Walnut & Cherry, new project #4: Lid work, and a sealcoat
Blog entry by bandit571 posted 09-12-2017 03:48 AM 950 reads 1 time favorited 1 comment Add to Favorites Watch
« Part 3: Stanley 45 time... Part 4 of Walnut & Cherry, new project series no next part
Box is out of the clamps. Decided to build the lid as a frame & raised panel..
Did a bit of trading for a stick of Black Walnut. Crosscut to get a few parts. These for the raised panel..
needed this for a pair of long rails, and..
These two for the short rails.. Long rails were ripped into a matching pair….needed saw marks removed..
Next day. got the blank out of the clamps, and planed them flat..
Made a jig to hold the panel still..
While a pair of #4 planes worked it over..
One set coarse, one set super fine….Needed to bevel the edges…
End grain first, then the edge grain until a nice, sharp corner shows up..
used the Stanley 45 to mill a few grooves, to hold the panel..
Which meant the jig needed reworked.
Then cut tenons with the Mitre box , and the bandsaw…..then wrestled parts, clamps, and cauls….and a bit of glue..
Two cauls per corner, and a c clamp vs two hands? Wasn’t pretty
let this sit a day…
Today’s chores: Clean and level all the glue joints, and sand things down to 220 grit. Bandsaw to finish shaping the front and back edges of the lid. Now has a finger “lift”. Small cove bit in a CORDED router was run around the bottom edges of the box. Dusted the mess off, brough the box upstairs for a sealcoat of amber shellac..
Back view. No hinges installed..yet..
End view
Front view….You might be able to see the cove details on the “feet”. Yes, I missed a couple places with the shellac… top view?
maybe Tuesday..I can get something done?
Stay tuned, almost done….
1 comment so far
View bandit571's profile
bandit571
21975 posts in 2918 days
#1 posted 09-13-2017 04:14 PM
Has been posted as a Project.
Thanks for following along!
