 8 grooves were done, I checked how they lined up..
Needed a rebate plane…
Bottom panel needed a rebate all around, as it was a bit too thick for the grooves…adjust the jig again.
Wards (Stanley) #78. Works nicely going across the grain..
Had to keep checking to make sure I didn’t go too deep. As for the edge grain….I started the cuts, but needed a different plane to remove most of the waste..
Then a pass or two to get to the final depth….Dry fit before the Elmer’s?
Then spread the Elmer’s around, and get out the clamps…
And let this sit a day, or so….stay tuned.
1 comment so far
View glideking's profile
glideking
45 posts in 212 days
#1 posted 11-05-2017 12:14 AM
I enjoyed thanks!
